Solved BLT on Duet wifi problem
Did you update your deploy and retract macros? Please post those.
Also test if M401 and M402 work to deploy and retract the pin.And for good measure include the results of sending M122 and M98 P"config.g"
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.3.6 on Fri Nov 26 2021 13:06:38 GMT+0100 (Centraleuropæisk normaltid) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-335 Y-341 F1800 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X-335 ; home X axis G1 H1 Y-341 ; home Y axis G1 X5 Y5 F6000 ; go back a few mm G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y-341 ; then move slowly to Y axis endstop G1 H1 Z-395 F360 ; move Z down stopping at the endstop G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
Here is the home all. Thanks for the tip on the code mode.
This post is deleted! -
@gibsea402 This is the section of your homeall that you want to change
It is using a G1 H1 homing move for Z (i.e. using an endstop which you don't have!), rather than a probing move using the BLTouch. For this you would want to use a G30 probing move (https://duet3d.dozuki.com/Wiki/G30)
So, I would suggest replacing those three lines of code with:
G90 ; set absolute positioning G1 X150 Y150 F1800 ; move quickly to bed centre - May need to change the X/Y values to suit your printer size G30 ; probe with BLTouch
You'll see that these commands are in @Arnold_R_Clark's homeall file (though he also has a bunch of extra stuff which may confuse things).
@phaedrux
Hi here is the following. I think the issue is that the macro is not updated. But i am not sure how to do that.Pin down: M280 P3 S10 I1
Pin Up: M280 P3 S90 I1 ; retract BLTouchIf i click on the macros in the web browser they do not work. But if i send the commands M401 and M402 they work.
Result of M122:
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later Used output buffers: 3 of 24 (23 max) === RTOS === Static ram: 23876 Dynamic ram: 75312 of which 148 recycled Never used RAM 15080, free system stack 184 words Tasks: NETWORK(ready,13.7%,227) HEAT(delaying,0.0%,314) Move(notifyWait,0.1%,364) MAIN(running,86.2%,387) IDLE(ready,0.0%,29), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:04:06 ago, cause: power up Last software reset at 2021-11-30 16:41, reason: User, GCodes spinning, available RAM 12148, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x08 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 29.4, current 29.9, max 30.2 Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2021-11-30 16:56:35 Cache data hit count 4294967295 Slowest loop: 5.02ms; fastest: 0.17ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.3ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 200.17ms; fastest: 0.08ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 2 WiFi firmware version 1.26 WiFi MAC address d8:bf:c0:fc:2a:7e WiFi Vcc 3.39, reset reason Turned on by main processor WiFi flash size 4194304, free heap 25784 WiFi IP address 192.168.87.164 WiFi signal strength -50dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
Results of M98:
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Error: Pin 'fan1' is not free Error: Fan number 2 not found Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 205C
Hope you can help me
This seem to work. But if i just give the g30 command the probe is not deploying.
@gibsea402 said in BLT on Duet wifi problem:
Which macros exactly are you clicking on? M401 and M402 call the deployprobe.g and retractprobe.g files in the /sys folder
Pin Up: M280 P3 S90 I1 ; retract BLTouchThose are incorrect for RRF3. Remove the I1 and instead of P3 you'd use P0 since you are using servo pin 0
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned onOne of those fan1 should be fan2
In the macro folder on the web control site
Thanks! this helped alot! its all working now
