    3.4.0 b3 leaning prints
    Beta Firmware
    9
    43
    2.4k
      T3P3Tony administrators @Adrian52
      @adrian52 ok thanks. I will try and do the same. are your test cubes hollow or with infil? are you using input shaping?
      Adrian52undefined 2 Replies Last reply Reply Quote 0
      • Adrian52undefined
        Adrian52 @T3P3Tony
        @t3p3tony I used 10% gyroid infill, and ei3 input shaping
          jay_s_uk @dc42
          @dc42 I have some more to add to the theory
          Both cubes are printed with 3.4b3.
          The right hollow cube is printed in vase mode.
          The left hollow cube was printed as a single wall. This one had a z hop setting of 1mm
          I am currently printing the same gcode with no z hop and it is not exhibiting the same leaning in Y.
          here is my config
          ; Configuration file for Fly-E3-Pro (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.2.1-LPC+17 on Wed Jun 30 2021 09:24:28 GMT+0100 (British Summer Time)
          G90                                            ; send absolute coordinates...
          M83                                            ; ...but relative extruder moves
          M550 P"Predator"                             ; set printer name
          M665 R227 L450 B185 H400                       ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0                                  ; put your endstop adjustments here, or let auto calibration find them
          M552 S1                                        ; enable network
          M586 P0 S1                                     ; enable HTTP
          M586 P1 S0                                     ; disable FTP
          M586 P2 S0                                     ; disable Telnet
          M569 P0 S1                                    ; physical drive 0 goes forwards using TMC2209 driver timings
          M569 P1 S1                                     ; physical drive 1 goes forwards using TMC2209 driver timings
          M569 P2 S1                                     ; physical drive 2 goes forwards using TMC2209 driver timings
          M569 P3 S1                                     ; physical drive 3 goes forwards using TMC2209 driver timings
          M584 X0 Y1 Z2 E3                               ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
          M92 X160.00 Y160.00 Z160.00 E415.00               ; set steps per mm
          M566 X500.00 Y500.00 Z500.00 E1000.00       ; set maximum instantaneous speed changes (mm/min) next try 3000
          M203 X9000.00 Y9000.00 Z9000.00 E10000.00    ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E3000.00       ; set accelerations (mm/s^2) next try 6000
          M906 X1344 Y1344 Z1344 E560 I30                ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                        ; Set idle timeout
          M208 Z0 S1                                     ; set minimum Z
          M574 X2 S1 P"e1stop"                           ; configure active-high endstop for high end on X via pin e1stop
          M574 Y2 S1 P"pson"                             ; configure active-high endstop for high end on Y via pin pson
          M574 Z2 S1 P"e0stop"                           ; configure active-high endstop for high end on Z via pin e0stop
          M558 P8 C"probe" H5 R0.4 F1200 T6000 A9                ; set Z probe type to switch and the dive height + speeds
          G31 P100 X0 Y0 Z-0.1                           ; set Z probe trigger value, offset and trigger height
          M557 R180 S20                                  ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"e1heat" T0                           ; create bed heater output on e1heat and map it to sensor 0
          M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                        ; map heated bed to heater 0
          M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8  ; configure sensor 1 as thermistor on pin e0temp
          M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
          M308 S2 P"boardtemp" Y"thermistor" T100000 B4092
          M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
          M563 P0 D0 H1 F0                               ; define tool 0
          G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
          G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
          M207 S4.0 F2400 Z1
          M572 D0 S0.4
          M955 P0 C"B.1+E.8" I50
          M501
          T0                                             ; select first tool
          I should add that I am using no form of input shaping but I am using PA
            dc42 administrators @jay_s_uk
            @jay_s_uk that's interesting! Is the Z hop configured using M207 and firmware retraction, or in the slicer?
              jay_s_uk @dc42
              @dc42 using M207.
              The gcode files are the same.
              I changed it to 0 using M207 from the console and checked it to ensure it had changed
                @jay_s_uk thanks. Please share the GCode, and I will try it on my delta with Z hop this afternoon.
                  jay_s_uk @dc42
                  @dc42 cube.gcode
                  • Adrian52undefined
                    Adrian52 @T3P3Tony
                    @t3p3tony have now tried the two cubes without infill, without input shaping, with z hop=0, and with pa=0, and the slope in the - y direction is the same.
                    jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                      jay_s_uk @Adrian52
                      @adrian52 so its not z hop.
                      that just adds to the complexity then
                      • CabalSoulundefined
                        CabalSoul
                        Here is my config and the example gcode. All my prints were printed in vase mode, no Z hop configured for PETG.
                        AAP_ringing.gcode
                        AAP_Dynamic_Acceleration_Adjustment.gcode
                        G90                                         				; Send absolute coordinates...
                        ; Delta Settings
                        M665 L440.000:440.000:440.000 R227.102 H449.038 B185.0 X-0.233 Y0.113 Z0.000
                        M666 X-0.220 Y0.388 Z-0.169 A0.00 B0.00
                        M550 P"Apex Predator"                     		               	; Set machine name
                        M552 S1
                        M586 P0 S1                                  				; Enable HTTP
                        M586 P1 S0                                  				; Disable FTP
                        M586 P2 S0                                  				; Disable Telnet
                        M569 P0 S1                                  				; Drive 0 goes forwards
                        M569 P1 S1                                  				; Drive 1 goes forwards
                        M569 P2 S1                                  				; Drive 2 goes forwards
                        M569 P3 S0                                  				; Drive 3 goes forwards
                        ;Stepper Configuration
                        M350 X16   Y16   Z16    E16  I1								; Configure microstepping with interpolation
                        M92  X160  Y160  Z160   E679								; Set steps per mm Orbiter greentec E689 @1mm 679 nonlinear
                        M906 X1800 Y1800 Z1800 E550 I11 							; Set motor currents (mA) and motor idle factor in per cent
                        ;Normal Speed
                        M566 X900  Y900  Z900  E1200     	      	   		          		; Set JERK(mm/min)
                        M201 X6000  Y6000  Z6000  E3600 	   						; Set accelerations (mm/s^2)
                        M203 X30000 Y30000 Z30000 E15000							; Set maximum speeds (mm/min) 18k is 300mm/s
                        M204 P3000 T6000									; set Print accel and travel accel
                        M208 Z0 S1                                  				; Set minimum Z
                        M574 X2 S1 P"xstop"						; configure active-high endstop for high end on X via pin xstop
                        M574 Y2 S1 P"ystop"                                 		; configure active-high endstop for high end on Y via pin ystop
                        M574 Z2 S1 P"zstop"                                 		; configure active-high endstop for high end on Z via pin zstop
                        ;Display
                        M575 P1 S0 B57600
                        ; Z-Probe micro switch
                        M558 P5 C"^e0stop" H2 F460 T12000 A6                  	  	; Set Z probe type to switch and the dive height + speeds  3 Probe Iterations
                        G31  P500 X0 Y0 Z20.567		                 				; Set Z probe
                        M557 R175 S30	                              				  ; Define mesh grid
                        ;Super PINDA
                        ;M558 P5 C"^exp.e2stop" H2 F460 T9000 A3
                        ;G31  P500 X0 Y-32.750 Z1.775
                        ;M557 R165 S30
                        ;Dial Gauge
                        ;M558 P0
                        ;G31  P500 X0 Y0 Z15
                        ;M557 R165 S30
                        ;Filament Sensor
                        M591 D0 P2 C"e1_stop" S1														;activate Filament Sensor S0 for deactivating
                        ; Bed Heater
                        M308 S0 A"Ultrabase Pro" P"bedtemp" Y"thermistor" T100000 B4300 C0 R4700		; Set thermistor + ADC parameters for heater 0
                        M950 H0 C"bedheat" Q250 T0                      			         			; create bed heater output on bedheat and map it to sensor 0
                        M307 H0 B0 R0.376 C428 D1.14 S1.00 V24.1										; Disable bang-bang mode for the bed heater and set PWM limit
                        M140 H0 P0																		; Create bed Heater
                        M143 H0 S125 A0 C0
                        ; Extruder Heater
                        M308 S1 A"Mosquito Hybrid" P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8  H0 L0				; Temperature Sensor
                        ;M308 S1 A"Mosquito Hybrid" P"e0temp" Y"thermistor" T4606017 B5848 C5.548428e-8 R4700 H0 L0	    ; blue sensor
                        M143 H1 S280 A0                               											    	; Set temperature limit for heater 1 to 280C
                        M307 H1 B0 R3.324 C137.4 D5.67 S1.00 V24.3           											; Disable bang-bang mode for the Hotend and set PWM limit
                        M570 H1 P15 T15 S120
                        ;Additional Sensors
                        M308 S2 A"Chamber" P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8						; define Chmaber temperature sensor
                        ;M308 S10 P"spi.cs6" Y"dht22"       A"Filament Temperature" 					        ; define DHT22 temperature sensor DATA Pin on E3_Stop
                        ;M308 S11 P"S10.1"   Y"dhthumidity" A"Filament Humidity[%]" 					    	; Attach DHT22 humidity sensor to secondary output of temperature sensor
                        M955 P0 S1000 C"spi.cs3+spi.cs4" 														; Accelerometer
                        ; Hotend Fan
                        M950 F1 C"fan1" Q100                        	   			;HOTEND FAN create fan 1 on pin fan1 and set its frequency
                        M106 C"HotendFAN" P1 H1 L1 T45                            	; set fan 1 value. Thermostatic control is turned on
                        ;Part Cooling Fan
                        M950 F0 C"!fan0+^exp.pb6" Q24000 							;CPAP create fan 0 on pin fan0 and set its frequency !fan2+exp.pb6 Q24000
                        M106 C"CPAP" P0 S0 H-1        								; set fan 0 value. Thermostatic control is turned off L0.3 X1
                        M563 S"NF crazy" P0 D0 H1                           		; Define tool 0
                        G10 P0 X0 Y0 Z0                             				; Set tool 0 axis offsets
                        G10 P0 R0 S0                                				; Set initial tool 0 active and standby temperatures to 0C
                        T0															; select Tool 0
                        ;Extrusion settings
                        M207 S2.5 F3600 R0 T2800 Z0 								       ;Retraction
                        M572 D0 S0.1													;Pressure Advance
                        ;standard settings
                        M593 P"ei3"  F41.4											;F Resonance Frequency
                        ;M593 P"daa"  F41.5
                        M703														;Load filament config
                        M501														;load config-override
                        Anycubic Predator, Orbiter Extruder , Duet Wifi, Mosquito Hotend, Remote Extruder Stepper cooling and Part cooling
                          T3P3Tony administrators @CabalSoul
                          @cabalsoul thanks. so I have managed to get a lean on "simpler" boxes printed as @Adrian52 suggested, offset in the +/- Y direction. (using gyroid infil and el3 input shaping)
                          Has anyone observed sloping in any direction other than -Y ?
                          CabalSoulundefined jay_s_ukundefined Fred-Yundefined 3 Replies Last reply Reply Quote 0
                            CabalSoul @T3P3Tony
                            @t3p3tony In my case always -Y.
                            If i rotate the object it doesn't change anything.
                              jay_s_uk @T3P3Tony
                              @t3p3tony in my case it is also always in -y and happens regardless of position on the build plate
                              • Fred-Yundefined
                                Fred-Y @T3P3Tony
                                @t3p3tony It seems that I got one of my prints leaning on both -X and +Y
                                On this picture it is leaning on the left and also back.
                                I spent quite some time today trying to reproduce the issue on simple objects like basic cubes, calibration cubes, ringing test with and without infill (rectilinear, gyroid...) but all seems fine.
                                I guess I changed something on SuperSclicer 😑 ... I even checked I was still on the beta3.
                                  T3P3Tony administrators @Fred-Y
                                  @fred-y thanks for spending the time in testing this - it helps!
                                  I will test to see if I can get a lean with the two box prints arranged in different orientations then looking for anything on +/-X
                                  • Adrian52undefined
                                    Adrian52
                                    With a 20mm cube and a 20x20x10high cube offset in the y direction printed together, the 20mm cube (on the right) looks like this
                                    undefined
                                    The left cube for comparison printed with no y offset. You can see that the lean reduces after 10mm, but interestingly a smaller lean is still seen. Havent tried a 45deg rotated cube yet.
                                      dc42 administrators @Adrian52
                                      Thanks to everyone who has helped us to try to track this down. @chrishamm has managed to reduce one of your leaning prints to a pair of 2 moves that leaves one of the carriages 2 microsteps away from the correct position. I expect to be able to track down the problem now.
                                      dc42undefined 1 Reply Last reply Reply Quote 5
                                        dc42 administrators @dc42
                                        @Adrian52 @CabalSoul @DaveA @Fred-Y @jay_s_uk @SIam I have put new firmware builds with a fix for the issue I was eventually able to reproduce at https://www.dropbox.com/sh/kgah0ylh2zu2f7w/AAD2vQOiTQrFly1p22sob6c7a?dl=0. As with all unofficial builds, use them with care.
                                        CabalSoulundefined jay_s_ukundefined DaveAundefined Fred-Yundefined 4 Replies Last reply Reply Quote 0
                                          CabalSoul @dc42
                                          @dc42 thank you exactly what I needed. I am going to test right away.
                                          I've tested it and it seems to work. Thanks again.
                                            jay_s_uk @dc42
                                            @dc42 one print completed so far and no leaning!
                                            What was it in the end?
                                            Blacksheep99undefined dc42undefined 2 Replies Last reply Reply Quote 0
