    #- (hash) printer with super simple gantry
    Example setups and prints
    anti-racking dual roller constraint hash printer
    11
    65
    6.5k
    • o_lampeundefined
      o_lampe @oliof
      @oliof I skipped the steelplate and placed it directly on selfadhesive ferro-film 1mm.
      What about bed-temps? I'm at 65C for first layer, but through the thick magnetic sheet the temp drops 5-8 degree (and takes extra pre-heat time of ca. 5min.)
      • oliofundefined
        oliof
        No discernible difference compared to PEI sheet at 0.5mm. I know it can take a long time to heat up at higher thickness.
        • o_lampeundefined
          o_lampe
          @mrehorstdmd calling
          Everytime I see your sand table videos, I want to build one.
          Now I think to build a square or round hashTable with 4 steel balls zipping around. They could draw the same mirrored pattern or 4 individual patterns ( two at a time)
          The main argument to do this, is the lack of slicer and RRF options to run a printer with hash gantry.
          • oliofundefined
            oliof @o_lampe
            @o_lampe Why do you think RRF couldn't run a hash printer? It looks like a pretty linear relation ship between axis so should be definable with M669 matrix option. While tool changing might be a challenge, 4x copy/2x2mirror mode should be relatively straightforward to setup.
            • o_lampeundefined
              o_lampe @oliof
              @oliof
              I've already prooven that the XYUV kinematics work, but a printer needs a perfect first layer and that's the culprit for now.
              RRF3.5 will have means for individual Z-axis adjustment of heightmap-corrections, but until then I have to find usecases with less critical Z-height. Sand table or laser engraver or feltpen plotter comes to mind.
              Quad ball sand table is by far the coolest option IMHO.
              oliofundefined o_lampeundefined 3 Replies Last reply Reply Quote 1
              • oliofundefined
                oliof @o_lampe
                @o_lampe you could go old school and print with rafts.
                • oliofundefined
                  oliof @o_lampe
                  @o_lampe said in #- (hash) printer with super simple gantry:
                  @oliof
                  Arkanoid style animation would be fun, three balls drawing bricks, that a third one destroys (-:
                  o_lampeundefined 2 Replies Last reply Reply Quote 0
                  • o_lampeundefined
                    o_lampe @oliof
                    @oliof said in #- (hash) printer with super simple gantry:
                    That came to my mind, too. But it takes extra time to print the raft and I'm afraid that even with 4 extruders in copy mode it melts down the otherwise significant time-advantage.
                    • o_lampeundefined
                      o_lampe @oliof
                      I'd be happy to play TicTacToe, but if you write a meta-code macro for Arcanoid, I'll try it for sure 😬
                      • oliofundefined
                        oliof @o_lampe
                        @o_lampe sure it won't be fast, but proving the concept is the first step to get it optimized. I get your hesitation though, and the world needs more sand tables (-:
                        • o_lampeundefined
                          o_lampe @oliof
                          @oliof
                          One Arcade classic game would be suitable for a sand table : Tron
                          Or Snake for single player 🙂
                          • o_lampeundefined
                            o_lampe @o_lampe
                            I've checked options how to put a sand table on my hash gantry and it seems, I can simply put it on top of the existing printer. Just have to design the tool holders for magnets and some frame adapters. Easy to revert, when serious stuff happens on Slicer or FW side...
                            • oliofundefined
                              oliof
                              @o_lampe any news on your hash printer? It's been a while since you posted an update l and I am curious.
                              • o_lampeundefined
                                o_lampe @oliof
                                @oliof , thanks for asking.
                                I got a bit distracted by the NeoPixel situation I found in RRF. When I played with other controller options I saw a nice Ocean wave animation, which would perfectly fit the sand table theme.
                                Last month I bought a CO2 laser, which will engrave acrylic sheets with a wave pattern. Those sheets will be enlighted by the neoPixel wave animation.
                                Commissioning the laser took a while, it's still not perfect. In the meantime I try to find the best wave pattern for engraving.
                                //edit I also had the idea to put 4 Laser diodes (or even CO2 tubes) on the hash printer, they are not so critical with Z-height. But the firmware situation regarding multi-beam collaboration is even worse than multi-extruder collaboration.
                                I will ask the discord channel of the "K40Keller" if they like the idea...they helped me a lot with my K40.
                                • o_lampeundefined o_lampe referenced this topic
                                • o_lampeundefined
                                  o_lampe
                                  Just for the record:
                                  I will disassemble the frame, because another insane project is in the making and I need the space and some parts. It was a proof of concept study anyway and IMHO showed it's potential.
                                  When the time comes and firmware and slicers are ready for it, I might rebuild it with linear rails and a stiffer frame.
                                    Only the good die young.
                                    • o_lampeundefined
                                      o_lampe
                                      @Amayaatp
                                      technically, it's a cartesian printer with four printheads. Only 4 motors required for the XYUV gantry.
                                      It allows several new and unique printmodes , which are currently not fully supported by slicers or printer firmware. So I disassembled it.
                                      Maybe it will get a second chance in 5-10 years...
                                      • _Djremaundefined
                                        _Djrema
                                        Hi. I'm the guy who did the "Hash Kinematics" video.
                                        Landed here completely by chance while looking at the Dueling Zero Github (this post is referenced there).
                                        At the time I've launched the videoI had a baby about to come and I that got me on ANOTHER (and more exciting) ride. Since then, It's harder to be in the right mental space (and money) to actually finish that build. That's why I'm really glad that video inspired someone to create something like this.
                                        o_lampeundefined 1 Reply Last reply Reply Quote 3
                                        • o_lampeundefined
                                          o_lampe @_Djrema
                                          @_Djrema Hi, honored to have you here although my project ended early as a proof of concept only.
                                          Slicers and controller firmware are just beginning to work with more than one nozzle, so it will take a while to see a working printer.
                                          Another reason why I started the project is, the copy/mirror mode which was interesting at first. But since I own resin printers and learned their ability to mass produce parts, they are much more intriguing to me now.
                                          Mirror mode for bigger parts would be a reason to build a #-printer, but the build-cost will explode.
