    #- (hash) printer with super simple gantry
    Example setups and prints
    anti-racking dual roller constraint hash printer
    11
    65
    6.5k
    • o_lampeundefined
      o_lampe
      Just for the record, I have configured bed leveling (G32) and mesh leveling with the mini-IR probe.
      It's blazing fast, the first G30 to set Z=0 always scares me 😱
      o_lampeundefined 1 Reply Last reply Reply Quote 2
      • o_lampeundefined
        o_lampe @o_lampe
        @o_lampe Almost forgot to mention that it runs with the split dual roller constraint now and it never failed yet.
        It's time to add some extruders and print some benchies.
        • o_lampeundefined
          o_lampe
          It's ALIVE...
          Actually no big things to report here, it just finished the first print. With only a single nozzle and without a fancy mini-Z axis. I just want to see if the two smooth rods are stable enough to carry a direct drive sherpa mini and to gather some experience with the new_to_me pertinax build plate. (feel free to share your findings with yours and PLA, PETG)
          The result reminds me a bit of my first prints on a Prusa i3...there's room for improvement 😉
          Sorry for the blurry pic, it's a screenshot from a short video
          o_lampeundefined 1 Reply Last reply Reply Quote 1
          • o_lampeundefined
            o_lampe @o_lampe
            @o_lampe
            I have to add more tie-raps (*), just doubling up the drylin bearings doesn't help much.
            *) can you believe it, German hardware stores are running out off supplies?
            • oliofundefined
              oliof
              I use 0.5mm FR2 (pertinax) on flex steel sheet, needs a good sanding and then works pretty well and is very resistant to abuse (-;
              • o_lampeundefined
                o_lampe @oliof
                @oliof I skipped the steelplate and placed it directly on selfadhesive ferro-film 1mm.
                What about bed-temps? I'm at 65C for first layer, but through the thick magnetic sheet the temp drops 5-8 degree (and takes extra pre-heat time of ca. 5min.)
                • oliofundefined
                  oliof
                  No discernible difference compared to PEI sheet at 0.5mm. I know it can take a long time to heat up at higher thickness.
                  • o_lampeundefined
                    o_lampe
                    @mrehorstdmd calling
                    Everytime I see your sand table videos, I want to build one.
                    Now I think to build a square or round hashTable with 4 steel balls zipping around. They could draw the same mirrored pattern or 4 individual patterns ( two at a time)
                    The main argument to do this, is the lack of slicer and RRF options to run a printer with hash gantry.
                    • oliofundefined
                      oliof @o_lampe
                      @o_lampe Why do you think RRF couldn't run a hash printer? It looks like a pretty linear relation ship between axis so should be definable with M669 matrix option. While tool changing might be a challenge, 4x copy/2x2mirror mode should be relatively straightforward to setup.
                      • o_lampeundefined
                        o_lampe @oliof
                        @oliof
                        I've already prooven that the XYUV kinematics work, but a printer needs a perfect first layer and that's the culprit for now.
                        RRF3.5 will have means for individual Z-axis adjustment of heightmap-corrections, but until then I have to find usecases with less critical Z-height. Sand table or laser engraver or feltpen plotter comes to mind.
                        Quad ball sand table is by far the coolest option IMHO.
                        oliofundefined o_lampeundefined 3 Replies Last reply Reply Quote 1
                        • oliofundefined
                          oliof @o_lampe
                          @o_lampe you could go old school and print with rafts.
                          • oliofundefined
                            oliof @o_lampe
                            @o_lampe said in #- (hash) printer with super simple gantry:
                            @oliof
                            Arkanoid style animation would be fun, three balls drawing bricks, that a third one destroys (-:
                            o_lampeundefined 2 Replies Last reply Reply Quote 0
                            • o_lampeundefined
                              o_lampe @oliof
                              @oliof said in #- (hash) printer with super simple gantry:
                              That came to my mind, too. But it takes extra time to print the raft and I'm afraid that even with 4 extruders in copy mode it melts down the otherwise significant time-advantage.
                              • o_lampeundefined
                                o_lampe @oliof
                                I'd be happy to play TicTacToe, but if you write a meta-code macro for Arcanoid, I'll try it for sure 😬
                                • oliofundefined
                                  oliof @o_lampe
                                  @o_lampe sure it won't be fast, but proving the concept is the first step to get it optimized. I get your hesitation though, and the world needs more sand tables (-:
                                  • o_lampeundefined
                                    o_lampe @oliof
                                    @oliof
                                    One Arcade classic game would be suitable for a sand table : Tron
                                    Or Snake for single player 🙂
                                    • o_lampeundefined
                                      o_lampe @o_lampe
                                      I've checked options how to put a sand table on my hash gantry and it seems, I can simply put it on top of the existing printer. Just have to design the tool holders for magnets and some frame adapters. Easy to revert, when serious stuff happens on Slicer or FW side...
                                      • oliofundefined
                                        oliof
                                        @o_lampe any news on your hash printer? It's been a while since you posted an update l and I am curious.
                                        • o_lampeundefined
                                          o_lampe @oliof
                                          @oliof , thanks for asking.
                                          I got a bit distracted by the NeoPixel situation I found in RRF. When I played with other controller options I saw a nice Ocean wave animation, which would perfectly fit the sand table theme.
                                          Last month I bought a CO2 laser, which will engrave acrylic sheets with a wave pattern. Those sheets will be enlighted by the neoPixel wave animation.
                                          Commissioning the laser took a while, it's still not perfect. In the meantime I try to find the best wave pattern for engraving.
                                          //edit I also had the idea to put 4 Laser diodes (or even CO2 tubes) on the hash printer, they are not so critical with Z-height. But the firmware situation regarding multi-beam collaboration is even worse than multi-extruder collaboration.
                                          I will ask the discord channel of the "K40Keller" if they like the idea...they helped me a lot with my K40.
                                          • o_lampeundefined o_lampe referenced this topic
                                          • o_lampeundefined
                                            o_lampe
                                            Just for the record:
                                            I will disassemble the frame, because another insane project is in the making and I need the space and some parts. It was a proof of concept study anyway and IMHO showed it's potential.
                                            When the time comes and firmware and slicers are ready for it, I might rebuild it with linear rails and a stiffer frame.
