    Custom image on PanelDue main pages
    Firmware developers
    custom firmware paneldue
    1.4k
    • mfs12undefined
      mfs12
      @Nil-Orbach sorry, i don't have an idea. i could imagine you can easily patch bmp2c tool.
      Visit me on github at https://github.com/mfs12/
      Nil Orbachundefined 1 Reply Last reply Reply Quote 0
      • Nil Orbachundefined
        Nil Orbach @mfs12
        Thanks anyway for your kindly help, @mfs12 πŸ™‚
        Actually, I have just answered my second question about the color palette by reading the bmp2c.go file. I found in the function getPaletteIndex() the following corresponding table :
        switch to16BitColor(r, g, b, a) {
        case 0xffff: // e.g. 0xffffff
        	return 1
        case 0x20e4: // e.g. 0x201c20
        	return 2
        case 0xffdf: // e.g. 0xf8f8f8
        	return 3
        case 0x18e3: // e.g. 0x181c18
        	return 4
        case 0xf79e: // e.g. 0xf0f0f0
        	return 5
        case 0xc986: // e.g. 0xc83030
        	return 6
        case 0xd30c: // e.g. 0xd06060
        	return 7
        case 0xc103: // e.g. 0xc02018
        	return 8
        case 0xff52: // e.g. 0xf8e890
        	return 9
        case 0xfffb: // e.g. 0xf8fcd8
        	return 10
        case 0x4569: // e.g. 0x40ac48
        	return 11
        case 0x9492: // e.g. 0x909090
        	return 12
        default:
        	return 0
        So, for anyone interested, when you read for example 0x01 in the IconHomeAll array in HomeIcon.cpp, it means that the first bit color is black (0 is default, i.e. black) and that the second bit color is white (1 is 0xFFFF, i.e. white), as there is 2 pixels/bit.
        I am looking for coding my image in 16 bits to use the StaticImageField() function and will let you know when (if!) I succeed.
        • mfs12undefined
          mfs12
          @Nil-Orbach can you share a photo of your result. I would be interested.
            Nil Orbach @mfs12
            @mfs12 Hello,
            Unfortunately, I did not manage to display my image with StaticImageField(). I have tried to convert my uin8_t icon into a uin16_t one by converting, for example, 0x13 into 0xffff, 0xffdf, then into 0x0000, 0x0003, with then without the height and width at the beginning of the array, but none of this has ever worked. Depending of what I test, I get a white square, or a black one with some blue, etc. - but not my image!
            Actually, the function called by StaticImageField() is drawCompressedBitmap(), which is almost the same function than drawCompressedBitmapBottomToTop() which is used to display the splash screen. Both take a uin16_t array of data as argument. If I could know how is coded the splash screen after the bmp2c tool is used, I could maybe try to code my image the same way. But, as I am not familiar with the go functions used in bmp2c.go, I do not really understand what computation is performed on the initial 24 bits bmp image.
            Or maybe the StaticImageField() or drawCompressedBitmap() functions have some error - it is hard to tell as they are never used in the code...
              dc42 administrators @Nil Orbach
              @nil-orbach the code to display the splash screen used to call DrawCompressedBitmap before I added DrawCompressedBitmap BottomToTop, so that function certainly used to work.
              The format is very simple:
              • 1 word (16 bits) repeat count minus one (so 0 means that the following pixel is displayed just once, 1 means it is displayed twice etc.)
              • 1 word (16 bits) pixel colours in 565 format (e.g. 5 bits red, 6 bits green, 5 bits blue)
              • Repeated as necessary
                Nil Orbach @dc42
                @dc42 Hello, thanks for your help. I really appreciate it!
                After reading your post, I generated a binary file from my 24-bit bmp image with the bmp2c tool. Then, I opened the binary file with a binary editor (Hex Neo Editor) and I displayed all the data as hex words (16 bits). Finally, I copied these words into my uint16_t array and called this array with the StaticImageField() function. As you said, I get the format you described: width, height, and then repeat byte followed by a pixel byte. But I still get something wrong: a white square with black lines (like a bar code - definitely not my image!).
                Did I make something wrong during the process?
                And by the way, thanks for the hard work you put into the Duet project! πŸ™‚
                • mfs12undefined
                  mfs12
                  @Nil-Orbach use the splash screen for initial testing. Then try to create your image.
                    Nil Orbach @mfs12
                    @mfs12 I can successfully change the splash screen with the bmp2C tool. Here are some photos to illustrate my problem:
                    First, the splash screen (this one is just a random image for the example) :SplashScreenCNC.jpg
                    And now, the same image displayed with the StaticImageField() function, after following the procedure described in my previous message:ImageCNCFailure.jpg
                    (The screen may look unfamiliar, as I have already customized and removed some buttons πŸ™‚ )
                    So, I think my array is good, but I may miss something when calling the StaticImageField()...
                    Here is how I call this function: mgr.AddField(new StaticImageField(row3, DISPLAY_X - 270, 120, 131, ImageCNC)); //height = 120, width = 131
                    And my ImageCNC array is: extern const uint16_t ImageCNC[] = { 131, 120, 0x0292, 0xffff, 0x0000, 0xef5d, 0x0000, 0xd69a, 0x0071, 0xd6ba, 0x0000, 0xe6fb, 0x000d, 0xffff, 0x0000, 0x7bef, 0x0072, 0x0000, 0x0000, 0x39e7, etc. }
                    • mfs12undefined
                      mfs12
                      @Nil-Orbach sorry, my ressources are limited i can't assist you on that. But hope you will succeed.
                      It really looks like the mapping is not yet correct. Does the image fit the dimensions you want to draw? I would expect they need to be accurate.
                        Nil Orbach @mfs12
                        @mfs12 I keep looking for what may be wrong. I hope I succeed too so that it will help those who could face the same problem in the future πŸ™‚
                        The image dimensions are good. Here is the same image displayed as a button, with the AddIconButton() function and an uint8_t array of my image generated with the bmp2c tool thanks to your first message:
                        The button is large, but the image dimensions are the same than those displayed with the StaticImageField() function.
                        Anyway, thanks for your help, that was very kind! πŸ™‚
                        • mfs12undefined
                          mfs12
                          @Nil-Orbach can we close this topic as solved?
                            Nil Orbach
                            @mfs12 Hi, actually it was not really solved, but as nobody seems to know the answer, I guess you can close it πŸ™‚
                            • mfs12undefined
                              mfs12
                              @Nil-Orbach check the drawing function of the button. Finally it should be the same as for images.
                                Nil Orbach @mfs12
                                @mfs12 these functions are not exactly the same. The button function calls drawBitmap4() which then calls LCD_Write_Repeated_DATA16() whereas image function calls drawCompressedBitmap() which then calls LCD_Write_DATA16(). These functions may look similar, but I do not think I will explore that further. I will let my image as a button, it is not that bad!
                                • mfs12undefined
                                  mfs12
                                  @Nil-Orbach so this seems to be your problem then. Your image does not have the right format.
                                  And which function does the splash screen use?
                                    Nil Orbach @mfs12
                                    @mfs12 According to what dc42 said, my image has the right format. dc42 said:
                                    "The format is very simple:
                                    • word (16 bits) repeat count minus one (so 0 means that the following pixel is displayed just once, 1 means it is displayed twice etc.)
                                    • word (16 bits) pixel colours in 565 format (e.g. 5 bits red, 6 bits green, 5 bits blue)
                                    • Repeated as necessary"
                                    This is exactly what I got after using the bmp2c -binary command, and after opening this binary file with a binary editor and copying the uint16_t hex code into my code so that the StaticImageField() method can display it by calling drawCompressedBitmap().
                                    Here is the splash screen format:
                                    And here is my image format in the code:
                                    They are the same!
                                    Concerning the splash screen, it is called with drawCompressedBitmapBottomToTop(0, 0, DISPLAY_X, DISPLAY_Y, _esplash + 2).
                                    • mfs12undefined
                                      mfs12
                                      Moved to developer's forum.
