    PrusaSlicer with better RRF time estimates.
    3.1k
    • PCRundefined
      PCR @bot
      @bot AH PERFECT!
      Really great work. Is it possible to get a Linux version too?
      • botundefined
        bot @PCR
        @pcr I don't have any PCs with linux distros, but there are build instructions for linux it should not be hard. I was just thinking about getting that set up today. I made a few commits that might be useful or not for isolating any linux builds from stock prusaslicer. macOS threw me a curve ball and now I'm worried about linux.
        Could you try and build from source and see how it works out?
        *not actually a robot
        PCRundefined 1 Reply Last reply Reply Quote 0
        • PCRundefined
          PCR @bot
          YEP 😉
          • botundefined
            bot @PCR
            @pcr Very nice! Thank you!
            Where is the .ini settings file saved? is it /users/user/Library/Application Support/PrusaSlicer-n8/ ? Or is it in a folder named just PrusaSlicer? This is important to keep the n8 version separate form the stock version.
            Also, the PrusaSlicer.desktop file might not be configured correctly. I don't even know what it's for really. Does the correct name and icon appear for the app in your desktop environment?
            Please don't hesitate to let me know of any issues you encounter I'd be happy to hear about them. I've never had it running on linux! Linux looks nice. What desktop environment you using?
            • botundefined
              bot @PCR
              @pcr I ended up making a PR anyway, so feel free to comment with any desired changes or problems:
              https://github.com/prusa3d/PrusaSlicer/pull/7347
              n8bot opened this pull request in prusa3d/PrusaSlicer
              closed Add compatibility for Machine Limits with RepRapFirmware G-code flavor #7347
              • PCRundefined
                PCR @bot
                @bot when will you merge upstream ;)))) hehe beta 2 is out
                • botundefined
                  bot @PCR
                  @pcr there is really not much added since I compiled this. Mine is basically beta2, except a few tiny bug fixes. If you need anything specific let me know. I have a beta2 branch that you can compile: n8-240b2
                  PCRundefined 1 Reply Last reply Reply Quote 1
                  • PCRundefined
                    PCR @bot
                    @bot thankk you. Really like your improvements
                    • rjenkinsgbundefined
                      rjenkinsgb
                      Off topic, but people on here are are familiar with Prusaslicer and it's useful for anyone else starting with it:
                      How the *$%£^!! do you get it to select a tool/extruder??
                      I have three tools defined.
                      As it is, the GCode has
                      M104 S240 ; set temperature
                      before the start gcode or any tool selection.
                      For a multi-tool machine it needs the appropriate tool / extruder selection before any related settings, but I cannot find how to do that?
                      It looks really good; I grabbed it last night and have spent a few hours going through the settings & trying to figure out all the appropriate options, and done a lot of searching, but just cannot find this info.
                      Up to now, I've only ever used Cura, an old version originally specified for use with my Overlord pro delta printer.
                      It's always worked fine for that, but is rather restricted for the Duet-based machine.
                      In that, I've been setting the correct tool in the start gcode; nothing is sent before the start sequence.
                      Robert J.
                      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                      • botundefined
                        bot @rjenkinsgb
                        @rjenkinsgb you have to put it in your start g-code. Also, select "RepRapFirmware" g-code flavor.
                        • botundefined
                          bot
                          I definitely released the n8 version of 2.4.0-beta2.
                          It is... colourful. 😈 😹 👾 🤐 🕵
                          https://github.com/n8bot/PrusaSlicer/releases
                          • botundefined
                            bot
                            Spammmming my own thread
                            PCRundefined 1 Reply Last reply Reply Quote 2
                            • PCRundefined
                              PCR @bot
                              @bot That is really good!
                              • botundefined
                                bot @PCR
                                @pcr Thank you! Let me know how you feel after a few days.
                                At first, I was reluctant about the colours but I went with what seemed to be best practices. I have since fallen in love with the colours. Dat sequential magma spectrum...
                                PCRundefined 2 Replies Last reply Reply Quote 1
                                • PCRundefined
                                  PCR @bot
                                  @bot will do.
                                  Just have to adjust the hash of a file....
                                  See my PR on upstream 😉
                                  https://github.com/prusa3d/PrusaSlicer/pull/7380
                                  P-C-R opened this pull request in prusa3d/PrusaSlicer
                                  closed Update Hash of wxWidgets #7380
                                    rjenkinsgb
                                    I did my first print using your slicer version yesterday afternoon/evening.
                                    The time estimate was spot on.
                                    And, the print quality is vastly better than the old Cura slicer I use with my Overlord Pro and initially used for the Duet machine!
                                    The item sides have no noticeable layer lines or ripples, just a really good result.
                                    Thanks!
                                    Robert J.
                                    • PCRundefined
                                      PCR @bot
                                      @bot
                                      https://anonfiles.com/l8Hb19Yau7/PrusaSlicer_n8_b2-x86_64_AppImage
                                      Linux AppImage Build 😉
                                      botundefined 2 Replies Last reply Reply Quote 1
                                      • botundefined
                                        bot @PCR
                                        @pcr Very nice!! Thank you.
                                        I saw that it's somewhat easy to do: use an existing app image, replace all the files. (Don't forget the resources folder! That's where the opengl shaders are located)
                                        I wonder if this process is possible to do on macOS? I would hate to have to bug you every time to make an appimage for me! lol.
                                        • botundefined
                                          bot @PCR
                                          @pcr Hey hey hey would you like to make an appimage for this latest release? Make sure you include the Resources folder from this release, because that is where the shaders are... and that is the main improvement!
                                          https://github.com/n8bot/PrusaSlicer/releases/tag/version_2.4.0-beta2-release2-n8
                                          • PCRundefined
                                            PCR @bot
                                            @bot here ya go
                                            https://anonfiles.com/56F150Ybu3/PrusaSlicer_n8_beta2_release2-x86_64_AppImage
                                            and yes i am repacking the original prusa slicer appimage 😉 thats faaaarrr easier
