    How to make Prusa Slicer work
    Third-party software
    2.9k
    • achrnundefined
      achrn @A Former User
      @the_dragonlord said in How to make Prusa Slicer work:
      with Ideamaker and Simplify3D I have no extrusion issue, only with PS
      Slice the same very simple model (like a three-layer solid square) and read the gcode to see if they are all consuming the same amount of filament?
      I note that in the gcode snippet up thread, your first two lines each extrude 22mm of filament over a 240mm line, that's 52.9mm3 of material, so should be laying down a 0.22mm2 line of extrusion, which if nozzle is at 0.3mm off the bed should be 0.7mm wide. If you're not getting that, it looks like a printer problem, not a slicer problem.
      A Former User? 2 Replies Last reply Reply Quote 0
        A Former User @achrn
        @achrn said in How to make Prusa Slicer work:
        The two lines come out perfectly, the problems start with the sliced GCODE
          Here are the first layers of a simple cube sliced with ideamaker:
          ;PRINTING: default-box.3mf
          ;PRINTING_ID: 0
          G1 F2400 E-3.0000
          G0 F9000 X155.292 Y155.292
          ;TYPE:WALL-OUTER
          ;WIDTH:0.585
          G1 F1500 E3.0000
          G1 F2400 X164.708 Y155.292 E0.6321
          G1 X164.708 Y164.708 E0.6321
          G1 X155.292 Y164.708 E0.6321
          G1 X155.292 Y155.292 E0.6321
          G0 F9000 X156.462 Y156.462
          ;PRINTING_TIME: 13
          ;REMAINING_TIME: 202
          ;LAYER:1
          ;Z:0.500
          ;HEIGHT:0.200
          M106 S255
          G4 P200
          M106 S255
          M104 T0 S205
          ;PRINTING_ID: 0
          M82
          M98 P"Print_gcodes/pressure_advance_at_layer_change.g"
          M83
          G0 F900 Z0.500
          G0 F9000 X155.225 Y155.225
          ;TYPE:WALL-OUTER
          ;WIDTH:0.450
          G1 F600 X164.775 Y155.225 E0.3288
          G1 X164.775 Y164.775 E0.3288
          G1 X155.225 Y164.775 E0.3288
          G1 X155.225 Y155.225 E0.3288
          G0 F9000 X156.125 Y156.125
          ;PRINTING_TIME: 17
          ;REMAINING_TIME: 198
          ;LAYER:2
          Here are the same file sliced with PS:
          ;LAYER_CHANGE
          ;Z:0.44
          ;HEIGHT:0.2
          G1 Z0.440 F7200.000
          G10 S205 ; set temperature
          G1 X160.200 Y169.800
          ;TYPE:External perimeter
          ;WIDTH:0.4
          G1 F900.000
          G1 X160.200 Y160.200 E0.28504
          G1 X169.800 Y160.200 E0.28504
          M73 P15 R2
          G1 X169.800 Y169.800 E0.28504
          G1 X160.260 Y169.800 E0.28325
          G1 E-3.00000 F2400.000
          G1 Z0.640 F7200.000
          G1 X160.342 Y161.178
          G1 Z0.440
          G1 E3.00000 F2400.000
          ;TYPE:Solid infill
          ;WIDTH:0.456468
          M73 P16 R2
          G1 F3600.000
          G1 X160.995 Y160.525 E0.03177
          G1 X161.580 Y160.525 E0.02011
          G1 X160.525 Y161.580 E0.05131
          G1 X160.525 Y162.165 E0.02011
          G1 X162.165 Y160.525 E0.07975
          G1 X162.749 Y160.525 E0.02011
          G1 X160.525 Y162.749 E0.10819
          G1 X160.525 Y163.334 E0.02011
          G1 X163.334 Y160.525 E0.13663
          G1 X163.919 Y160.525 E0.02011
          G1 X160.525 Y163.919 E0.16507
          G1 X160.525 Y164.504 E0.02011
          G1 X164.504 Y160.525 E0.19351
          G1 X165.089 Y160.525 E0.02011
          G1 X160.525 Y165.089 E0.22195
          G1 X160.525 Y165.674 E0.02011
          G1 X165.674 Y160.525 E0.25039
          G1 X166.259 Y160.525 E0.02011
          G1 X160.525 Y166.259 E0.27883
          G1 X160.525 Y166.843 E0.02011
          G1 X166.843 Y160.525 E0.30727
          G1 X167.428 Y160.525 E0.02011
          G1 X160.525 Y167.428 E0.33572
          M73 P17 R2
          G1 X160.525 Y168.013 E0.02011
          G1 X168.013 Y160.525 E0.36416
          G1 X168.598 Y160.525 E0.02011
          G1 X160.525 Y168.598 E0.39260
          G1 X160.525 Y169.183 E0.02011
          G1 X169.183 Y160.525 E0.42104
          G1 X169.475 Y160.525 E0.01006
          G1 X169.475 Y160.817 E0.01005
          G1 X160.817 Y169.475 E0.42104
          G1 X161.402 Y169.475 E0.02011
          G1 X169.475 Y161.402 E0.39260
          G1 X169.475 Y161.987 E0.02011
          G1 X161.987 Y169.475 E0.36416
          G1 X162.572 Y169.475 E0.02011
          G1 X169.475 Y162.572 E0.33572
          M73 P18 R2
          G1 X169.475 Y163.157 E0.02011
          G1 X163.157 Y169.475 E0.30728
          G1 X163.741 Y169.475 E0.02011
          G1 X169.475 Y163.741 E0.27884
          G1 X169.475 Y164.326 E0.02011
          G1 X164.326 Y169.475 E0.25040
          G1 X164.911 Y169.475 E0.02011
          G1 X169.475 Y164.911 E0.22196
          G1 X169.475 Y165.496 E0.02011
          G1 X165.496 Y169.475 E0.19352
          G1 X166.081 Y169.475 E0.02011
          G1 X169.475 Y166.081 E0.16507
          G1 X169.475 Y166.666 E0.02011
          G1 X166.666 Y169.475 E0.13663
          G1 X167.250 Y169.475 E0.02011
          G1 X169.475 Y167.250 E0.10819
          G1 X169.475 Y167.835 E0.02011
          G1 X167.835 Y169.475 E0.07975
          G1 X168.420 Y169.475 E0.02011
          G1 X169.475 Y168.420 E0.05131
          G1 X169.475 Y169.005 E0.02011
          G1 X168.822 Y169.658 E0.03178
          M106 S127.5
          They are completely different from each other.....
          A Former User? achrnundefined 2 Replies Last reply Reply Quote 0
            A Former User @A Former User
            @the_dragonlord Here's what happens:
            https://youtu.be/gVyKdpvdzXg
            • achrnundefined
              They aren't expected to be the same.
              Also, I note your Prusa example has a skirt, apparently with curves at the corners, so that muddies the waters. There's also reference to pressure advance in teh code, but I don't think that's more than a red herring.
              Your ideamaker cube has this:
              ;TYPE:WALL-OUTER
              ;WIDTH:0.585
              So that is simple squares, the nozzle moving 9.416mm to a side and using 0.6321mm of filament. That's 0.161mm2 extrusion.
              The Prusaslicer cube has this
              ;WIDTH:0.4
              So that is simple square, the nozzle moving 9.600mm to a side and using 0.28504mm of filament. That's only 0.072mm2 extrusion
              The comments say the Prusa is a thinner wall, but only 10% thinner. Pro-rata both to 0.45 thick would bring the Prusa up to 0.0805mm2.
              So the Prusa is delivering half as much filament (curiously, exactly half as much) for some reason. However, I'm suspicious that the Prusa is delivering what it should - a 0.4 x 0.2 mm extrusion should be 0.4x0.2=0.08mm2. Have you, long ago, put some correction factor into the other slicers for some reason?
              With a factor of exactly two I'd start to wonder if a 400 step stepper was swapped for a 200, and 'fixed' by putting an extrusion multiplier in? As per previous poster's suggestion, I'd go back and check calibration and configuration of the extrusion hardware from fresh, but you didn't like that suggestion.
              achrnundefined A Former User? 2 Replies Last reply Reply Quote 1
              • achrnundefined
                achrn @achrn
                ;TYPE:WALL-OUTER
                ;WIDTH:0.585
                Aha, but I've just noticed that further down it has
                0 F900 Z0.500
                ;TYPE:WALL-OUTER
                ;WIDTH:0.450
                Which is much closer to the Prusa case. I don't jknow what that slicer is doing there. I still think teh GCode from Prusa is calling for about teh right amount of material.
                  ;TYPE:WALL-OUTER
                  ;WIDTH:0.585
                  ;WIDTH:0.4
                  Thanks for your answer, in Ideamaker I haven't made any adjustment on the stepper steps/mm or some kind of multiplier...It not I didn't liked the suggestion, it's that they are all steps that I've made right now and I'm sure that in Ideamaker I have no firmware overrides about step/mm or so on...I've just made several thin wall tests to get the exact extrusion multiplier for all my filaments....I really don't know what's happening....even with Simplify3D it all gone well...only with PS there are problems...
                  gloomyandyundefined 1 Reply Last reply Reply Quote 0
                  • gloomyandyundefined
                    gloomyandy @A Former User
                    @the_dragonlord How did you tune your extruder steps/mm set in config.g? If it involved something that used your slicer you may have in effect tuned for that. What value do you have set for steps/mm in your config.g file and what extruder are you using?
                      A Former User @gloomyandy
                      @gloomyandy said in How to make Prusa Slicer work:
                      415 step/mm, original bondtech BMG
                        @the_dragonlord Assuming that has a standard 1.8 degree stepper (does it?), that sounds fine.
                          it sound because it is fine 😊 with other slicers I have no problems
                          engikeneerundefined 1 Reply Last reply Reply Quote 1
                            Is the first layer height the same? Same width and flow rate?
                            • engikeneerundefined
                              engikeneer @A Former User
                              @the_dragonlord I've used PS for years with issues so am slightly perplexed by your issue!
                              One thought - are the filament/printer/print profiles that you're editing the ones that PS is using to slice the file? I.E. Do these:
                              Match these:
                              Could simply be that you're actualy slicing with one of the default 2.85mm profiles?
                              Failing that, if you can export your config from PS (File, Export, Export config), post it here and I can try it on mine to see what's up. Might need to rename the filetype to .txt to upload it to the forum
                              i3 clone with a bunch of mods
                                A Former User @Phaedrux
                                @phaedrux said in How to make Prusa Slicer work:
                                yes
                                  A Former User @engikeneer
                                  @engikeneer said in How to make Prusa Slicer work:
                                  Match these:
                                  no, it's not my case, the profiles, unfortunately, are correct. Here's my config fileconfig.ini.txt
                                  Thanks!
                                  engikeneerundefined 1 Reply Last reply Reply Quote 0
                                    @the_dragonlord I think I've found some of your issue. Your first layer extrusion width is set to 120%, so over a 0.24mm first layer height, you only get 0.288mm width lines for your first layer. Personally, I set all these as widths in mm so I know what I'm getting even if I change the layer height.
                                    You can see this if you look at the sliced line widths on the plater. Looks like the brim and infil are affected, but the external perimeter is slicing at 0.4mm which you specified.
                                    The other thing I noticed is that you are using absolute extrusion. General advice is to use relative extrusion because you may lose accuracy in long prints. Note that you've got M92 in your custom start code there too!
                                      excellent, thanks! i'll try your suggestions when I'll return home! what is your setting for the first layer extrusion width?
                                      • achrnundefined
                                        achrn @engikeneer
                                        I thought that, and I would have sworn that's what at least one of the files extracts showed the first time I looked at them, but it's not what they show the second time I looked (and now). This is clearly not absolute extrusion:
                                        ;LAYER_CHANGE
                                        ;Z:0.44
                                        ;HEIGHT:0.2
                                        G1 Z0.440 F7200.000
                                        ;WIDTH:0.4
                                        G1 F900.000
                                        M73 P15 R2
                                        otherwise there's no extrusion on two of those sides, and retraction on the fourth.
                                        So now I'm wondering if the forum is occasionally showing a differnet file to reasders!
                                          @the_dragonlord I think 0.45mm for a 0.35mm nozzle, but I'm not 100% sure as I'm out today. Typically I'd do nozzle width +30-40% for first layer but I've never really played too much attention to it tbh...
                                          Also @achrn makes a good point. In your first post you had relative extrusion selected but had an M82 in you custom start code which may have overridden things and caused your issue.
                                          Edit: back home now and here are the setting I used to use for my 0.4mm nozzle (though I've been using a 0.35mm for a while now). They work okay for me, but not done any calibration etc - main thing is that the support material is less than nozzle dia so that it is weaker, all the others are larger
