Vivedino Troodon Board (non-working w/RRF >=3.1).
@jay_s_uk Theoretically yes, but are they built for 24/7 stress? They aren't exactly cheap either...
@o_lampe you can buy the drivers directly from them, choose the driver as the purchase option on https://www.formbot3d.com/products/troodon-mother-board-and-touch-screen
@o_lampe please note that these are not stepstick compatible drivers! So they won't fit onto a BTT MOT board. You'll need to spin your own bigfoot compatible board or wire them up directly.
@oliof The biggest question is, whether we could add them to the SPI bus or not? It would be nice to have an adapter board on the CONN_LCD connector, like it existst for Maestro and D3Mini.
@oliof I recently got a Troodon v2 and wanted to go beyond RRF 3.0 - which is not possible. Now your post says you had success with 3.4? I am in no means skilled enough to try this but if I understand your post, there is hope that I can - sometimes in the hopeful near future - upgrade to 3.4?
@tak21 you can Just use 3.4 Beta 5?
@pcr oh well ... why should it be so easy (...) THX I will try that
@oliof what does IIRC stand for?
"if I recall correctly"
@oliof Thank you sir......:)
