    separate idle current for extruder motors
    Firmware wishlist
    • adhanabalundefined
      adhanabal
      hello all
      is it possible to keep only xyz axis motors in defined idle current ,
      i want to keep extruder motor to become zero idle current,
      or is it possible that m571 command i can define for individual extruders for some operations in which i require to allocate different outputs for different extruders,
      board; duet3 6hc, firmware 3.3
      please help
      adhanabalundefined 1 Reply Last reply Reply Quote 1
      • T3P3Tonyundefined T3P3Tony moved this topic from Duet Hardware and wiring
        adhanabal @adhanabal
        @adhanabal is it possible to keep only xyz axis motors in defined idle current ?,
        In rrf3.3 now is this possible?
        @T3P3Tony
        • o_lampeundefined
          o_lampe @adhanabal
          @adhanabal said in separate idle current for extruder motors:
          iwant to keep extruder motor to become zero idle current,
          At zero current, the firmware will loose position info of the extruder.
          AFAIK it's not possible yet to set different idle current, but it can be interesting for multitool printers.
          adhanabalundefined 1 Reply Last reply Reply Quote 0
            adhanabal @o_lampe
            @o_lampe thank you
            gloomyandyundefined 1 Reply Last reply Reply Quote 0
            • gloomyandyundefined
              gloomyandy @adhanabal
              @adhanabal If you want to power your extruders off when not printing you could just use M18 E0 at the end of a print or possibly in one of the standard macro files (you could even put it in daemon.g along with a suitable test to see if you are not printing).
