    Slow all the time at 2000% speed
    21
    1.2k
    • Jbournsundefined
      Jbourns @PaulHew
      @paulhew I'll give those a go, Thanks for the help. I'll be testing them in the next hour once this part is printed.
      PaulHewundefined 1 Reply Last reply Reply Quote 0
      • PaulHewundefined
        PaulHew @Jbourns
        @jbourns 👍
        • Jbournsundefined
          Jbourns @PaulHew
          @paulhew It's at 0 which is default so I assume that's off?
          • PaulHewundefined
            PaulHew @Jbourns
            @jbourns I found this for calculating Volumetric speed.
            https://docs.google.com/spreadsheets/d/1ZHSRzTm2AR_sXnLSSOq2NSmx0UYtF5bJKHUSFWiDscA/edit#gid=0
            Jbournsundefined 1 Reply Last reply Reply Quote 0
            • Jbournsundefined
              Jbourns @PaulHew
              @paulhew 10mm/3 seems like a good middle ground for the volcano
              • Jbournsundefined
                Jbourns @PaulHew
                @paulhew The only explanation is that im a daft prick. I think i fugged up my E speeds ands acceleration at some point. Doesn't explain why I couldn't just override it.
                https://youtu.be/tr7fGtmQUk8
                alankilianundefined 1 Reply Last reply Reply Quote 1
                  @jbourns the speed multiplier will override the speeds requested in the F parameter of G1/2/3/4 commands, but not the machine speed limits set by M203.
                  • alankilianundefined
                    alankilian @Jbourns
                    @jbourns YEAH!!!
                    Thanks for keeping us in the loop and letting us know when you figured it out.
                    • Jbournsundefined
                      Jbourns
                      It was either volumetric flow in prusa slicer or max speed in the config
                      JoergS5undefined 1 Reply Last reply Reply Quote 1
                      • JoergS5undefined
                        JoergS5 @Jbourns
                        @jbourns trying a different slicer and then testing 2000% let's you decide whether the problem is in the slicer region or in the config/dwc region.
