TMC2660 problem
25
2.3k
    jerolee
    Does the TMC2660 driver have a problem with NEMA14 36mm pancake stepper motors?
    The only thing i can come up with is that the low resistance (i havent measured inductance yet) of these small ones cause problems.
    I cant get mine to work, which ever combination of wiring, tried 8 combo's
    result a little hum.
    NEMA17 however works normally.
    coils of the small NEMA 14 measure 2.3/2.4 Ohms 1495uH
    coils of the NEMA 17 measure 4.7 Ohms
    i use a Duet2 wifi with TMC2660 drivers on it.
    anyone experience with pancake for extruder and Duet2 board?
    Thanks all.
      rjenkinsgb
      @jerolee said in TMC2660 problem:
      Those readings are odd..
      A quick search for pancake NEMA14 found this example; they are ten ohm per winding and quite high inductance, advertised as suitable for extruders.
      I wonder if yours is faulty, or a weird type?
      https://www.printedsolid.com/products/ldo-nema14-36mm-round-pancake-motor-ldo-36sth17-1004ah
      Robert J.
      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
      undefined 1 Reply Last reply 4 Nov 2021, 23:38 Reply Quote 0
        jerolee @rjenkinsgb
        @rjenkinsgb
        I got 2 brandnew and 1 older, all measure about the same. odd it is.
        undefined undefined undefined 3 Replies Last reply 5 Nov 2021, 00:22 Reply Quote 0
          GeneRisi @jerolee
          @jerolee Your readings are correct. I have the same stepper and it works fine. Do you know that they are wired differently than the typical Nema 17 motor? What do you have the current set to?
            rjenkinsgb @jerolee
            OK, that same place I linked to also sells the exact motor you have; 2.1 Ohms, 1.2mH inductance.
            https://www.printedsolid.com/products/ldo-nema14-36mm-round-pancake-motor-ldo-36sth20-1004ah
            Around 2 ohms is common for steppers, that should not cause a problem.
            Check continuity at the Duet plug? The winding should be 1-2 and 3-4, whichever end you start from.
            (Some extension / adapter cables have two wires swapped).
            Robert J.
            undefined 1 Reply Last reply 5 Nov 2021, 12:44 Reply Quote 0
              jerolee @rjenkinsgb
              @rjenkinsgb
              thats what makes it so frustrating. i got the pairs/coils in the connector like 1-1-2-2. just as the NEMA17 coils are in their connector.
              If i pair them up wrong, they make a not so nice sound 🙂 so the wiring is not the problem.
              NEMA17 works fine on same driver , pancake just wont rotate.
              I have tested other drivers, same result.
              Im gettin a bit tired of reprap and duet to be honest, i never had any problems with marlin boards. with these, there seems always something.
              Switches not detected, Gantry tramming doesnt work consistantly etc....
              undefined undefined 2 Replies Last reply 5 Nov 2021, 12:57 Reply Quote 0
                deckingman @jerolee
                @jerolee I used to have a Duet2 (Ethernet rather than WiFi) with Duex 5 expansion board (same drivers as far as I know) and I used to drive 5 pancake steppers without any problems (although I don't remember the spec). Maybe there is something about the way you have the board configured but unless you post your configuration files it's hard to say.
                  Gixxerfast @jerolee
                  @jerolee Are you absolutely sure about the motor wiring? I have a similar motor (17mm) in my V0.1
                  My connector is red, green , yellow, blue as described below. Yours doesn't seem to be connected the same way. I assume you have checked this as you've measured the resistance.
                  https://cdn.shopify.com/s/files/1/0239/9287/files/HT_LDO-36STH20-1004AHG_XH_RevA.pdf
                  Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                  Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                  Ender 3 Pro with BTT SKR-2 + RRF
                  undefined 1 Reply Last reply 5 Nov 2021, 16:34 Reply Quote 1
                    jerolee @Gixxerfast
                    @gixxerfast
                    hi mate,
                    I just tested my 3 pancakes on my ender 3 which has a SKR board and runs marlin. pancakes run fine. no problems.
                    Im gonna sell my duet2 wifi duex tft, never gonna look back.
                    I just ordered a BTT Octopus board which has 8 drivers on it with TMC 2209's all problems sorted.
                    undefined 1 Reply Last reply 5 Nov 2021, 18:13 Reply Quote 0
                    • undefined jerolee has marked this topic as solved 5 Nov 2021, 16:37
                      PCR @jerolee
                      @jerolee ..... Thats than Bad for you ,;) its definitly Not the duet
                        dc42 administrators @jerolee
                        @jerolee you have wired the motor to the plug incorrectly. The diagram posted by @Gixxerfast shows that red and green are one phase, therefore they need to be adjacent and at one end of the connector. That's not what I see in your photo. You will get the same problem if you use your existing wiring order with any other control board.
                        undefined 1 Reply Last reply 11 Nov 2021, 13:10 Reply Quote 0
                          jerolee @dc42
                          the diagram showed does not represent de motor i have. i measured the coils and the correct pairs for my motor are black/green and red/blue.
                          Otherwise i couldnt measure the resistance no?
                          So, this is not a wiring problem, i got more pancakes with different color wires. i measure the coils which are what and then connect, same problem no rotation, just a little bit of hum. when i connect a nema17 thats runs quite normal, i noticed however some hickup that it wouldnt start rotating.
                          I also tested the round 36mm pancakes on other drivers on the board X, Y, Z (these drive my NEMA17's. all drivers same result, no rotation.
                          It must be some PWM or whatever signal not quite work with the small round motors?
                          Further... i used same pancake motors with connector on my ender 3 board, motors run normally.
                          I just have no clue whats goin on here. i post my config file.
                          M569 P0 S0 ; physical drive 0 goes backwards
                          M569 P2 S0 ; physical drive 2 goes backwards
                          M569 P4 S0 ; physical drive 4 goes backwards
                          M569 P5 S0 ; physical drive 5 goes backwards
                          M569 P6 S0 ; physical drive 6 goes backwards
                          M569 P7 S0 ; physical drive 7 goes backwards
                          M584 X0 Y1:4 Z2:5:6:7 E3 ; set drive mapping
                          M671 X-60:-60:660:660 Y-48:378:378:-48 S7 ; set the coordinates of the 4 Z-axis drivers
                          M92 X80.03 Y79.84:79.84 Z1615.90:1621.26:1621.69:1619.23 E300.00 ; set steps per mm
                          M566 X900.00 Y900.00:900.00 Z60.00:60.00:60.00:60.00 E500.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X10000.00 Y10000.00:10000.00 Z500.00:500.00:500.00:500.00 E1000.00 ; set maximum speeds (mm/min)
                          M201 X500.00 Y500.00:500.00 Z20.00:20.00:20.00:20.00 E500.00 ; set accelerations (mm/s^2)
                          M906 X800 Y800:800 Z800:800:800:800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M208 X600 Y300 Z470 S0 ; set axis maxima
                          M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin !xstop
                          M574 Y1 S1 P"!ystop+!e1stop" ; configure active-low endstop for low end on Y via pin !ystop
                          M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
                          M558 P9 C"^zprobe.in" H5 F120 T4000 ; set Z probe type to bltouch and the dive height + speeds
                          G31 P500 X36 Y9 Z0 ; set Z probe trigger value, offset and trigger height
                          M557 X65:585 Y20:280 S130 ; define mesh grid
                          ;Filament Runout switch
                          M591 D0 P2 C"e0stop" S1 ; filament switch
                          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 R4700 ; configure sensor 0 as thermistor on pin bedtemp
                          M308 S1 P"e0temp" Y"pt1000" T100000 B4000 R4700 ; configure sensor 1 as thermistor on pin e0temp
                          M307 H1 B0 R2.926 C244.4 D10.45 S1.00 V25.0 ; disable bang-bang mode for heater and set PWM limit
                          M143 H1 S260 ; set temperature limit for heater 1 to 260C
                          M950 F0 C"fan0" Q500 ; create fan 0 "part fan" on pin fan0 and set its frequency
                          M950 F1 C"fan1" Q500 ; create fan 1 "hotend fan"on pin fan1 and set its frequency
                          M106 P1 S1 H1 T70 ; set fan 1 value. Thermostatic control is turned on
                          undefined 1 Reply Last reply 11 Nov 2021, 13:16 Reply Quote 0
                          • undefined jerolee has marked this topic as unsolved 11 Nov 2021, 13:12
                            PCR @jerolee
                            @jerolee
                            there are some erros in cour config. please give me a sec.
                            undefined undefined 2 Replies Last reply 11 Nov 2021, 13:19 Reply Quote 0
                              PCR @PCR
                              M92 X80.03 Y79.84 Z1615.90 E300.00 ; set steps per mm
                              M566 X900.00 Y900.00 Z60.00 E500.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X10000.00 Y10000.00 Z500.00 E1000.00 ; set maximum speeds (mm/min)
                              M201 X500.00 Y500.00 Z20.00 E500.00 ; set accelerations (mm/s^2)
                              RepRapFirmware does not support individual motor settings where an axis has multiple motors connected to different stepper drivers. The first parameter specified will be used for all motors on the axis. You should use identical motors on any axis that has more than one motor to avoid unexpected behaviour.
                              Example: If you have two motors on your Z axis, physically connected to Z and E0 stepper drivers, configured with M584 Z2:3, set M92 Z80, not M92 Z80:80
                                jerolee @PCR
                                @pcr
                                This has no solution for the Extruder stepper problem but that aside.
                                Quote "RepRapFirmware does not support individual motor settings where an axis has multiple motors connected to different stepper drivers. The first parameter specified will be used for all motors on the axis. You should use identical motors on any axis that has more than one motor to avoid unexpected behaviour." end quote.
                                I use identical motors on my axis.
                                This means that my Z-axis will always run out of sync go skewed in height while the motors are not exactly the same? I had to calibrate them.
                                Have them raise Z 450mm then measure the actual distance and do some calculation to adjust the number of steps per mm per motor.
                                They didnt raise the gantry at all corners exactly accurate. Same as you do for extruding exact amount of filament.
                                But oddly enough, after the calibration, feed in these steps in the config, the 4 corners does run accurate 🙂 so another wierd thing goin on then?
                                This would be 1 more reason to step away from reprap software?
                                undefined 1 Reply Last reply 11 Nov 2021, 20:04 Reply Quote 0
                                  @jerolee please can you provide a link to the pancake stepper motor that you purchased. I will then purchase on so that I can test it with Duets.
                                  Only if your Z steps/mm is not the same for all your Z motors, or they can't all be run at the same current.
                                  undefined 1 Reply Last reply 11 Nov 2021, 20:09 Reply Quote 0
                                    GeneRisi @dc42
                                    @dc42 I have exactly the same motor. It works. @jerolee , here is my suggestion. Connect the motor wiring from the motor all the way to the duet board. The duet board connector has the wiring between coils on adjacent pins, so one coil will be pins 1 and 2. The other coil will be on pins 3 and 4. Measure the resistance on the connector you are plugging into the duet board. If you do not get approx. 2 ohms for both pairs, a wire is crossed. Typical Nema 17 steppers have the pairs interlaced. The LDO pancake stepper does not.
                                    undefined 1 Reply Last reply 11 Nov 2021, 20:24 Reply Quote 0
                                      dc42 administrators @GeneRisi
                                      @generisi, thanks for your observations.
                                      Unfortunately, connecting stepper motors incorrectly to a stepper driver is the best way of blowing it. We took steps when designing the Duet to improve the resilience of the drivers when a motor is disconnected under load. However, the current regulation in the stepper drive relies on the motor being connected correctly, and we can't do anything about that. This is why at https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Connecting_stepper_motors we stress the need to connect the motors correctly.
                                      The TMC2660s are high-current drivers and the short-circuit protection built into them is unfortunately not fast enough to protect the driver in all situations (even though RRF sets it to maximum sensitivity), especially when connecting low-inductance motors incorrectly. Therefore I suggest you check whether the motor output that you are testing the pancake motor with is still capable of driving one of your Nema 17 motors correctly.
                                      undefined 1 Reply Last reply 11 Nov 2021, 22:19 Reply Quote 0
                                        jerolee @dc42
                                        All of the drivers still operate normally with all NEMA17 on it. So none of the drivers is defective or burned out. my 3D printer functions, it homes all axis, it does the tramming. it just wont let the pancake motors rotate. i connected them to all of the drivers and they just dont work.
                                        Please stop replying on the wiring because i connect the coils correctly. 1 coil on 1-2 pin other coil to 3-4 pin. i looked at the wiring schematic of the Duet board.
                                        So nema17 just works fine, i know the wiring can be different for motors, thats exactly why i measured which pairs are the coils, to not make mistakes here.
                                        Im completely in the dark about what can cause this. I posted the config file im using. Can someone comment on the settings for the Extruder?
                                        I cant think of anything wrong there tbh because it has all the settings the other drivers get.
                                        Also tried different current settings, nothing changes. tried without interpolation, etc...
                                        I connect the pancakes to my ender3 board which runs on a SKR turbo with Marlin and there the round pancakes just work fine, rotating both directions
                                        No worries.
                                        If you guys dont have a clue either, then just say it. dont bring up the wiring again 🙂
                                        Thanks anyways.
                                        i just changed the Y and Z steps to just 1 value for each letter. Does the same goes for the current settings and others like acceleration, speed?
                                        After getting used to reprap and DWC i would hate to change back, a lot of work again, time and money invested lost. im not happy, the printer as good as finished but without the extruder running its useless sitting there.IMG_1778.JPG
                                        undefined undefined 2 Replies Last reply 12 Nov 2021, 03:11 Reply Quote -1
                                          jerolee @jerolee
                                          @dc42 Same measurement, same wiring like other picture but just more clear in view.
                                          Hurray the stepper is rotating!!! The only thing i changed today was that i removed the (not needed) steps per mm in the config file from the Y and Z axis. This has nothing to do with E axis right?!
                                          BUT appearantly , how in the hell this is possible i dunno, it fucked up the pancake steppers. Im completely stunned here and i would like to ask DC42 to try and replicate this. the more values registered under Y and Z axis must have crazed the system in some kinda really odd way.
                                          Wow unbelievable, but im so happy it works now, jeeeez im speechless.
                                          10 out of 25
