Just for fun why did I buy this?
My Duet controlled machine
1.2k
    fcwilt
    There was a recent topic here the got my attention.
    It led me to try an experiment to change the way one of my printers does something common.
    The item shown uses a NEMA 11 stepper and has 100mm of travel. The one I am actually using has just 50mm of travel.
    Before I finish my work and post pictures anyone care to speculate on what I have been up to?
    Just for fun.
    The first person with the correct answer wins...
    (make a drum roll sound in your mind)
    ...the right to say they were the first person with the correct answer. 😉
    undefined undefined 2 Replies Last reply 19 Oct 2021, 23:18 Reply Quote 0
      zapta @fcwilt
      @fcwilt, give us an hint, how will it be oriented?
      I would use it to turn off the main switch when the print completes.
      undefined 1 Reply Last reply 19 Oct 2021, 23:23 Reply Quote 0
        fcwilt @zapta
        @zapta
        A hint?
        OK, it is used to move something out of the way so when printing no print area is lost but still allows the something to perform it's intended purpose.
        undefined undefined 2 Replies Last reply 19 Oct 2021, 23:23 Reply Quote 0
          bot @fcwilt
          Probing, tool alignment with a camera coming in and out, or purge bucket moving in and out of print area are my guesses.
          *not actually a robot
          undefined 1 Reply Last reply 19 Oct 2021, 23:26 Reply Quote 0
            fcwilt @bot
            @bot said in Just for fun why did I buy this?:
            Well one of the words in your post is exactly what this experiment is about.
            undefined 1 Reply Last reply 20 Oct 2021, 00:06 Reply Quote 0
              bot @fcwilt
              @fcwilt the first word?
              undefined 1 Reply Last reply 20 Oct 2021, 00:07 Reply Quote 0
                fcwilt @bot
                Yes
                undefined 1 Reply Last reply 20 Oct 2021, 00:09 Reply Quote 0
                  bot @fcwilt
                  @fcwilt sounds like fun. I have been manually aligning my tools on the idex with a cheap USB microscope. so magnificent. You could use your little doo-dad to move the camera into the exact same position every time!
                  Or, a CNC-style tool pre-setter to measure tool Z offsets.
                  Or, a 3D-Taster style multi-axis touch probe to do Z and X/Y offsets.
                  undefined 1 Reply Last reply 20 Oct 2021, 00:11 Reply Quote 0
                    fcwilt @bot
                    Well your first word was "probing" unless I read it wrong.
                    undefined 1 Reply Last reply 20 Oct 2021, 00:12 Reply Quote 0
                      bot @fcwilt
                      @fcwilt hmmmm. probing is a vague term. I hope you're not thinking of placing anything in any dark places.
                      undefined 1 Reply Last reply 20 Oct 2021, 00:15 Reply Quote 0
                        fcwilt @bot
                        Nope - nothing like that - but was not your first word "probing"? The second item mentioned as tool alignment using a camera.
                        Did I misunderstand your post?
                          zapta @fcwilt
                          @fcwilt said in Just for fun why did I buy this?:
                          My answer below, encrypted with Google translate
                          Brosse de nettoyage de buse
                          undefined 1 Reply Last reply 20 Oct 2021, 00:36 Reply Quote 0
                            jens55
                            Pebble wiper setup
                              fcwilt @zapta
                              @zapta said in Just for fun why did I buy this?:
                              I like that I idea - I may just try that as well.
                                fcwilt @jens55
                                @jens55 said in Just for fun why did I buy this?:
                                Pebble wiper setup
                                What is a "pebble wiper"?
                                undefined 1 Reply Last reply 20 Oct 2021, 01:28 Reply Quote 0
                                  jens55 @fcwilt
                                  @fcwilt, a device for cleaning printing nozzles. The purged filament is formed into a pebble for easy separation from the nozzle (no curling around of loose filament), disconnected from the nozzle and then wiped away to ready for the next purge operation. In the context of a tool changing printer, the height of the wiper assembly is adjusted based on the tool being purged which is why you have a very short reach adjustable stage.
                                  undefined 1 Reply Last reply 20 Oct 2021, 02:04 Reply Quote 0
                                    fcwilt @jens55
                                    Interesting.
                                    How is the filament formed into a "pebble"?
                                    undefined Yveskeundefined 2 Replies Last reply 20 Oct 2021, 02:45 Reply Quote 0
                                      jens55 @fcwilt
                                      @fcwilt, it is extruded onto a flat surface just underneath the extruder
                                      https://lukeslabonline.com/products/pebble-wiper?variant=41218627371193
                                      undefined 1 Reply Last reply 20 Oct 2021, 02:48 Reply Quote 1
                                        fcwilt @jens55
                                        Well the link is interesting because it is also a clue to what I am experimenting with.
                                        • Yveskeundefined
                                          Yveske @fcwilt
                                          @fcwilt A cheaper, mechanical way of doing things
                                          https://www.bigbrain3d.com/product/retractable-purge-mechanism/
                                          undefined 1 Reply Last reply 20 Oct 2021, 07:02 Reply Quote 0
                                          4 out of 23
