    sensor ir
    3.8k
      A Former User @fcwilt
        A Former User @A Former User
        @sgk i have this
        fcwiltundefined 2 Replies Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt @A Former User
          @sgk said in sensor ir:
          @sgk i have this
          And the number doesn't change if you put something near the sensor or take that something away?
          • fcwiltundefined
            @sgk
            And what does your current M558 command look like?
            • tecnoundefined
              tecno @fcwilt
              @sgk
              show photo of IR probe connector/cable
                A Former User @tecno
                @tecno IMG_20211026_143529.jpg M558 P1 C"!^zprobe.in" H5 F200 T9000 I0 R0.5
                  o_lampeundefined jumpedwithbothfeetundefined fcwiltundefined 3 Replies Last reply Reply Quote 0
                  • o_lampeundefined
                    o_lampe @A Former User
                    @sgk here's mine for reference: ( the probe pin has a different name, ignore it)
                    Did you try P8 as sensor type?
                    M558 P8 C"probe" H3.5 F1200 T24000
                      A Former User @o_lampe
                      • jumpedwithbothfeetundefined
                        jumpedwithbothfeet @A Former User
                        @sgk Just to clarify as I have gone over the post and I cant see your answer... when you turn on the printer and do nothing else, if you place something under the IR sensor does the red LED on the board light up when you get close to the bottom of the board?
                        6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                        • fcwiltundefined
                          That appears to be correct except, perhaps, for the exclamation point.
                          • fcwiltundefined
                            @sgk
                            Where is the M558 command located?
                            In your config.g file?
                            If so please execute, from the DWC Console, M98 P"config.g" and see if any errors are reported.
                              A Former User @jumpedwithbothfeet
                                A Former User
                                @fcwilt said in sensor ir:
                                M98 P"config.g"
                                • fcwiltundefined
                                  @sgk
                                  Thank you.
                                  It seems that the IR sensor is working based on the LEDs on it responding to the presence of the bed.
                                  The M558 configuration seems to be correct and if it is in your config.g file it appears to be executing without any problems.
                                  So that really seems to leave only the connection from the IR Sensor output to the Duet Z Probe input.
                                  Do you have a meter of any sort that can verify continuity of the wire from the connector for the IR Sensor all the way to the connector for the Duet Z Probe input?
                                    @fcwilt yes I tested with a multimeter the continuity
                                    fcwiltundefined jumpedwithbothfeetundefined 2 Replies Last reply Reply Quote 0
                                    • fcwiltundefined
                                      OK can you do this:
                                      • Disconnect the connector from the IR Sensor
                                      • Using a small piece of wire or equivalent connect the signal and ground pins of that connector and check the DWC Z probe reading
                                      • Then do the same but connecting the signal and power pins
                                        @sgk I just looked at your config.g what firmware version are you using version 1? it might be an idea to update it!
                                          @fcwilt
                                          you can tell me what they are
                                            SIamundefined 1 Reply Last reply Reply Quote 0
