    ST3Di Modelsmart 280 - Duet Maestro repair/upgrade
    My Duet controlled machine
    13
    139
    9.4k
    • Blacksheep99undefined
      Blacksheep99 @Phaedrux
      @Phaedrux thanks for all the help, the support here is excellent and meant I could get a printer working again
      • tonyundefined
        tony
        Hello. Noticed your post, although quite old (post that is) I too have a Modelsmart 280. Managed to fry my ssd drive the other day which contained my original stedi driver etc originally downloaded from the stedi site. As you may have experienced the link to stedi download the drivers site, is now some Chinese football site !.
        So it looks like stedi having been purchased by other larger companies is no longer alive to date as far as I can tell.
        Having seen your post I wonder if you may still have the software downloaded on your end, if so any chance you could copy this to me, so I can again communicate PC to Printer as before my PC meltdown. Thanks again, kind regards Tony
        Blacksheep99undefined 1 Reply Last reply Reply Quote 0
          Blacksheep99 @tony
          @tony Just checked I still have it. Not sure I have the driver. I can send you what I have though.
          As an aside, you don't need to use it. I was using Cura but you can use any slicer as long as you edit the gcode before you print to include a line the printer reads. I have a word doc I produced that I can also send.
          Beyond that, consider replacing the board.
          tonyundefined DanWilliams94undefined 2 Replies Last reply Reply Quote 1
          • tonyundefined
            tony @Blacksheep99
            @blacksheep99
            that was a quick, thanks. I've got to confess not a 3d printer nerd, so writing code might be beyond my level. That said appreciate if you could send what you have, thanks much appreciated, regards tony
              Blacksheep99 @tony
              @tony I've sent you a message.
              tonyundefined 1 Reply Last reply Reply Quote 0
              • tonyundefined
                tony @Blacksheep99
                @blacksheep99
                hello boss, seems like I didn't receive it, any chance of routing it down my email sales@compass-stairlifts.co.uk regards tony👍
                  Blacksheep99 @tony
                  @tony email sent
                  tonyundefined 1 Reply Last reply Reply Quote 1
                  • tonyundefined
                    tony
                    Hello
                    Had to go to work this morning, so just thought I would acknowledge your much appreciated efforts,
                    I will get on with using the driver package you sent via email and have downloaded the latest cura version, in an effort to increase my knowledge in this field.
                    Anyway thanks again for taking the time, if you have any further information that may help my basic attempts to understand g-code that would also be appreciated. Kind regards Tony
                    • tonyundefined
                      tony @Blacksheep99
                      @blacksheep99 stedi file worked perfect, printer back in communication with PC, thanks for taking the time again, very much appreciated, Kind Regards Tony
                        Blacksheep99 @tony
                        @tony glad to hear you’re back up and running. Happy to be able to help
                        • Hulsie3216undefined
                          Hulsie3216
                          Maybe I am to late to join this conversation, but i got exactly the same issue as @tony.
                          Is it for me also possible to get the st3di driver or the word document so i can slide it in Cura, (or both ;D)?
                          That would be very helpfull for me. Thanks in advance.
                          Regards Hulsie3216
                          Blacksheep99undefined DanWilliams94undefined 2 Replies Last reply Reply Quote 0
                            Blacksheep99 @Hulsie3216
                            @hulsie3216 hi, sorry I’ve just seen this. Currently on holiday but I’ll send you the info when I get a chance
                            • DanWilliams94undefined
                              DanWilliams94 @Hulsie3216
                              @hulsie3216 can u send me the settings for cura because I tried slicing something and uploading it to the sd card and nothing shows?
                                DanWilliams94 @Blacksheep99
                                @blacksheep99 by any chance to u still have the g code edit?
                                Blacksheep99undefined 2 Replies Last reply Reply Quote 0
                                  Blacksheep99 @DanWilliams94
                                  @danwilliams94 I have a guide somewhere. I'll dig it out and put a link here
                                    @danwilliams94 See if this works
                                    https://docs.google.com/document/d/1xLjEwIyu_P7TE6h6DIhYH68IQRL0Qa_p/edit?usp=sharing&ouid=116402951384827293733&rtpof=true&sd=true
                                      @blacksheep99
                                      My g codes don't look the same mine say this
                                      FLAVOR:Marlin
                                      ;TIME:31184
                                      ;Filament used: 8.0111m, 0m
                                      ;Layer height: 0.15
                                      ;MINX:60.218
                                      ;MINY:60.428
                                      ;MINZ:0.3
                                      ;MAXX:144.789
                                      ;MAXY:141.628
                                      ;MAXZ:116.55
                                      ;Generated with Cura_SteamEngine main
                                      T0
                                      M104 S200
                                      M105
                                      M109 S200
                                      M82 ;absolute extrusion mode
                                      G21 ;metric values
                                      G90 ;absolute positioning
                                      M82 ;set extruder to absolute mode
                                      M107 ;start with the fan off
                                      G28 X0 Y0 ;move X/Y to min endstops
                                      G28 Z0 ;move Z to min endstops
                                      G1 Z15.0 F9000 ;move the platform down 15mm
                                      T1 ;Switch to the 2nd extruder
                                      G92 E0 ;zero the extruded length
                                        @blacksheep99 what would be ideal if I could get hold of the editor but I think the company went bust some time ago been looking online just incase someone made a copy of it but no look finding st3di edit
                                          @danwilliams94 I have a copy. Link incoming
                                            @danwilliams94
                                            Hopefully works
                                            https://drive.google.com/file/d/1f1yuOidiOxlcGvqfJhKm9rftpKGLOB2k/view?usp=drivesdk
                                            DanWilliams94undefined 1 Reply Last reply Reply Quote 0
