    InputShaping-Plugin-0.1.0-rc7 released (repacked)
    Plugins for DWC and DSF
    12
    32
    2.2k
    • tecnoundefined
      tecno @mfs12
      @mfs12
      Input-Shaping Tab is emty = black
      mfs12undefined 2 Replies Last reply Reply Quote 0
      • mfs12undefined
        mfs12 @tecno
        @tecno did you reload?
        to be honest i didn't install it just packaged it. so there's a chance things are failing.
        Visit me on github at https://github.com/mfs12/
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @mfs12
          @mfs12
          Yes
          no worries, just reporting what I experience.
          Cheers Bengt
          • mfs12undefined
            mfs12
            thanks. you are right. something is again wrong with the inputshaping algorithm enumeration.
            • mfs12undefined
              mfs12 @tecno
              @tecno said in InputShaping-Plugin-0.1.0-rc7 released:
              Repacked the plugin. It should be fine now.
              • tecnoundefined
                tecno @mfs12
                @mfs12
                Sofar so good 😉
                Looks to be OK need to do some testing.
                Cheers Bengt
                • Blacksheep99undefined
                  Blacksheep99
                  Hi, is there any guidelines for how to set this up? Thanks.
                  • mfs12undefined
                    mfs12
                    @Blacksheep99 I can recommend reading through
                    • https://duet3d.dozuki.com/Wiki/Input_shaping
                    • https://duet3d.dozuki.com/Wiki/Accelerometers
                    Blacksheep99undefined 1 Reply Last reply Reply Quote 0
                      Blacksheep99 @mfs12
                      @mfs12 Thanks. I've read them, but will again. I'm not sure how to interpret the graphs. As in which frequency I then choose for the input shaper.
                      • mfs12undefined
                        mfs12
                        @Blacksheep99
                        • usually you look at the FFT analyzed graph of the recorded profile.
                        • there you find the biggest amplitude which maps to a frequency
                        • this is the target frequency to operate input shaping on
                        Blacksheep99undefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                          Blacksheep99 @mfs12
                          @mfs12 Thanks, that was my assumption but good to have it confirmed.
                            jay_s_uk @mfs12
                            @mfs12 any chance you can indicate what has changed between each RC rather than just lumping the changes in together?
                            • Fred-Yundefined
                              Fred-Y
                              @mfs12 Excellent work, I really like it ☺
                              Some parameters are displayed while there is no compensation - nothing major but it confused me a little, I was unsure if I had an IS configured and miss reported.
                              Generating graphs from multiple records works very well, I spent quite some time tonight playing with it on my Delta!
                              I really like being able to compare the different recordings, that is perfect to try different settings and compare them.
                              Hiding some axis on the graph would useful when we have 3 or more records at the same time
                              I'm going to test it on a CoreXY within the next few days 👍
                              mfs12undefined 1 Reply Last reply Reply Quote 0
                              • mfs12undefined
                                mfs12 @Fred-Y
                                @fred-y thanks for your feedback. basically all of your ideas are going to be implemented in future versions. so stay tuned 😉
                                Fred-Yundefined 1 Reply Last reply Reply Quote 1
                                • Fred-Yundefined
                                  Fred-Y @mfs12
                                  @mfs12 I'm looking forward to test the next releases!
                                  This might be a little off topic: is there a plan to implement a script similar to the one used by Klipper to determine the best frequency / type for IS?
                                  Using the graphs requires some knowledge and analysis, for example the spike at 102Hz on my graph is deceiving as it is not caused by a movement, it exists on a records done with no moves. I suspect it to come from the PSU fan on top of my Delta.
                                  • mfs12undefined
                                    mfs12
                                    @Fred-Y thanks for you help.
                                    Yes, we plan to automate as much as possible. Although i can't tell you yet what is going to be realized.
                                    this is a very good point you are hinting to. To understand such behavior we should records as well the current movement with the accelerations.
                                    Fred-Yundefined shmibbityundefined 2 Replies Last reply Reply Quote 0
                                    • Fred-Yundefined
                                      Fred-Y @mfs12
                                      @mfs12 Thanks for the response.
                                      Let me know if you need any kind of help to test experimental functions or alpha built, I would be happy to support.
                                      My printers are not used for any business purposes so they can be use for troubleshooting and even be put out of service for days.
                                      • shmibbityundefined
                                        shmibbity @mfs12
                                        @mfs12 I'm also interested in an autocalibration feature. Would the right way to go about it be to have the printer oscillate the print head in one dimension at a time with varying accelerations and distances and use the accelerometer data to find how much distance the frame moved as it shook? The largest displacement will indicate what the natural frequency is of the printer frame in the respective axis.
                                        That information could be used to dynamically adjust jerk and acceleration values of the printer before the next move takes place.
                                        NightLonk42undefined shmibbityundefined 2 Replies Last reply Reply Quote 0
                                        • NightLonk42undefined
                                          NightLonk42 @shmibbity
                                          This post is deleted!
                                            NightLonk42
                                            I've tried on the latest RRF beta and 3.3. It's replicated 100% every time.
                                            Duet Mini 5+ Wifi
                                            Toolboard V1.1
                                            BL Touch (in case that matters somehow)~~
                                            m122
                                            RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta3 (2021-08-24 14:08:24) running on Duet 3 Mini5plus WiFi (standalone mode)
                                            Board ID: GJRQ5-V396U-D65J0-40KM8-K013Z-7VUQA
                                            Used output buffers: 3 of 40 (15 max)
                                            Static ram: 102756
                                            Dynamic ram: 107252 of which 28 recycled
                                            Never used RAM 31676, free system stack 200 words
                                            Tasks: NETWORK(ready,11.8%,253) HEAT(notifyWait,0.0%,372) Move(notifyWait,0.0%,338) CanReceiv(notifyWait,0.0%,797) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,346) TMC(notifyWait,0.7%,115) MAIN(running,85.4%,428) IDLE(ready,1.2%,29) AIN(delaying,0.8%,266), total 100.0%
                                            Owned mutexes: WiFi(NETWORK)
                                            Last reset 00:00:19 ago, cause: software
                                            Last software reset at 2021-09-13 22:57, reason: User, GCodes spinning, available RAM 31388, slot 0
                                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                            Error status: 0x00
                                            Aux0 errors 0,0,0
                                            MCU revision 3, ADC conversions started 19343, completed 19341, timed out 0, errs 0
                                            Step timer max interval 750
                                            MCU temperature: min 43.7, current 44.1, max 44.8
                                            Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                            Driver 0: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 70, reads 988, writes 12, timeouts 0, DMA errors 0
                                            Driver 1: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 70, reads 988, writes 12, timeouts 0, DMA errors 0
                                            Driver 2: position 0, standstill, SG min/max 2/2, read errors 0, write errors 1, ifcnt 70, reads 987, writes 12, timeouts 0, DMA errors 0
                                            Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 70, reads 987, writes 12, timeouts 0, DMA errors 0
                                            Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 70, reads 988, writes 12, timeouts 0, DMA errors 0
                                            Driver 5: position 0, assumed not present
                                            Driver 6: position 0, assumed not present
                                            Date/time: 2021-09-13 22:58:05
                                            Cache data hit count 36845245
                                            Slowest loop: 3.99ms; fastest: 0.12ms
                                            === Storage ===
                                            Free file entries: 10
                                            SD card longest read time 3.5ms, write time 0.0ms, max retries 0
                                            DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Bed heaters = 0 -1, chamberHeaters = -1 -1
                                            Heater 1 is on, I-accum = 0.0
                                            Segments left: 0
                                            Movement lock held by null
                                            HTTP is idle in state(s) 0
                                            Telnet is idle in state(s) 0
                                            File is idle in state(s) 0
                                            USB is idle in state(s) 0
                                            Aux is idle in state(s) 0
                                            Trigger is idle in state(s) 0
                                            Queue is idle in state(s) 0
                                            LCD is idle in state(s) 0
                                            SBC is idle in state(s) 0
                                            Daemon is idle in state(s) 0
                                            Aux2 is idle in state(s) 0
                                            Code queue is empty
                                            === CAN ===
                                            Messages queued 193, received 591, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 237, free buffers 17 (min 16), ts 97/96/0
                                            Tx timeouts 0,0,0,0,0,0
                                            === Network ===
                                            Slowest loop: 15.35ms; fastest: 0.00ms
                                            HTTP sessions: 1 of 8
                                            - WiFi -
                                            Network state is active
                                            WiFi firmware version 1.26
                                            WiFi MAC address f0:08:d1:02:e6:b1
                                            WiFi Vcc 3.40, reset reason Power up
                                            WiFi flash size 2097152, free heap 21408
                                            WiFi IP address 192.168.1.29
                                            WiFi signal strength -35dBm, mode 802.11n, reconnections 0, sleep mode modem
                                            Clock register 00002002
                                            Socket states: 0 4 0 0 0 0 0 0
                                            How to replicate:
                                            * -Install InputShaping Plugin (Currently using latest version as of 9/13/21)
                                            * Start it
                                            *No issues whatsoever with homing or G32 happen at this point. Everything is fine*
                                            * Home Printer
                                            * Run mesh compensation (G29)
                                            *A Height Map is saved*
                                            (The height map file is what's causing the bug for whatever reason)
                                            * Reboot printer
                                            *Paneldue will no longer connect and is now stuck at connecting*
                                            * Try to Home Printer
                                            *BL Touch will not deploy and the console throws error messages*
                                            9/13/2021, 10:49:13 PM	Error: in file macro line 17: G30: Z probe 0 not found
                                            Error: G0/G1: insufficient axes homed
                                            9/13/2021, 10:49:11 PM	G28
                                            * Delete heightmap.csv
                                            * Reboot printer
                                            *Everything now works as expected again*~~
                                            gloomyandyundefined 1 Reply Last reply Reply Quote 0
