    electromagnet for tool dock
    1.3k
    • duttiundefined
      dutti
      hey community,
      I wanna make my tool changing a bit more safety and I wanna install a 24v electro magnet to hold the tools a bit stronger in the dock.
      Does anybody has some experience with it or/and has some ideas how to configure this in config.g?
      should I fan outputs and how to define, that the magnet just hold till the point for letting the tool free?
      datenblatt-502309-intertec-elektromagnet-nicht-magnetisch-stromloser-zustand-20-n-24-vdc-25-w-its-ms-2015-24vdc.pdf
      Thanks a lot to all
      R.
        jay_s_uk
        @dutti i would recommend going for a degauss magnet instead of what you're looking at. They require voltage to release the magnet rather than the other way round. If you require the magnet to be on for a long time, theres a risk of them getting hot
        duttiundefined 1 Reply Last reply Reply Quote 1
        • fcwiltundefined
          fcwilt @dutti
          @dutti
          Perhaps a mechanical lock of some sort that is released by a magnet? No need to keep the magnet always energized.
          duttiundefined 1 Reply Last reply Reply Quote 0
          • duttiundefined
            dutti @jay_s_uk
            @jay_s_uk
            The guy from the magnet shop told me this magnet is not getting hot. I think i give it a try - already bought 2...
            I hope the best
            • duttiundefined
              dutti @fcwilt
              @fcwilt
              the magnet is holding the tool directly. the tool has a small plate.. so in this case it should hold it while it´s not printing.
              I found this which maybe I can take for my own magnet system?
              https://miscsolutions.wordpress.com/2020/06/06/improvements-to-the-hemera-tools/
              Richard
              • fcwiltundefined
                fcwilt @dutti
                @dutti said in electromagnet for tool dock:
                @fcwilt
                Richard
                I understand - it might be a good solution if the power required to hold the tool is not great.
                Just be sure the magnet is rated for continuous power - many have severe duty cycle limits.
                Let us know how it works.
                  @dutti the holding force of that magnet is 20N (about 2kgf) using a 2mm counter plate. Do you need that much force? If you don't, then you may find that a 24V electromagnet powered from 12V is sufficient.
                  • duttiundefined
                    dutti @dc42
                    Yes it's should be 2kg 🙂 but if I really need them... I'm not sure, yet.
                    I'll power them from the mainboard duet 3 or expansion board.
                    I guess I can choose the voltage?
                    What would be the best option to connect it? To the fan outputs?
                    Richard
                      dc42 administrators @dutti
                      Yes.
                      spirit.roboticsundefined 1 Reply Last reply Reply Quote 0
                      • spirit.roboticsundefined
                        spirit.robotics @dc42
                        @dc42 Hello, Im experimented a simmilar soluction for dock tool, Im planning use the Electromagnet with a low PWM frecuency to avoid heating, I have a doubt.
                        In the post about connecting Fans said: "The polarity of the fans is important - don't connect them backwards." but the EM I have have the two cables blue without any polarity, only use 0.2 amps, so the pin could manage it, there is any risky to connect it to the FAN PWM pin? (in another post I wrote about my burned duet, maybe because of this)
                        rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
                        • rjenkinsgbundefined
                          rjenkinsgb @spirit.robotics
                          @spirit-robotics
                          You need to add a diode across the magnet coil to prevent back emf spikes damaging the Duet board.
                          A "flywheel diode" function, in other words; preferably something like a 1A fast recovery or schottky rectifier diode.
                          https://www.elprocus.com/freewheeling-or-flyback-diode-circuit-working-functions/
                          The magnet coil polarity does not matter, but the diode polarity does - it should not be conducting with the normal supply polarity from the PSU or duet.
                          Robert J.
                          Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                            spirit.robotics @rjenkinsgb
                            @rjenkinsgb
                            Thanks, now I know how I burned my duet, I was reading about it, you consider that this diode will work? it is rated 1amp
                            rjenkinsgbundefined dc42undefined 2 Replies Last reply Reply Quote 0
                              @spirit-robotics
                              A 1N4007 is better than nothing, but not ideal - they are a basic rectifier and react quite slowly to changes in polarity (the "reverse recovery" time).
                              As the purpose of the diode is to protect from fast spikes, a fast recovery or schottky diode is much better.
                              A UF4007 (or other UF / UR 400x series) would be fine, likewise any 1A or higher schottky rectifier with a reasonable voltage rating.
                              eg.
                              https://www.amazon.com/Fielect-Rectifier-Rectified-Repetitive-Blocking/dp/B081YX4FZQ/ref=sr_1_12?crid=321AL9ZREAAET&keywords=UF4007&qid=1641541500&sprefix=uf4007%2Caps%2C132&sr=8-12
                              https://www.amazon.com/BOJACK-Recovery-1A1000V-Electronic-Silicon/dp/B07Q4FNZZG/ref=sr_1_2?crid=2OEF4XRG1J1KB&keywords=FR107&qid=1641541663&sprefix=fr107%2Caps%2C135&sr=8-2
                              Or use such as a 1N5819 or 1N5822 out of one of the cheap diode selection packs;
                              https://www.amazon.com/MICSPSF-Assortment-Rectifier-Recovery-Switching/dp/B08VDH8H35/ref=sr_1_6?keywords=1N5819&qid=1641541799&s=industrial&sr=1-6
                              Robert J.
                                dc42 administrators @spirit.robotics
                                @spirit-robotics which Duet do you have, and if it is a Duet 2, what board revision?
                                All duets except older Duet WiFi/Ethernet boards have flyback diodes built in to the fan outputs, so external ones are not needed. Duet 3/3 Mini boards also have flyback diodes built in to all heater outputs except heater 0.
                                If you do need a flyback diode, then as @rjenkinsgb says a fast recovery or Schottky diode is preferred.
                                rjenkinsgbundefined spirit.roboticsundefined 3 Replies Last reply Reply Quote 0
                                  rjenkinsgb @dc42
                                  @dc42 said in electromagnet for tool dock:
                                  That's fine, as long as the power to whatever is connected also comes from the same connector.
                                  If by chance you use a separate positive supply and only switch the ground via the fan output, I'd consider an external flywheel diode to still be essential.
                                  ps.
                                  @dc42 - that rings a bell - another thread, someone having fan outputs fail, when using a separate positive feed?? I wonder if back EMF could be a cause?
                                  Robert J.
                                    rjenkinsgb
                                    Also, on a related subject -
                                    having a flywheel diode (or snubber etc. depending on the load) close to the load itself means the flywheel current or voltage spike is not passed along the connecting wires through the machine, which reduces the chance of interference with other signals.
                                    It's unrelated to damage to the electronics, but just good practice.
                                    Robert J.
                                      rjenkinsgb @dc42
                                      Thinking further on the external supply situation:
                                      You may need to update the board info and tell users not to use external supplies at a higher voltage than the onboard output is set to, on outputs with flywheel diodes.
                                      With a higher external supply to a load, the built-in flywheel diodes will presumably provide a direct path from that to the internal supply, when the output switch is off?
                                      Robert J.
                                        @dc42 My Duet are the lasted version v 1.04.
                                        Output M115:
                                        RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
                                        About the diodes, they are always active? I supposed it is. In anycase how could be the circuit to put the diode? Thanks
                                          @spirit-robotics the diode will be active if the fan voltage select jumper is installed. As @rjenkinsgb says, the external solenoid supply voltage must be no higher than the selected voltage on the fan jumper (normally VIN).
                                            @rjenkinsgb Today I connect the board by USB and work fine, and connect a 5V FAN in the always ON fan and the fan work well.
                                            However Im little worried if I try to connect the electromagnet, maybe the reason of the shortcut is different...
                                            Just to understand, confirm ... in a board V1.04 I have the flyback diodes in place with the fans, so, in theory if I connect to the PWM Fan pin a small electromagent should be work?
                                            The Electromagent, rated for 12V 0.2amps, but connected to the 5V pwn fan pin only need 0.09 amps ... could be work?
