Solved Duet 3 XYZ Optical End Stops configuration
Are they active high or active low?
If the M119 shows not stopped when they are in fact stopped, you need to invert the signal pin by adding a
in front of the pin name.Example:
M574 X1 S1 P"!xstop" ; X min active high endstop switch M574 Y1 S1 P"!ystop" ; Y min active high endstop switch
Have you seen this> https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches
tried that also, same result. Seems a dead end so far.
What board are you using?
What firmware are you using?
I'm not aware of any Duet 3 board with those pin names.
@fcwilt said in Duet 3 XYZ Optical End Stops configuration:
Duet 3 / RR3 what is the pin name for IO_0
@dingo007 said in Duet 3 XYZ Optical End Stops configuration:
Here are some endstop setups taken from one of my printers using a Duet 3 Mini 5 running firmware 3.3.
; **************************************************************************************************** ; end stops ; -- X,Y,Z,etc = location of endstop (0 = none, 1 = low end, 2 = high end) ; -- S = type (1 = switch, 2 = probe, 3 = motor stall (one), 4 = motor stall (multiple) ; -- ! = invert ^ = enable pull-up ; **************************************************************************************************** M574 X1 S1 P"!io6.in" M574 Y2 S1 P"!io5.in" M574 Z1 S1 P"io4.in"
welp tried this
; end stops
; ****************************************************************************************************M574 X1 S1 P"^io0.in"
M574 Y1 S1 P"^io1.in"
M574 Z1 S1 P"io7.in"; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speedsG31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh gridand
M119
Endstops - X: not stopped, Y: not stopped, Z: no endstop, Z probe: not stoppedbut if i trigger it, movew X to home manually, M119 says the same
Can you take and post a photo of the endstop connections to the board?
With firmware 3.3 (and probably newer) you can view endstop status with the DWC Object Model selection.
And, just FYI, with a Duet 3 board you don't need to use the ^ character as the pullup resistors are always active.
ok so now X homes fine, Y doesntM574 X1 S1 P"!io0.in"
M574 Y1 S1 P"!io2.in"
M574 Z1 S2 P"io7.in"; Z-Probe
M557 X15:215 Y15:195 S20 ; define mesh grid -
@dingo007 welp a multimeters says it appears i have a bad cable, no power at the endstop, but 5.24v at the header pins
so to update all.... i have a new cable and end stop on the way... and yet what do i find....
the simplest of mistakes by reversing black and white wires by the builder, I chase issues for 2 days.
@fcwilt i have the proper omron cables being delivered tomorrow, no idea why they solder these ends.
I'm sure I would have caught on eventually. Nice catch.
@dingo007 and this is fixed now, XYZ all home correctly now,
thanks for the config hint
; end stops
; ****************************************************************************************************M574 X1 S1 P"!io0.in"
M574 Y1 S1 P"!io1.in"
Glad to hear all is working.
Just FYI that M574 for Z is not needed.
From the docs:
The S2 option of M574 is intended for use only when axes other than Z are using the Z probe for homing. The only printers known that do this using Duet electronics are the RepRapPro Ormerod, Huxley Duo, and Mendel Tricolour machines. When using the Z probe to home Z, M574 Z has no bearing on the probe setup or usage. A Z probe and a Z endstop can both be configured at the same time. G30 calling the probe setup with M558, and G1 H1 Z moves calling the endstop configured with M574 Z.
