    Vivedino Troodon Board (non-working w/RRF >=3.1).
    Other control boards
    9
    39
    3.4k
    • o_lampeundefined
      o_lampe @oliof
      @oliof I tried to find their TMC2660 drivers sold separately, but computer says NO
      Would be cool to add them as driver 10+11 to a Duet2. For now we can only use external drivers without SPI on the CONN_LCD pins.
      jay_s_ukundefined oliofundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @o_lampe
        @o_lampe won't these do? https://www.digikey.co.uk/en/products/detail/trinamic-motion-control-gmbh/TMC2660-BOB/8037672
        • o_lampeundefined
          o_lampe @jay_s_uk
          @jay_s_uk Theoretically yes, but are they built for 24/7 stress? They aren't exactly cheap either...
          • oliofundefined
            oliof @o_lampe
            @o_lampe you can buy the drivers directly from them, choose the driver as the purchase option on https://www.formbot3d.com/products/troodon-mother-board-and-touch-screen
            oliofundefined 1 Reply Last reply Reply Quote 1
            • oliofundefined
              oliof @oliof
              @o_lampe please note that these are not stepstick compatible drivers! So they won't fit onto a BTT MOT board. You'll need to spin your own bigfoot compatible board or wire them up directly.
              • o_lampeundefined
                o_lampe @oliof
                @oliof The biggest question is, whether we could add them to the SPI bus or not? It would be nice to have an adapter board on the CONN_LCD connector, like it existst for Maestro and D3Mini.
                • tak21undefined
                  tak21 @oliof
                  @oliof I recently got a Troodon v2 and wanted to go beyond RRF 3.0 - which is not possible. Now your post says you had success with 3.4? I am in no means skilled enough to try this but if I understand your post, there is hope that I can - sometimes in the hopeful near future - upgrade to 3.4?
                  PCRundefined 1 Reply Last reply Reply Quote 0
                  • PCRundefined
                    PCR @tak21
                    @tak21 you can Just use 3.4 Beta 5?
                    tak21undefined 1 Reply Last reply Reply Quote 1
                    • tak21undefined
                      tak21 @PCR
                      @pcr oh well ... why should it be so easy (...) THX I will try that 🙂
                      • ccollinscjundefined
                        ccollinscj @oliof
                        @oliof what does IIRC stand for?
                        • oliofundefined
                          oliof
                          "if I recall correctly"
                          ccollinscjundefined 1 Reply Last reply Reply Quote 0
                            ccollinscj @oliof
                            @oliof Thank you sir......:)
