    Accelerometer Usage
    Beta Firmware
    25
    191
    22.1k
      jay_s_uk
      @tecno if you have a bedslinger, then yes.
      and then use the input shaper plugin to record the results
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @jay_s_uk
        @jay_s_uk
        Yes its my good old Chiron 😉
        Will try to see what I get here.
        • tecnoundefined
          tecno @tecno
          Re ORIENTATION
          As i see this is orientation I20, right?
          If I flip the board so VCC will be to the right upside down is the orientation then I60 ?
          How do handle this in config.g ? 2 lines ?
          M955 P0 I20 C"io3.out+io3.in" ;active
          ;M955 P0 I60 C"io3.out+io3.in" ; not active
          tekkydaveundefined 1 Reply Last reply Reply Quote 0
          • tekkydaveundefined
            tekkydave @tecno
            @tecno Yes 60.
            0 = +X, 1 = +Y, 2 = +Z, 4 = -X, 5 = -Y, 6 = -Z.
            the chip's z will be pointing in printer's -z dir = 6
            the chip's x will be pointing in printer's +x dir = 0
            ~ tekkydave ~
            D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
            FreeCAD, PrusaSlicer
            tecnoundefined 1 Reply Last reply Reply Quote 1
            • tecnoundefined
              tecno @tekkydave
              @tekkydave
              Thanks, just want to be sure.
                tekkydave
                I have finally got my hands on a LIS3DSH. I ordered it from the link supplied above by @dc42
                https://www.ebay.co.uk/itm/272706183865
                Note the 'DSH' on the chip 🙂
                And in DWC:
                ~ tekkydave ~
                • Blacksheep99undefined
                  Blacksheep99
                  I got mine hooked up to the Maestro. Seems to be working. I've had some overruns so need to look at that. I'm not sure what to do with the data from the graphs as yet but reading it seems documentation is coming and the plugin will be updated to support 3.4b3 soon.
                  Does it matter where on the print head gantry I place the sensor? To test I just taped in on top of the extruder assembly.
                    tekkydave
                    @blacksheep99 I have mine mounted on the back plate of the extruder mount. It would benefit from being rigidly mounted rather than taped.
                    ~ tekkydave ~
                    Blacksheep99undefined 1 Reply Last reply Reply Quote 0
                      Blacksheep99 @tekkydave
                      @tekkydave thanks. The tape is just while I know it works. I should be able to design and print a mount for it.
                      • jbarrosundefined
                        jbarros
                        I'm trying to connect accelerometers to my boards and on a 6HC and a Mini 5+ I'm unable to detect it.
                        Tried 3 accelerometers 2x LIS3DSH and 1x LIS3DH and 2 cables, one I built with 100mm and a short version with dupond cables.
                        Wasn't it supposed to receive some message with failure or success?
                        Ex:
                        Error: M955: Accelerometer not found on specified port
                        I get nothing when entering:
                        M955 P0 C"io2.out+io2.in"
                        Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.4.0beta3 (2021-08-24)
                        jbarrosundefined 1 Reply Last reply Reply Quote 0
                        • GeneRisiundefined
                          GeneRisi
                          FWIW, twisted pair wiring is designed to use both wires in the pair. The signals we are carryng are not differential, so try connecting the "other" wire in the pair to ground at both ends of the wiring. You might find that it cleans up the signal quite a bit. I am using CAT5 unshielded cable for both the accelerometer and the Paneldue serial link without any issues (as far as I can tell)
                          • jbarrosundefined
                            jbarros @jbarros
                            @jbarros said in Accelerometer Usage:
                            Ex:
                            I decided to test with 3.3 and I got an answer:
                            Accelerometer 0:0 with orientation 20 samples at 1344Hz with 10-bit resolution
                            I was not getting a response on 3.4b3, either good or bad from M955 but I didn't actually check if data collection was working which it is, so it's just the missing response from M955 that's whacked 🙂
                              @jbarros I'm glad you solved it. The M955 command no longer returns a response if it is successful, just like most other G- and M-code configuration commands
                              • jbarrosundefined
                                jbarros @dc42
                                @dc42 said in Accelerometer Usage:
                                Thanks, I was unaware of that.
                                What is the rationale behind this change?
                                  dc42 administrators @jbarros
                                  It's normal that configuration commands when they succeed do not return a response. You can still get the details by sending M955 with no additional parameters just the P parameter.
                                  • jbarrosundefined
                                    jbarros @dc42
                                    It's normal that configuration commands when they succeed do not return a response. You can still get the details by sending M955 with no additional parameters.
                                    Ok, I get that, I was assuming a response as seen on the other posts and as the accelerometer was ok I also never got an error message (lesson learned, try various situations)
                                    Don't wan't to correct you but M955 needs the P parameter 😊
