M566 P1 vs pressure advance
Beta Firmware
936
    T3P3Tony administrators @AlexTh
    @alexth is this behaviour different in RRF3.3?
    undefined 1 Reply Last reply 23 Nov 2021, 10:21 Reply Quote 0
      AlexTh @T3P3Tony
      @t3p3tony I am a new RRF user. I did not install other versions.
      undefined undefined 2 Replies Last reply 23 Nov 2021, 10:25 Reply Quote 0
        @alexth the board you had probably had an older version initially. Maybe @jay_s_uk can advise as this is a mellow board not a duet.
          PCR @AlexTh
          @alexth you have to tune PA with the specific jerk settings and policy.
          undefined 1 Reply Last reply 23 Nov 2021, 10:34 Reply Quote 0
            AlexTh @PCR
            @pcr I can't find the PA value, because the perimeter prints well, and only the beginning of the line with high underextrusion.
            undefined 1 Reply Last reply 23 Nov 2021, 10:39 Reply Quote 0
              PCR @AlexTh
              @alexth which printer? A PA value of 0,1 is quite high
              undefined undefined 2 Replies Last reply 23 Nov 2021, 10:39 Reply Quote 0
                PCR @PCR
                @pcr for a direct drive
                  AlexTh @PCR
                  @PCR
                  Flying Bear 5
                  Long direct
                  ~10 cm
                  undefined 1 Reply Last reply 23 Nov 2021, 10:45 Reply Quote 0
                    PCR @AlexTh
                    @alexth start with S0 and increase?
                    undefined 2 Replies Last reply 23 Nov 2021, 10:47 Reply Quote 0
                      AlexTh @PCR
                      @pcr I've tried different values. Can't set up.
                      But I'll try again
                        AlexTh @PCR
                        @pcr M572 D0 S0.07 is a more appropriate value, there is no underextrusion at the beginning of the line, but the outer corners of the model are slightly outward. For the perimeter, this value is not ideal.
                        undefined 1 Reply Last reply 23 Nov 2021, 11:27 Reply Quote 0
                          PCR @AlexTh
                          @alexth please print a tuning tower from S0 to S0.1 and show the pictures
                          undefined 1 Reply Last reply 23 Nov 2021, 12:14 Reply Quote 0
                            AlexTh @PCR
                            @pcr Give me a link to the test
                            undefined 1 Reply Last reply 23 Nov 2021, 12:22 Reply Quote 0
                              PCR @AlexTh
                              @alexth https://duet3d.dozuki.com/Wiki/Pressure_advance
                              or
                              https://forum.duet3d.com/topic/25764/pressure-advance-tuning-with-conditional-g-code?_=1635840827943
                              21 out of 25
