    How to connect two 24V PSUs?
    18
    630
    • cosmowaveundefined
      cosmowave @o_lampe
      @o_lampe If your MosFET (and Fuse) allow to deliver 300W, then it should be possible to connect the GND's of the two PSU's (need a prober Wire!).
      Then connect the heatbed between the second PSU+ and the MosFET- (Bed- on board)
      I'm not 100% sure if this will work!!
      Mankati FSXT+, DeltaTowerV2, E3D MS/TC
      o_lampeundefined 1 Reply Last reply Reply Quote 1
      • o_lampeundefined
        o_lampe @cosmowave
        @cosmowave
        That was also my idea.
        But I'm not sure how PID tuning would work then? Vin of the bed is unknown...
        cosmowaveundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
          cosmowave @o_lampe
          @o_lampe said in How to connect two 24V PSUs?:
          But the two Vin's should not be very different..
          Do you need a very accurate PID tuning for the bed?
          • PaulHewundefined
            PaulHew
            Personally, I would err on the side of caution.
            For approx £18, I would go with a DC-DC SSR. (Yes I did read that you did not want to use one! 😉 )
            cosmowaveundefined 1 Reply Last reply Reply Quote 0
              cosmowave @PaulHew
              @paulhew @o_lampe Yes for sure, a SSR would be the best option.
              Pickettundefined 1 Reply Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @o_lampe
                Well on my printers I have 120 VAC bed heaters controlled by AC SSRs.
                PID works fine even though Vin is not used for heating.
                • Pickettundefined
                  Pickett @cosmowave
                  @cosmowave Hello may I join in and humbly ask if it is possible to power the silicone heater pad with a mosfet or does it need to be a SSR? Ive read that a SSR is a MOSFET in a fancier package? Ive got zero problems getting a good SSR cause Im planning on getting a 400mm X 400mm Silicne Heater Pad for my Anycubic Chiron 3.0 build powered by a D3M5+ of course so am curious as to what is the deal with the SSR vs the MOSFET for the purpses of heating the bed or nozzle for that matter. TIA!!!
                  cosmowaveundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                    cosmowave @Pickett
                    @pickett You can power your bed with a suitable mosfet. That's possible.
                    If you'd like to use a AC bed-heater then a SSR will switching allways at 0 volts. So you have no "switching peaks"
                    Sorry, my english is not good enough to explain it better!
                    • o_lampeundefined
                      o_lampe @Pickett
                      @pickett If your heater needs higher voltage than the Duet3 is rated for, you need an external switcher.
                      A dc/dc ssr is an array of Mosfet, but for AC you'd need an AC-SSR.
                      • Dougal1957undefined
                        Dougal1957 @o_lampe
                        You do need to be careful with DC-DC SSR's due to there on resistance (most of the cheaper ones use Triacs I think and tend to have a quite high Volts drop which leads too a lot of energy being lost in the SSR itself) IMHO a good Mosfet is the preferred for a DC bed and a Zero Crossing SSR for AC Beds.
                        • Pickettundefined
                          Pickett @Dougal1957
                          @dougal1957 thanks sorry for the late reply as I had been really busy with the kids. Anywho I am seeing some Zero Crossing SSR's and I guess I need to educate myself a bit more on SSR's in general. Ive found one by Uxcell but it is only 12.95 USD which is definitely a good price and a lot of the reviews are great but if there is anything Ive learned about great reviews on Amazon doesnt always mean they are real but these do sound authentic from a lot of different users. Anyways the SSR I have spoken about is an DC to AC SSR as the Silicone Heater Pad Im going to buy is a 120v AC bed which I know will work terrificly and can hardly wait to get it as Im finishing up my build of my Anycubic Chiron with a Duet 3 Mini 5+ and other nice components though with most things in life there are even nicer components than the ones Ive got to be had but that is life I guess or me anyways always wanting something bigger and badder lols. So is the Zero Crossing SSR an AC to AC SSR?
                          Dougal1957undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                            Dougal1957 @Pickett
                            @pickett zero crossing just means that it switches the AC output att the zero points of the wave form so it applies to any SSR that switches an AC Load (so DC-AC sir's) I have never seen a AC-AC one tbh not that that means they don't exist I just don't know.
                            Pickettundefined 1 Reply Last reply Reply Quote 1
                              Phaedrux Moderator @Pickett
                              @pickett said in How to connect two 24V PSUs?:
                              I would say that is overpriced.
                              Take a look here: https://www.auberins.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=ssr
                              There is a range of AC and DC SSRs in a range of power ratings and they don't cost a fortune.
                              • Pickettundefined
                                Pickett @Dougal1957
                                @dougal1957 yeah wow I guess an AC to AC SSR would be not only redundant but dumb lols "hey let me get a plate for my hamburger and a plate for the buns to sit on so I can eat a hamburger wrapped in wax papers lols!!!!!!!" ok ok sorry I didnt realize what I said til you said something lols its all good anyways ok thanks man I appreciate the bit of info I really do!!!!
                                • Pickettundefined
                                  Pickett @Phaedrux
                                  @phaedrux thanks man Ill look into that and see what I can come up with over here in the US Market thank you though I really appreciate it I really do!!!!
                                    Auber Instruments is US based. Georgia I believe.
                                    • weed2allundefined
                                      weed2all @o_lampe
                                      @o_lampe for a dc heatbed I would probably go for a external mosfet...this way you have a dedicated psu for your heatbed and a seccond psu for everything else...in any case I use alot this type of mosfet powering the heatbed just because is cheap ro buy 2 psu with lower watts(24v 350w) than to buy a bigger psu(24v 600/700w to meet all the power drain requirements)
                                      https://m.banggood.com/3PCS-60+50mm-Hot-Bed-Power-Module-Expansion-MOS-Tube-For-3D-Printer-p-1272663.html?utm_source=googleshopping&utm_source=googleshopping&utm_medium=cpc_organic&utm_medium=cpc_bgs&gmcCountry=PT&utm_content=minha&utm_content=dcr&utm_campaign=minha-pt-en-mb&utm_campaign=dcr-ssc-pt-en-newcustom-ncv65-0720&currency=EUR&cur_warehouse=CN&createTmp=1&ad_id=534534084655&gclid=Cj0KCQjwkIGKBhCxARIsAINMioJpFBfRNwRKoGiy9kqHrrPNd-pPVbN9NGLfFDIM7ZsvrQiMCRCqv1AaAo1xEALw_wcB
                                      https://www.thingiverse.com/weed2all/designs
