    #- (hash) printer with super simple gantry
    Example setups and prints
    anti-racking dual roller constraint hash printer
    11
    65
    7.7k
    • fcwiltundefined
      fcwilt @o_lampe
      @o_lampe said in #- (hash) printer with super simple gantry:
      @fcwilt
      you both describe a *[Kelvin mount]
      After reading about the different kinds of mounts I decided to follow your lead.
      I modified my printer to use a mount similar to yours.
      My bed is supported by a frame made from 20x20 extrusions and the mounting points are on the frame well away from the heat of the bed.
      I now have three one piece printed parts with a V for the ball to ride in.
      They seem to be working fine.
      Here is one of them:
      Thanks for leading me to a better design.
        jay_s_uk @o_lampe
        @o_lampe looks very good! impressive that it can manage 2 different designs at once.
        Looking forward to seeing this thing print!
        • o_lampeundefined
          o_lampe @jay_s_uk
          @jay_s_uk said in #- (hash) printer with super simple gantry:
          Well, I cheated a bit since both objects have the same path-count.
          circle vs square would be much harder to merge into one file.
          Then I'd have to keep an eye on layer times. Probably have to slow down one tool to see them finish at roughly the same time.
          I'd have to split long straights into short segments and sync them with the arc-moves (G2/G3 is another story)
          And let's not forget the missing independant Z-adjustment, I'm still trying to figure out.
          sigh we will see feltpen-demos forever 😉
            jay_s_uk @o_lampe
            @o_lampe I can see where that would be difficult. you'd also have to do something about ooze/moving a tool out the way as well
            • o_lampeundefined
              o_lampe @jay_s_uk
              @jay_s_uk Oozing can be nasty on multitool printers. I have a parking-slot on my IDEX printer, which has a nylon part where the nozzle rests on.
              The good thing about the hashPrinter is, they (could) have way less tool changes than the classic toolchangers. (in the future)
              • o_lampeundefined
                o_lampe @fcwilt
                @fcwilt said in #- (hash) printer with super simple gantry:
                To be honest, in the end I wasn't sure if it's better. The arguments about misaligned guides made me think. But from a 3D perspective, the Maxwell design is easier to build. (How would I drill a really round hole with my cheap drillpress? They tend to be triangular)
                cosmowaveundefined 1 Reply Last reply Reply Quote 1
                • cosmowaveundefined
                  cosmowave @o_lampe
                  try to use a reamer?!
                  Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                  • o_lampeundefined
                    o_lampe
                    More and more test hours for the gantry and it is beginning to show an issue. The dual-dual roller constraint fails sometimes.
                    I think, I have to split the Aramid-line into two parts and fix the ends. Which means, I have to disassemble the whole gantry 😢
                    Before/after:
                    • o_lampeundefined
                      o_lampe
                      Just for the record, I have configured bed leveling (G32) and mesh leveling with the mini-IR probe.
                      It's blazing fast, the first G30 to set Z=0 always scares me 😱
                      o_lampeundefined 1 Reply Last reply Reply Quote 2
                      • o_lampeundefined
                        o_lampe @o_lampe
                        @o_lampe Almost forgot to mention that it runs with the split dual roller constraint now and it never failed yet.
                        It's time to add some extruders and print some benchies.
                        • o_lampeundefined
                          o_lampe
                          It's ALIVE...
                          Actually no big things to report here, it just finished the first print. With only a single nozzle and without a fancy mini-Z axis. I just want to see if the two smooth rods are stable enough to carry a direct drive sherpa mini and to gather some experience with the new_to_me pertinax build plate. (feel free to share your findings with yours and PLA, PETG)
                          The result reminds me a bit of my first prints on a Prusa i3...there's room for improvement 😉
                          Sorry for the blurry pic, it's a screenshot from a short video
                          o_lampeundefined 1 Reply Last reply Reply Quote 1
                          • o_lampeundefined
                            o_lampe @o_lampe
                            @o_lampe
                            I have to add more tie-raps (*), just doubling up the drylin bearings doesn't help much.
                            *) can you believe it, German hardware stores are running out off supplies?
                            • oliofundefined
                              oliof
                              I use 0.5mm FR2 (pertinax) on flex steel sheet, needs a good sanding and then works pretty well and is very resistant to abuse (-;
                              • o_lampeundefined
                                o_lampe @oliof
                                @oliof I skipped the steelplate and placed it directly on selfadhesive ferro-film 1mm.
                                What about bed-temps? I'm at 65C for first layer, but through the thick magnetic sheet the temp drops 5-8 degree (and takes extra pre-heat time of ca. 5min.)
                                • oliofundefined
                                  oliof
                                  No discernible difference compared to PEI sheet at 0.5mm. I know it can take a long time to heat up at higher thickness.
                                  • o_lampeundefined
                                    o_lampe
                                    @mrehorstdmd calling
                                    Everytime I see your sand table videos, I want to build one.
                                    Now I think to build a square or round hashTable with 4 steel balls zipping around. They could draw the same mirrored pattern or 4 individual patterns ( two at a time)
                                    The main argument to do this, is the lack of slicer and RRF options to run a printer with hash gantry.
                                    • oliofundefined
                                      oliof @o_lampe
                                      @o_lampe Why do you think RRF couldn't run a hash printer? It looks like a pretty linear relation ship between axis so should be definable with M669 matrix option. While tool changing might be a challenge, 4x copy/2x2mirror mode should be relatively straightforward to setup.
                                      • o_lampeundefined
                                        o_lampe @oliof
                                        @oliof
                                        I've already prooven that the XYUV kinematics work, but a printer needs a perfect first layer and that's the culprit for now.
                                        RRF3.5 will have means for individual Z-axis adjustment of heightmap-corrections, but until then I have to find usecases with less critical Z-height. Sand table or laser engraver or feltpen plotter comes to mind.
                                        Quad ball sand table is by far the coolest option IMHO.
                                        oliofundefined o_lampeundefined 3 Replies Last reply Reply Quote 1
                                        • oliofundefined
                                          oliof @o_lampe
                                          @o_lampe you could go old school and print with rafts.
                                          • oliofundefined
                                            oliof @o_lampe
                                            @oliof
                                            Arkanoid style animation would be fun, three balls drawing bricks, that a third one destroys (-:
                                            o_lampeundefined 2 Replies Last reply Reply Quote 0
