    New build system introduced, testing and feedback needed
    PanelDue
    2.8k
    • mfs12undefined
      mfs12
      @gloomyandy said in New build system introduced, testing and feedback needed:
      The LPC and STM32 builds of RRF both use make
      Can you point me to the repository? Eventually it would be an option to port your solution to RRF.
      Visit me on github at https://github.com/mfs12/
      jay_s_ukundefined gloomyandyundefined 2 Replies Last reply Reply Quote 2
        jay_s_uk @mfs12
        @mfs12
        Here's the main build repo https://github.com/gloomyandy/RRFBuild/tree/v3.4-dev
        • oliofundefined
          oliof @gloomyandy
          @gloomyandy I kind of agree. Considering I need to manually pass the really important info (where are the build binaries, what do I want to build) manually into CMake to make it work on Windows, a well-constructed set of Makefiles might be cleaner and easier to follow along in the end. But I won't say no to CMake, and it's @mfs12´s weapon of choice (-:
          • gloomyandyundefined
            gloomyandy @mfs12
            @mfs12 The repo that jay pointed you to is the overall build repo. The actual make files we currently keep in the CoreN2G repo (which may or may not be a good idea):
            https://github.com/gloomyandy/CoreN2G/tree/v3.4-dev/src/STM32F4/makefiles
            https://github.com/gloomyandy/CoreN2G/tree/v3.4-dev/src/LPC/makefiles
            I doubt if these qualify as a "well constructed set of makefiles", but they do the job. For historical reasons we currently keep two separate sets of build files for the two different mcus, it would probably make sense to combine them and have a different make build target.
            cmake is certainly a lot easier to handle than the eclipse build file system!
            • oozeBotundefined
              oozeBot
              Thanks all. I'm getting further and can create the build files, but am now stuck at the following:
              PS C:\Eclipse\PanelDueFirmware> make -C build all -j12
              make: Entering directory 'C:/Eclipse/PanelDueFirmware/build'
              Makefile:32: *** missing separator.  Stop.
              I've tried other variations with no luck. FYI - (Get-Command make).Path returns:
              C:\Program Files\GNU ARM Eclipse\Build Tools\2.6-201507152002\bin\make.exe
              Thanks in advance.
              • mfs12undefined
                mfs12
                @oozeBot
                can you send the file 'C:/Eclipse/PanelDueFirmware/build/Makefile'
                There's something wrong with the makefile. any path you pass as commandline parameter needs to be in quotes, backslash replaced with slash and whitespaces escaped with backslash.
                Can you share your cmake call?
                oozeBotundefined 1 Reply Last reply Reply Quote 0
                • oozeBotundefined
                  oozeBot @mfs12
                  @mfs12 - Here you go - both renamed to ".txt". I believe I've setup env.vmake correctly. With it, my cmake command is just
                  cmake -B build
                  env.cmake.txt
                  Makefile.txt
                  I'm reviewing the makefile now - one thing of note I've found is on line 79 - note the double "\\". edit - changing the \\ to \ didn't fix it. still reviewing.
                  C:\Eclipse\PanelDueFirmware\build\\CMakeFiles\progress.marks
                  edit - There was an unescaped space in my env.cmake file that I just corrected, but still receiving the same error.
                  • mfs12undefined
                    mfs12
                    @oozeBot somehow make wants the if-block at line 32 indented. I don't understand why. Weird enough.
                    Anyway i want cmake to run on you machine so hacking the makefiles is not really an option. Just for testing.
                    • oozeBotundefined
                      oozeBot @mfs12
                      @mfs12 - thanks. I got past it by indenting the entire IF block in both makefile and CMakeFiles\makefile2. Pretty strange..
                      Current error I'm researching:
                      make[1]: Entering directory 'C:/Eclipse/PanelDueFirmware/build'
                      make[1]: *** No rule to make target '/nologo'.  Stop.
                      make[1]: Leaving directory 'C:/Eclipse/PanelDueFirmware/build'
                      Makefile:79: recipe for target 'all' failed
                      make: *** [all] Error 2
                      make: Leaving directory 'C:/Eclipse/PanelDueFirmware/build'
                      • mfs12undefined
                        mfs12
                        You can always make the build verbose.
                        $ make -C build VERBOSE=1 all
                        • oozeBotundefined
                          oozeBot @mfs12
                          @mfs12 - Thank you for the hand-holding.
                          I see an error but am not sure where it came from yet. Look at line 5. That does not exist on my system and was not defined anywhere that I have yet to find.
                          edit - that's the path to "make" and does exist. My mistake - I was looking in Program Files (x86).
                          PS C:\Eclipse\PanelDueFirmware> make -C build VERBOSE=1 all
                          "C:\Program Files\CMake\bin\cmake.exe" -SC:\Eclipse\PanelDueFirmware -BC:\Eclipse\PanelDueFirmware\build --check-build-system CMakeFiles\Makefile.cmake 0
                          "C:\Program Files\CMake\bin\cmake.exe" -E cmake_progress_start C:\Eclipse\PanelDueFirmware\build\CMakeFiles C:\Eclipse\PanelDueFirmware\build\CMakeFiles\progress.marks
                          C:/Program Files/GNU ARM Eclipse/Build Tools/2.6-201507152002/bin/make  -f CMakeFiles\Makefile2 /nologo -w -- VERBOSE=1 all
                          • mfs12undefined
                            mfs12
                            @oozebot said in New build system introduced, testing and feedback needed:
                            How old is your eclipse and toolchain? Is this a date 201507152002?
                            I think this might be an issue.
                            • mfs12undefined
                              mfs12
                              this nologo parameter is somehow related to verbosity. So if you remove VERBOSE=1 again. Does it work then?
                              • oozeBotundefined
                                oozeBot @mfs12
                                @mfs12 no, it returned the same error as I posted above.
                                My toolchain is
                                C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2021.07\bin
                                and the Eclipse IDE is
                                Version: 2021-06 (4.20.0)
                                Build id: 20210612-2011
                                Reviewing now how to update make.exe
                                • mfs12undefined
                                  mfs12
                                  in the end this /nologo parameter is the issue. Make thinks it's a target but it's actually parameter intended for the windows linker. Really strange.
                                  If you delete that. You get a step further.
                                  • mfs12undefined
                                    mfs12
                                    Apparently you can install additional tools using eclipse. Probably update them as well. Eventually this didn't happen for some time.
                                    • oozeBotundefined
                                      oozeBot @mfs12
                                      @mfs12 - much closer now. I had two versions of make.exe. I updated it and removed all references to /nologo. However, the version without a logo is what I am needing to compile?
                                      Here is where I currently am at.
                                      C:\Eclipse\PanelDueFirmware\build C:\Eclipse\PanelDueFirmware\build C:\Eclipse\PanelDueFirmware\build\CMakeFiles\paneldue.elf.dir\DependInfo.cmake --color=
                                      make[2]: Leaving directory 'C:/Eclipse/PanelDueFirmware/build'
                                      C:/Program Files/GNU ARM Eclipse/Build Tools/2.6-201507152002/bin/make  -f CMakeFiles\paneldue.elf.dir\build.make  -nw -- VERBOSE=1 CMakeFiles\paneldue.elf.dir\build
                                      make[2]: Entering directory 'C:/Eclipse/PanelDueFirmware/build'
                                      make[2]: *** No rule to make target 'lib\librrf\librrf.a', needed by 'paneldue.elf'.  Stop.
                                      make[1]: *** [CMakeFiles\Makefile2:93: CMakeFiles\paneldue.elf.dir\all] Error 2
                                      make: *** [Makefile:80: all] Error 2
                                      • oliofundefined
                                        oliof
                                        did you check out librrf as a submodule as detailed in the build instructions?
                                        • mfs12undefined
                                          mfs12
                                          @oozeBot sounds like you didn't checkout the git submodules.
                                          Please refer to https://github.com/Duet3D/PanelDueFirmware#setup-repository
                                          • oozeBotundefined
                                            oozeBot @oliof
                                            @oliof yes, I did and the root lib/librrf contains many files, so I think I did it right!
