    Fans dont appear in Dwc
    747
    • peirofundefined
      peirof @Phaedrux
      @phaedrux how i can see/check this?
        Do they look like this?
        https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
        peirofundefined 1 Reply Last reply Reply Quote 0
        • peirofundefined
          peirof @Phaedrux
          @phaedrux
          Seems that, no. But not sure.
          attach photo
          P.D.: i am thinking, and the fan connected in Shocket FAN1, yesterday turns.... estrange... Can do more tests?
          • peirofundefined
            peirof @peirof
            @peirof
            one dude....
            What minimum voltage does it need to turn? I say it, because perhaps a 24V fan, with a voltage of 20.4, V should rotate even if it was slower.
            No?
              Phaedrux Moderator @peirof
              @peirof said in Fans dont appear in Dwc:
              No?
              Maybe? It would depend on the fan on how it tolerated undervolting.
              giostarkundefined 1 Reply Last reply Reply Quote 0
              • giostarkundefined
                giostark @Phaedrux
                @phaedrux
                I'm using now a fan for the nozzle that is 40x40x28 , 6.8Watt and is not pwm despite is declared 6-13.8 voltage range. If I don't give the 100% it won't either spin a little.
                https://www.aliexpress.com/item/4000358337229.html?spm=a2g0o.productlist.0.0.1af91fae2vpxjC&algo_pvid=2777b708-8377-426c-8404-8851119de85f&algo_exp_id=2777b708-8377-426c-8404-8851119de85f-5
                It is really powerful and make a lot of loud BUT when I close the enclosure it completely disappear. (luckily)
                Ps: I made the mode of the 12v with the LM2596 >> Zl116LUM also for make lower Ampere.
                https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54#s214
                Mine was fuse but not damaged ! (exteriorly)
                https://forum.duet3d.com/topic/23594/solved-shorted-pwm-fan2
                So basically to be sure settings are fine , the fan is good, and noting if fried.
                • peirofundefined
                  peirof @giostark
                  Is this the correct configuration to use heater 01 as a fan?
                  in this case, for thermostatic tests, then it will be per layer
                  M950 F2 C"e1heat"
                  M106 P2 T45 H1
                    You can find all pin names here. e1heat is correct.
                    https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
                    peirofundefined 1 Reply Last reply Reply Quote 1
                    • peirofundefined
                      peirof @Phaedrux
                      @phaedrux do it, works.... FW3 save me the ass
                      Phaedruxundefined 1 Reply Last reply Reply Quote 2
                        FW3 save me the ass
                        We should put that on the tin.
                        • peirofundefined
                          peirof @Phaedrux
                          @phaedrux said in Fans dont appear in Dwc:
                          are you free
