    Phi: Open-source, Wi-Fi + Ethernet, RRF 3D Printer Controller
    Other control boards
    2.4k
      droftarts administrators @likhalabs
      @likhalabs said in Phi: Open-source, Wi-Fi + Ethernet, RRF 3D Printer Controller:
      I decided to try my hand at integrating an ESP32 on a 3D printer controller to assume the same functions an SBC would, as nobody was doing it.
      Interesting work! Does the ESP32 run your own custom firmware, or is it running a form of dsf (like a Raspberry Pi does)?
      likhalabsundefined 1 Reply Last reply Reply Quote 0
      • likhalabsundefined
        likhalabs @droftarts
        @droftarts Its a partial port of RepRapFirmware to run on top of ESP-IDF, actually. I've mentioned that the ESP32 is in charge of networking, sd card, displays, usb, etc. so I've ported only the relevant parts to these functions and disabled or excluded from build others.
        • zaptaundefined
          zapta @likhalabs
          @likhalabs, can it use the Duet Mini5 binaries or will you release your own binaries for RRF and Klipper?
          likhalabsundefined 1 Reply Last reply Reply Quote 1
            likhalabs @zapta
            @zapta No, it can't use Duet 3 Mini 5+ binaries, so I will be releasing Phi's own RRF binaries.
            RepRapFirmware will be the 'official' firmware, so I will not be maintaining a Klipper port and releasing Klipper binaries. However, there is nothing preventing members of the community from porting other firmware like Marlin or Klipper to Phi, as like I've mentioned, full schematic + PCB layout will be released.
              likhalabs @likhalabs
              The campaign is live! Please check it out if you're interested.
                likhalabs
                I've been trying to improve upload speed for Phi. Finally broke the 1MiB/s barrier!
                There's still some room for improvement, though.
                oliofundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 1
                • oliofundefined
                  oliof @likhalabs
                  @likhalabs is that on Ethernet or Wifi?
                    jay_s_uk @likhalabs
                    @likhalabs the STM port gets 1.6Mib/s with an ESP32
                    • botundefined
                      bot
                      When can we have one with 6 steppers? 🙂
                      *not actually a robot
                        likhalabs @jay_s_uk
                        @jay_s_uk Usually, small 'b' denotes bits and big 'B' denotes bytes. Just to clarify, is it bits or bytes in the case of the STM32 port?
                          likhalabs @oliof
                          @oliof Hi oliof, this is on Wi-Fi. Ethernet is a little slower, around 900 KiB/s - 1 MiB/s so far. Ethernet is slower because it's not native (ESP32-S3 does not have an Ethernet peripheral, is using a W5500 Ethernet <-> SPI chip).
                            likhalabs @bot
                            @bot Unfortunately since I'm a one-man team, it will be after the current board gets off the ground. Though it's possible to add https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_Mini_2plus for a total of 7 steppers (like the Duet 3 Mini 5+).
                              jay_s_uk @likhalabs
                              @likhalabs sorry. B not b.
                              So 1.6MiB/s
                                likhalabs @jay_s_uk
                                @jay_s_uk Thanks for the clarification! Looks like I have a new benchmark. (There still some room for improvement, like I said). I have an SKR pro and lots of ESP32's lying around to test and see how its achieving that speeds.
                                In theory at least, I should be able to achieve faster speeds since the data does not have to travel between microcontrollers through an SPI link (same theory why ethernet is slower as mentioned in the reply to @oliof).
                                • botundefined
                                  bot @likhalabs
                                  @likhalabs fair enough. I love the path you're on so I'm excited to see you progress.
                                  • o_lampeundefined
                                    o_lampe @bot
                                    @bot said in Phi: Open-source, Wi-Fi + Ethernet, RRF 3D Printer Controller:
                                    When the thread started I thought it was a good idea to have an ESP32 as RasPi replacement. The RasPi4 felt like 1000x overkill for the few tasks it had to do as SBC.
                                    But the task list will grow in the future and I'm not sure how much headroom there is for the ESP32?
                                    Could we program post pocessing scripts for it? I know there's MicroPython for ESP32, would it run on your environment?
                                    @likhalabs If I'd be you, I'd look for Linux driven alternatives for new projects. (eg. header for RasPi Zero 2W)
                                      likhalabs @o_lampe
                                      @o_lampe Although the ESP32 is much less powerful than the Pi's, it still packs some grunt. People have been running image and audio processing on it, after all.
                                      It's hard to quantify how much headroom there is for ESP32 (one thing that is sure is that it's much less than the Pi). However, to get some idea, the current 'heaviest' workload would be networking, particularly uploading a G-code file. It hovers around 8% of CPU time when uploading a file.
                                      Anything super computationally expensive would be out of the question for the ESP32, I think. One example I can think of is on-device 'spaghetti detection'. However, even the RasPi4 is not recommended for that.
                                      I mean, there is a MicroPython/CircuitPython port to the ESP32, but it would need to be integrated into RepRapFirmware. Again, anything super computationally expensive might be out of the question. But for simple custom manipulation of pins & peripherals, it could conceivably run. For example, sending out a custom color animation on Neopixels when a print is finished.
                                      • o_lampeundefined
                                        o_lampe @likhalabs
                                        So the bottleneck is not the CPU. That's already good news. Then there's enough CPU-time left to do simple post processing on gcode files.
                                        How much RAM/flash is left over on the ESP32, when running RRF?
                                          likhalabs @o_lampe
                                          @o_lampe So for the RAM, I currently opted to use any free RAM for network buffers. However, ESP32-S3 supports external PSRAM up to 8MB.
                                          The firmware is about 1.5MB. Phi has a module with 8MB flash.
