    Vivedino Troodon Board (non-working w/RRF >=3.1).
    Other control boards
    9
    39
    3.4k
    • gloomyandyundefined
      gloomyandy @oliof
      @oliof Can you check the m122 output while you are getting the warning to see if the driver status shows a similar message. Was it the same config.g file for both 3.0 and 3.x (x>=1)?
      • oliofundefined
        oliof @gloomyandy
        @gloomyandy yes, the same config.g as posted above. I will do some more testing tomorrow.
        • oliofundefined
          oliof
          Here are some photos of the bigfoot stepper modules, the last one with an overlay of the 2660 pinout courtesy of Chase Daigle.
          • oliofundefined
            oliof
            @gloomyandy here's an M122 after an attempted X move:
            	M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
            Board ID: 0JD0M-9P6M2-NW4SD-6J9D8-3S86Q-9APHL
            Used output buffers: 3 of 24 (24 max)
            Static ram: 23876
            Dynamic ram: 79464 of which 0 recycled
            Never used RAM 11076, free system stack 150 words
            Tasks: NETWORK(ready,6.6%,249) HEAT(delaying,0.0%,342) Move(notifyWait,0.1%,323) DUEX(notifyWait,0.0%,24) MAIN(running,93.3%,415) IDLE(ready,0.0%,29), total 100.0%
            Owned mutexes: WiFi(NETWORK)
            Last reset 00:02:48 ago, cause: power up
            Last software reset at 2021-10-05 18:04, reason: User, GCodes spinning, available RAM 11076, slot 2
            Error status: 0x04
            Step timer max interval 0
            MCU temperature: min 25.0, current 25.8, max 25.9
            Supply voltage: min 24.2, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: position 800, standstill, SG min/max not available
            Driver 1: position 0, standstill, SG min/max not available
            Driver 2: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
            Driver 3: position 0, standstill, SG min/max not available
            Driver 4: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
            Driver 5: position 0, standstill, SG min/max not available
            Driver 6: position 0, standstill, SG min/max not available
            Driver 7: position 0, standstill, SG min/max not available
            Driver 8: position 0, standstill, SG min/max not available
            Driver 9: position 0, temperature-shutdown! short-to-ground, standstill, SG min/max not available
            Driver 10: position 0
            Driver 11: position 0
            Date/time: 2021-10-06 07:19:47
            Slowest loop: 4.21ms; fastest: 0.70ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 0.4ms, write time 0.0ms, max retries 0
            DMs created 83, maxWait 145255ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 2, completed moves 2, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === DueX ===
            Read count 0, 0.00 reads/min
            === Network ===
            Slowest loop: 199.91ms; fastest: 0.08ms
            HTTP sessions: 1 of 8
            - WiFi -
            Network state is active
            Failed messages: pending 0, notready 0, noresp 2
            WiFi firmware version 1.26
            WiFi MAC address 3c:61:05:e6:f7:3b
            WiFi Vcc 3.38, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 19488
            WiFi IP address 192.168.86.39
            WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            Socket states: 0 4 0 0 0 0 0 0
            It bears noting that I by now twice did an accidental G0 H2 X1 F300 before a G0 H2 X10 F300 -- and on the X1 move nothing happened; neither a move nor a motor phase error.
            gloomyandyundefined droftartsundefined 2 Replies Last reply Reply Quote 0
            • o_lampeundefined
              o_lampe
              @oliof I can't say anything about the FW-issues, but i compared the 2660 PCB with the original Duet2. I noticed, there are far more "vias" on the Duet around the 4 output tracks (A1-B2) and the tracks are much wider. The Duet also has more vias below the chip to transfer heat to the PCB backside.
              Could you post a picture of an empty driver-socket? I'm missing a big capacitor on the driver to stabilize VMot.
                gloomyandy @oliof
                @oliof Are you still getting an error saying:
                "motor phase A may be disconnected reported by driver(s) 0"
                If you are can you run m122 when that error is being reported. I would expect the motor status to report:
                "open-load-A"
                or something similar. In your original post it looked like it was reporting the error over and over once it happened was that the case or was it reporting it only when you did a move?
                  droftarts administrators @oliof
                  @oliof is it because it identifies as Duet+DueX5, rather than Duet+DueX2, so it’s not disabling the extra non-existent drivers? How did it identify on old FW versions? There’s definitely a hardware difference between the real boards. See https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Using_a_DueX5_with_External_drivers
                  I’d guess you’d have to look at the Troodon schematic next to the DueX schematic to work out what’s different.
                  jay_s_ukundefined oliofundefined 2 Replies Last reply Reply Quote 0
                    jay_s_uk @droftarts
                    @droftarts it doesn't include the Drivers 2, 4 and 9, which are Z, E1 and E6 so it really is a duet+duex5 rather than a duet+duex2
                    • oliofundefined
                      oliof @gloomyandy
                      @gloomyandy yes and the M122 is from when I got the error. And yes, it does repeat reporting the error.
                      • oliofundefined
                        oliof @o_lampe
                        @o_lampe PXL_20211006_154555414.jpg.
                        Yes, the cooling setup is different, but please remember: The hardware is proven to work, it worked fine with RRF until 3.0 and it continues to work well with either older RRF versions or Klipper. The design may not be ideal, but it's solid and functional.
                        • oliofundefined
                          oliof @droftarts
                          @droftarts it always identifies as a Duet+DuetX5, and as you can see in my config.g, the missing drivers are disabled so they don't report an error. I have not heard back from Formbot3D but if I am not mistaken there's a weeklong holiday so I picked an unfortunate time to expect a speedy answer.
                          • oliofundefined
                            oliof
                            @o_lampe @droftarts one of the easiest discernible differences is that SG_TEST is not connected, i.e. stallguard pin is floating. Since people elsewhere were theorizing the floating stallguard may be a problem, I bridged SG_TEST to the neighboring GND pin (which I confirmed to be going on the GND rail with a multimeter, I also checked my solder attempt and it's got continuity from SG_TEST to VNegative).
                            Unfortunately no change.
                            • oliofundefined
                              oliof
                              To make it clear @gloomyandy: While I get the phase mismatch error in the console, the driver does not report open load state in M122. That is what you were looking for?
                              gloomyandyundefined 1 Reply Last reply Reply Quote 0
                                gloomyandy @oliof
                                @oliof I was expecting to see it in the m122 output, but there is a lot of "filtering" going on for this condition (motor, current, step speed, must be reported constantly over time), so it's hard to be sure. I've had a good luck at the changes since V3.0 and I can't see anything obvious that would result in what you are seeing.
                                • oliofundefined
                                  oliof @gloomyandy
                                  @gloomyandy I've been spelunking in Platform.cpp and the TMC2660 driver code (in vimdiff between 3.0 and 3.1.0), and nothing jumps immediately out at me that would explain this behavior. There are some changes about the setting and resetting of status bits that may be related, but my C++ knowledge is likely not good enough to see the subtlety that likely causes this failure. Best guess is, it's something about the changed driver initialization, maybe even the missing 10 millisecond pause that's still in 3.0 but was dropped in 3.1 ... I may just add that back, recompile and see if it helps.
                                    dc42 administrators @oliof
                                    @oliof where in the code was this 10ms pause?
                                    • oliofundefined
                                      oliof @dc42
                                      @dc42 it's possible I've been confused by vimdiff's output, I will need to re-check what I saw last night ... When I'm back home later today. Sorry for the confusion; I am still trying to understand what's going on...
                                      • oliofundefined
                                        oliof @oliof
                                        @dc42 microseconds, not milliseconds -- sorry for the mixup. In src/Movement/StepperDrivers/TMC2660.cpp; line 1030 in the 3.0 release. The whole driver bringup has been significantly changed between 3.0 and 3.1. My gut says it's a likely candidate to dig into since the failure happens on first move attempt.
                                          @oliof I suspect the problem may be caused by the code in the new driver that checks the microstep position and adjusts it to be zero before it enables the driver. This code should be disabled for drivers that have been disabled. I will look at implementing than in the next 3.4beta.
                                          oliofundefined 1 Reply Last reply Reply Quote 2
                                          • oliofundefined
                                            oliof @dc42
                                            @dc42 I do have a Duet2Wifi with a blown driver (E0, so driver 3 IIRC). I never upgraded that board to RRF3, and had packed it away to send for repairs. I hadnot gotten around to sending this board out, so I was able to do a comparison with the Troodon board.
                                            In the simple test bench setup with one stepper connected to driver 0 (X), this board does not exhibit the same failure mode as the Troodon board. In fact, it just works without any complaints.
                                            Of course this might be because there actually are traces and resistors on the board for this driver (or the driver is only partially broken instead of completely missing), so the behavior of the overall board could very well be different.
                                            Since I noticed you got the change landed already, I'll see that I get my build environment up and running again for a (hopefully) quick build and feedback cycle.
                                            oliofundefined ccollinscjundefined 2 Replies Last reply Reply Quote 0
