    PrusaSlicer with better RRF time estimates.
    3.0k
    • PCRundefined
      PCR @PCR
      @pcr and would you change the mm/s to mm/min for the jerk? 😉
      • botundefined
        bot @PCR
        @pcr Yeah I was thinking of that. I have a lot of open PR right now, and some of them are silly, so they might not take yet another PR seriously at the moment. I will test it out some more, and let users test it out, before submitting it to them.
        One thing that is bugging me about my current workaround implementation is how to handle "stealth mode." afaik, it does not affect anything negatively to include it as is with RRF, it simply provides a second time estimate based on a second set of values. I suspect the Prusa team will not like that integration, but it might not bother them.
        *not actually a robot
        • botundefined
          bot @PCR
          @pcr the mm/s to mm/min for jerk is taken care of behind the scenes, if you emit to gcode.
          The time estimator uses mm/s, and I don't want to mess with that (less is more in this case. if I can leave something alone, better).
          So, simply input your jerk values as mm/s, and the app will take care of the rest. If you emit the values to gcode, it will use m566 with mm/min if you have RRF as the g-code flavor.
          PCRundefined 1 Reply Last reply Reply Quote 0
            I'll take a look next time I print something. Good luck with the PRs
            • PCRundefined
              PCR @bot
              @bot AH PERFECT!
              Really great work. Is it possible to get a Linux version too?
              • botundefined
                bot @PCR
                @pcr I don't have any PCs with linux distros, but there are build instructions for linux it should not be hard. I was just thinking about getting that set up today. I made a few commits that might be useful or not for isolating any linux builds from stock prusaslicer. macOS threw me a curve ball and now I'm worried about linux.
                Could you try and build from source and see how it works out?
                • PCRundefined
                  PCR @bot
                  YEP 😉
                  • botundefined
                    bot @PCR
                    @pcr Very nice! Thank you!
                    Where is the .ini settings file saved? is it /users/user/Library/Application Support/PrusaSlicer-n8/ ? Or is it in a folder named just PrusaSlicer? This is important to keep the n8 version separate form the stock version.
                    Also, the PrusaSlicer.desktop file might not be configured correctly. I don't even know what it's for really. Does the correct name and icon appear for the app in your desktop environment?
                    Please don't hesitate to let me know of any issues you encounter I'd be happy to hear about them. I've never had it running on linux! Linux looks nice. What desktop environment you using?
                    • botundefined
                      bot @PCR
                      @pcr I ended up making a PR anyway, so feel free to comment with any desired changes or problems:
                      https://github.com/prusa3d/PrusaSlicer/pull/7347
                      n8bot opened this pull request in prusa3d/PrusaSlicer
                      closed Add compatibility for Machine Limits with RepRapFirmware G-code flavor #7347
                      • PCRundefined
                        PCR @bot
                        @bot when will you merge upstream ;)))) hehe beta 2 is out
                        • botundefined
                          bot @PCR
                          @pcr there is really not much added since I compiled this. Mine is basically beta2, except a few tiny bug fixes. If you need anything specific let me know. I have a beta2 branch that you can compile: n8-240b2
                          PCRundefined 1 Reply Last reply Reply Quote 1
                          • PCRundefined
                            PCR @bot
                            @bot thankk you. Really like your improvements
                            • rjenkinsgbundefined
                              rjenkinsgb
                              Off topic, but people on here are are familiar with Prusaslicer and it's useful for anyone else starting with it:
                              How the *$%£^!! do you get it to select a tool/extruder??
                              I have three tools defined.
                              As it is, the GCode has
                              M104 S240 ; set temperature
                              before the start gcode or any tool selection.
                              For a multi-tool machine it needs the appropriate tool / extruder selection before any related settings, but I cannot find how to do that?
                              It looks really good; I grabbed it last night and have spent a few hours going through the settings & trying to figure out all the appropriate options, and done a lot of searching, but just cannot find this info.
                              Up to now, I've only ever used Cura, an old version originally specified for use with my Overlord pro delta printer.
                              It's always worked fine for that, but is rather restricted for the Duet-based machine.
                              In that, I've been setting the correct tool in the start gcode; nothing is sent before the start sequence.
                              Robert J.
                              Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                              • botundefined
                                bot @rjenkinsgb
                                @rjenkinsgb you have to put it in your start g-code. Also, select "RepRapFirmware" g-code flavor.
                                • botundefined
                                  bot
                                  I definitely released the n8 version of 2.4.0-beta2.
                                  It is... colourful. 😈 😹 👾 🤐 🕵
                                  https://github.com/n8bot/PrusaSlicer/releases
                                  • botundefined
                                    bot
                                    Spammmming my own thread
                                    PCRundefined 1 Reply Last reply Reply Quote 2
                                    • PCRundefined
                                      PCR @bot
                                      @bot That is really good!
                                      • botundefined
                                        bot @PCR
                                        @pcr Thank you! Let me know how you feel after a few days.
                                        At first, I was reluctant about the colours but I went with what seemed to be best practices. I have since fallen in love with the colours. Dat sequential magma spectrum...
                                        PCRundefined 2 Replies Last reply Reply Quote 1
                                        • PCRundefined
                                          PCR @bot
                                          @bot will do.
                                          Just have to adjust the hash of a file....
                                          See my PR on upstream 😉
                                          https://github.com/prusa3d/PrusaSlicer/pull/7380
                                          P-C-R opened this pull request in prusa3d/PrusaSlicer
                                          closed Update Hash of wxWidgets #7380
                                            rjenkinsgb
                                            I did my first print using your slicer version yesterday afternoon/evening.
                                            The time estimate was spot on.
                                            And, the print quality is vastly better than the old Cura slicer I use with my Overlord Pro and initially used for the Duet machine!
                                            The item sides have no noticeable layer lines or ripples, just a really good result.
                                            Thanks!
                                            Robert J.
