    Open-loop for performance, closed-loop for error recovery.
    Hardware dev
    1.3k
    • alankilianundefined
      alankilian @fcwilt
      @fcwilt That's excellent news!
      • What are you using?
      • Have you measured the position error?
      • fcwiltundefined
        fcwilt @alankilian
        @alankilian said in Open-loop for performance, closed-loop for error recovery.:
        Products like these:
        Closed Loop Systems
        I haven't done any error measurements to date, just verified that prints seemed right.
        • o_lampeundefined
          o_lampe @T3P3Tony
          @t3p3tony said in Open-loop for performance, closed-loop for error recovery.:
          the 1HCL board runs in openloop, but reports the error from the quadrature encoder
          That's quite handy to tune in the motor current, too. Sometimes too much current reduces the max. possible speed (higher backEMF).
            alankilian @fcwilt
            @fcwilt
            Here's a thread where I measured the performance of a similar closed-loop stepper motor controller and found the MEASURED performance quite unacceptable.
            It also contains images from a user who gets unacceptable prints. We never heard back if he ever got it working well.
            If you're getting good enough prints for you that's an excellent data point and shows that is IS possible to get good prints.
            I just haven't quite seen it yet, but there is some hope.
            • DigiDundefined
              DigiD @alankilian
              @alankilian
              This is the system used by shopbottools cnc
              Pretty well exactly as you described
              https://www.orientalmotor.com/stepper-motors/alphastep-closed-loop-stepper-motors.html
              alankilianundefined 1 Reply Last reply Reply Quote 2
                alankilian @DigiD
                @digid
                MIND BLOWN!!!
                • o_lampeundefined
                  o_lampe @alankilian
                  @alankilian
                  Someone had a lot of fun making this video! But there's no disturbance in the motion to demonstrate the abilities of closed loop.
                  They could stick a ballpen between the steppers, while they were thumbwrestling.
                  • rjenkinsgbundefined
                    rjenkinsgb @alankilian
                    I'm seeing several groups attempt to make a closed-loop stepper motor controller using encoder feedback and they are all experiencing the same difficulties everyone does implementing a PID control loop.
                    Large errors during speed changes.
                    Unstable oscillation
                    Differing error performance for long and short moves
                    Differing error performance for slow and fast movements
                    The simple solution is not to use a PID system.
                    Running the drives/motors in "following error" mode with appropriate gain settings should not cause any instability.
                    That's how a lot of older industrial CNCs work, and still some new ones.
                    The motor speed is defined by:
                    (Difference between the present target position [a virtual value] and the measured position) * a gain factor.
                    As long as the gains are equal for any interpolating axes, path following accuracy is good.
                    "Look ahead" where PID calculations are added in is a refinement, but can be extremely touchy to set up if the machine mechanical performance, drive system response and measuring system response are not near perfect.
                    Any performance problems or response delays make it very difficult or impossible to get a system stable with lookahead / PID control and keep a fast response.
                    (Working with industrial CNCs for several decades, including designing and programming a control system from scratch in the early 80s).
                    Robert J.
                    Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                      alankilian @rjenkinsgb
                      @rjenkinsgb said in Open-loop for performance, closed-loop for error recovery.:
                      That would be identical to a PID system with:
                      • P = gain
                      • I = 0
                      • D = 0
                      In that system, you ONLY get "Motor speed" when you have a following error.
                      Speed = error * gain
                      That CAN be acceptable if you allow a large enough error.
                      (Note: This error is the difference between the desired position and the actual position, and can be made very very small if you have very high resolution position-measuring system, so "large enough error" might be a fraction of a step of a stepper motor.)
                      Without some mechanical damping (or D coefficient) purely proportional controls like this will oscillate as you attempt to get lower error by increasing the gain. That's just the physics of the situation.
                      I would be interested in seeing prints from a proportional-only 3D printer as well as the specifications of the position-measurement system to get a feeling for how well they can perform.
                      My experience says that with a 300-line or 500-line encoder like is available on most stepper systems that a P-only controller will perform extremely poorly.
                      But I'd LOVE to be shown to be wrong with some prints!
                      (Reference. Here's PID tuning guide I wrote 21 years ago.)
                      rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
                        P = gain
                        I = 0
                        D = 0
                        A machine too servo drive look-ahead PID system factors in the instantaneous speed that the target point is moving, before any feedback.
                        A perfectly tuned machine runs with in effect no following error using that system, but it can be extremely difficult to use on an imperfect machine.
                        Example block diagram from a Heidenhain manual - note the Velocity input to the system.
                        That particular diagram is for a DC or BLDC type servo, so includes motor current control. The same concept can be used with a drive system that only has a velocity command input though.
                        I'm limited for time just now to start looking things up, but if I remember right, in lookahead mode the PID system takes the proportional component from command velocity, the integral from following error and the derivative from feedback velocity.
                        It's not a simple all-in-one PID as for a heater or whatever.
                        Robert J.
                          rjenkinsgb
                          This is the other info I was thinking of, from a 1980s system with separate, analog servo drives.
                          The lookahead / PID is probably easier to replicate from this version:
                          That's the CNC section of this overall drive system diagram:
                          The control those diagrams relate to (Heidenhain TNC360) runs everything on a 16MHz MC68000 if I remember correctly, for machines operating with multi-axis interpolation and contouring at accuracies down to microns, but with totally separate servo drives.
                          Robert J.
