    Custom image on PanelDue main pages
    Firmware developers
    custom firmware paneldue
    1.4k
    • Nil Orbachundefined
      Nil Orbach @dc42
      @dc42 Hello, thanks for your help. I really appreciate it!
      After reading your post, I generated a binary file from my 24-bit bmp image with the bmp2c tool. Then, I opened the binary file with a binary editor (Hex Neo Editor) and I displayed all the data as hex words (16 bits). Finally, I copied these words into my uint16_t array and called this array with the StaticImageField() function. As you said, I get the format you described: width, height, and then repeat byte followed by a pixel byte. But I still get something wrong: a white square with black lines (like a bar code - definitely not my image!).
      Did I make something wrong during the process?
      And by the way, thanks for the hard work you put into the Duet project! 🙂
      • mfs12undefined
        mfs12
        @Nil-Orbach use the splash screen for initial testing. Then try to create your image.
        Visit me on github at https://github.com/mfs12/
        Nil Orbachundefined 1 Reply Last reply Reply Quote 0
          Nil Orbach @mfs12
          @mfs12 I can successfully change the splash screen with the bmp2C tool. Here are some photos to illustrate my problem:
          First, the splash screen (this one is just a random image for the example) :SplashScreenCNC.jpg
          And now, the same image displayed with the StaticImageField() function, after following the procedure described in my previous message:ImageCNCFailure.jpg
          (The screen may look unfamiliar, as I have already customized and removed some buttons 🙂 )
          So, I think my array is good, but I may miss something when calling the StaticImageField()...
          Here is how I call this function: mgr.AddField(new StaticImageField(row3, DISPLAY_X - 270, 120, 131, ImageCNC)); //height = 120, width = 131
          And my ImageCNC array is: extern const uint16_t ImageCNC[] = { 131, 120, 0x0292, 0xffff, 0x0000, 0xef5d, 0x0000, 0xd69a, 0x0071, 0xd6ba, 0x0000, 0xe6fb, 0x000d, 0xffff, 0x0000, 0x7bef, 0x0072, 0x0000, 0x0000, 0x39e7, etc. }
          • mfs12undefined
            mfs12
            @Nil-Orbach sorry, my ressources are limited i can't assist you on that. But hope you will succeed.
            It really looks like the mapping is not yet correct. Does the image fit the dimensions you want to draw? I would expect they need to be accurate.
              Nil Orbach @mfs12
              @mfs12 I keep looking for what may be wrong. I hope I succeed too so that it will help those who could face the same problem in the future 🙂
              The image dimensions are good. Here is the same image displayed as a button, with the AddIconButton() function and an uint8_t array of my image generated with the bmp2c tool thanks to your first message:
              The button is large, but the image dimensions are the same than those displayed with the StaticImageField() function.
              Anyway, thanks for your help, that was very kind! 🙂
              • mfs12undefined
                mfs12
                @Nil-Orbach can we close this topic as solved?
                  Nil Orbach
                  @mfs12 Hi, actually it was not really solved, but as nobody seems to know the answer, I guess you can close it 🙂
                  • mfs12undefined
                    mfs12
                    @Nil-Orbach check the drawing function of the button. Finally it should be the same as for images.
                      Nil Orbach @mfs12
                      @mfs12 these functions are not exactly the same. The button function calls drawBitmap4() which then calls LCD_Write_Repeated_DATA16() whereas image function calls drawCompressedBitmap() which then calls LCD_Write_DATA16(). These functions may look similar, but I do not think I will explore that further. I will let my image as a button, it is not that bad!
                      • mfs12undefined
                        mfs12
                        @Nil-Orbach so this seems to be your problem then. Your image does not have the right format.
                        And which function does the splash screen use?
                          Nil Orbach @mfs12
                          @mfs12 According to what dc42 said, my image has the right format. dc42 said:
                          "The format is very simple:
                          • word (16 bits) repeat count minus one (so 0 means that the following pixel is displayed just once, 1 means it is displayed twice etc.)
                          • word (16 bits) pixel colours in 565 format (e.g. 5 bits red, 6 bits green, 5 bits blue)
                          • Repeated as necessary"
                          This is exactly what I got after using the bmp2c -binary command, and after opening this binary file with a binary editor and copying the uint16_t hex code into my code so that the StaticImageField() method can display it by calling drawCompressedBitmap().
                          Here is the splash screen format:
                          And here is my image format in the code:
                          They are the same!
                          Concerning the splash screen, it is called with drawCompressedBitmapBottomToTop(0, 0, DISPLAY_X, DISPLAY_Y, _esplash + 2).
                          • mfs12undefined
                            mfs12
                            Moved to developer's forum.
