    Fans dont appear in Dwc
    749
      Please share your config.g
      peirofundefined 1 Reply Last reply Reply Quote 0
      • peirofundefined
        peirof @Phaedrux
        @phaedrux think i have find the issue, i need 2 restarts of board, in 1 first dont detect the chages...
        • peirofundefined
          peirof @peirof
          @peirof
          Well, think i have find something... i explain the process.
          01 - I have setup all 3 fans thermostatilly controlled, putting this in config.g
          Fans
          M950 F0 C"fan0"
          M106 P0 T45 H1
          M950 F1 C"fan1"
          M106 P1 T45 H1
          M950 F2 C"fan1"
          M106 P2 T45 H1
          02 - i have unplug al fans from board
          03 - With DWC i have raise temperature in hotend to 100º
          04 - With a multimeter, i have tested voltage in always on fans1/2... all two 24 v
          05 - With temperature of hotend around 100 degress, I have checked the voltage on the shocket fan0..., I CAN READ 24V, the fans connected here turns
          06 - With temperature of hotend around 100 degress, I have checked the voltage on the shocket fan1..., I CAN READ 20.8V, the fans connected here dont turns
          07 - With temperature of hotend around 100 degress, I have checked the voltage on the shocket fan1..., I CAN READ 0V, upsss....the fans connected here dont turns
          Well, think i have read, that in FW3, can change the funtion of a shocket...
          How could this be done?
          Could I use one of the Always Fan On, as a layer fan?
          What other connection could I use? Maybe E1 (one of the thermistors, which I don't use)
            Phaedrux Moderator @peirof
            M950 F1 C"fan1"
            M106 P1 T45 H1
            M950 F2 C"fan1"
            M106 P2 T45 H1
            Did you intend to use fan1 twice?
            @peirof said in Fans dont appear in Dwc:
            Always on is always on, so it would work if you want tha part fan always on. Maybe that's ok.
            You could use a free heater pin as a fan. In the M950 where you declare the pin "fan1" use "e1heat" instead.
            • peirofundefined
              peirof @Phaedrux
              @phaedrux
              eee.... where i can find doc, how to do it?
              its strange, but thin that the socket that twrows 20,4 volts, must be turn the fan.... maybe slowy
                Has the mosfet on the fan been damaged?
                • peirofundefined
                  peirof @Phaedrux
                  @phaedrux how i can see/check this?
                    Do they look like this?
                    https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
                    • peirofundefined
                      peirof @Phaedrux
                      @phaedrux
                      Seems that, no. But not sure.
                      attach photo
                      P.D.: i am thinking, and the fan connected in Shocket FAN1, yesterday turns.... estrange... Can do more tests?
                      • peirofundefined
                        peirof @peirof
                        @peirof
                        one dude....
                        What minimum voltage does it need to turn? I say it, because perhaps a 24V fan, with a voltage of 20.4, V should rotate even if it was slower.
                        No?
                          No?
                          Maybe? It would depend on the fan on how it tolerated undervolting.
                          giostarkundefined 1 Reply Last reply Reply Quote 0
                          • giostarkundefined
                            giostark @Phaedrux
                            @phaedrux
                            I'm using now a fan for the nozzle that is 40x40x28 , 6.8Watt and is not pwm despite is declared 6-13.8 voltage range. If I don't give the 100% it won't either spin a little.
                            https://www.aliexpress.com/item/4000358337229.html?spm=a2g0o.productlist.0.0.1af91fae2vpxjC&algo_pvid=2777b708-8377-426c-8404-8851119de85f&algo_exp_id=2777b708-8377-426c-8404-8851119de85f-5
                            It is really powerful and make a lot of loud BUT when I close the enclosure it completely disappear. (luckily)
                            Ps: I made the mode of the 12v with the LM2596 >> Zl116LUM also for make lower Ampere.
                            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s214
                            Mine was fuse but not damaged ! (exteriorly)
                            https://forum.duet3d.com/topic/23594/solved-shorted-pwm-fan2
                            So basically to be sure settings are fine , the fan is good, and noting if fried.
                            • peirofundefined
                              peirof @giostark
                              Is this the correct configuration to use heater 01 as a fan?
                              in this case, for thermostatic tests, then it will be per layer
                              M950 F2 C"e1heat"
                              M106 P2 T45 H1
                                You can find all pin names here. e1heat is correct.
                                https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
                                peirofundefined 1 Reply Last reply Reply Quote 1
                                • peirofundefined
                                  peirof @Phaedrux
                                  @phaedrux do it, works.... FW3 save me the ass
                                  Phaedruxundefined 1 Reply Last reply Reply Quote 2
                                    FW3 save me the ass
                                    We should put that on the tin.
                                    • peirofundefined
                                      peirof @Phaedrux
                                      @phaedrux said in Fans dont appear in Dwc:
                                      are you free
