    New Raspberry Pi Zero 2W
    65
    4.2k
      jay_s_uk @PCR
      @pcr I wonder if 512mb is enough ram???
      o_lampeundefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @jay_s_uk
        @jay_s_uk said in New Raspberry Pi Zero 2W:
        [OT] On my Odroid headless MCU cluster I defined 1GB RAM of each MCU as Ram-disk and the Head-MCU could access them as Swap-drive. This way I had +8GB swap drive with network read/write speed (1GBit LAN).
        Maybe we can install a swap-drive here with USB-speed (SSD?)
        //edit there's an official RPi eMMC_to_SD-card with 32GB, might be a good compromise?
          T3P3Tony administrators @PCR
          👀 RP3A0, a custom-built system-in-package designed by Raspberry Pi in the UK 👀
          I wonder what interesting yet to be discovered kernel/driver "features" lie in wait here 😆
          definitely worth giving it a go though!
          • o_lampeundefined
            o_lampe @jay_s_uk
            How much free RAM does a RPi 3 or 4 show after DSF has booted?
            • chrishammundefined
              chrishamm administrators @o_lampe
              @o_lampe On DuetPi:
              pi@duet3:~ $ free -h
                            total        used        free      shared  buff/cache   available
              Mem:          3.7Gi       342Mi       2.9Gi        58Mi       511Mi       3.2Gi
              Swap:          99Mi          0B        99Mi
              On DuetPi-lite (no GUI):
              pi@Ender3Pro ~> free -h
              Mem:          1.8Gi       128Mi       1.5Gi       8.0Mi       175Mi       1.6Gi
              Swap:          99Mi          0B        99Mi
              Both are running on two different RPi 4s. I suspect some more RAM could be saved by turning off some more system services (like bluetooth and pulseaudio).
              Duet software engineer
              o_lampeundefined 1 Reply Last reply Reply Quote 1
              • o_lampeundefined
                o_lampe @chrishamm
                @chrishamm Even in GUI mode it only takes ~350MB, that should work with the Zero 2W. But slicing is a different story.
                • o_lampeundefined
                  o_lampe
                  Don't want to highjack the thread, but while shopping in the raspberry shop, I saw the RP2040 aka. Raspberry Pi Pico.
                  It has a very low price and comes with a Cortex M0 MCU. I wonder if it would work as Arduino nano replacement, or even better as a mini toolboard MCU?
                  rjenkinsgbundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                  • rjenkinsgbundefined
                    rjenkinsgb @o_lampe
                    @o_lampe said in New Raspberry Pi Zero 2W:
                    On that off-topic subject 🙂
                    I've been playing with some Seeed Xiao boards - again an M0 CPU with 256K flash, 32K RAM. About £5 on ebay and minuscule things, 17x20mm. Info:
                    https://wiki.seeedstudio.com/Seeeduino-XIAO/
                    I'd not thought of them in relation to 3D printing, but for a small, light auxiliary interface, they should be good.
                    Robert J.
                    Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                      T3P3Tony administrators @o_lampe
                      mini toolboard MCU?
                      if someone wrote the code to use one of the pico processor cores to simulate CAN-FD fast enough then just maybe but that could well be impossible.
                      o_lampeundefined PCRundefined 2 Replies Last reply Reply Quote 0
                      • o_lampeundefined
                        o_lampe @T3P3Tony
                        @t3p3tony
                        I tried to find a Pico board with Sam-C21 and CAN-FD.
                        As Toolbord in the classic sense is difficult, but it could do some light duty chores, like extra fans, thermistors or other less timing relevant things.
                          @o_lampe i see using it as a coprocessor. There could be applications for a coprocessor (maybe not so much a toolboard but on a mainboard) but it adds significantly to the complexity of many things (think a firmware update).
                          • o_lampeundefined
                            o_lampe @T3P3Tony
                            @t3p3tony said in New Raspberry Pi Zero 2W:
                            I'd happily go that extra mile, if it helps the huge Duet2-community "over the hump" and enables it to benefit from future development.
                            The M0 processor has ~twice the power of the onboard MCU. If we'd use the onboard MCU as gateway and the M0 as mainprocessor, it would be a huge leap forward. (just dreaming)
                              @o_lampe I don't understand exactly what you are proposing? what would the board with the pico do? how would it communicate (and what hump are we getting over?)
                              • o_lampeundefined
                                o_lampe @T3P3Tony
                                @t3p3tony the M0 could do the multi-stream gcode analysis, while the onboard MCU does the pulse-generating for steppers, PWM a.s.o.
                                The hump is the limited RAM of the duet2 mcu
                                  @t3p3tony
                                  See https://duet3d.dozuki.com/Wiki/Using_the_Sammy-C21_development_board_with_Duet_3.
                                  PCRundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                                  • PCRundefined
                                    PCR @dc42
                                    • o_lampeundefined
                                      o_lampe @dc42
                                      @dc42 I know the board, but it's out off stock and quite expensive. (27EUR vs 4EUR)
                                      But I'd still consider it as Duet2 CoPro as described above.
                                      @T3P3Tony I wouldn't mind to delete the last posts and start a new thread, although everything I posted about the M0 is IMHO also valid for the Zero 2W and any other SBC
                                        @pcr nice! why the two different headers, one for Duet 3 and one for the 3 mini?
                                        PCRundefined 1 Reply Last reply Reply Quote 0
                                        • PCRundefined
                                          PCR @T3P3Tony
                                          @t3p3tony yes. I dont want to Stack in diectly on the Board. Because of some connectors. And yes the Header is placed diffrently on duet 3 and Duet Mini ;(
                                          • PCRundefined
                                            PCR @PCR
                                            @pcr btw someone from Germany who Likes to Test the Board ?
                                            o_lampeundefined PCRundefined 2 Replies Last reply Reply Quote 1
