Solved Printer cant be connected anymore
Can you try reaching it from a different computer/browser?
When connected to USB terminal can you send M20 P"/www/" to see if it will read back the contents of the DWC files folder.
Note that 192.168.0.254 (or 1.254) are default address for some internet / ethernet devices.
Try a different ethernet address & see if that works differently, eg. 0.230
well I already did tested that - and I am also my own network admin so I checked in my network settings the IPs, and I also tryed to give the MAC address a fixed IP from my network and writing "M552 S1 P0.0.0.0 " in the config.g file however it did not worked at all. I was not able to even find the printer in my own (ethernet) network.
My guess now would be that I eather have a hardware Issue with the network controller section or I might have some issues with the soft/firmware sigth. However I doubt that it is software related - because of the fact that it randomly stopped working without any external influence.
I am open for some other inputs.
When and where did you purchase your Duet Ethernet?
@phaedrux
I bought it in 05/2020 from the german duet seller Dold Mechatronik. -
@phaedrux said in Printer cant be connected anymore:
@humbleJoe can you try this suggestion please
Sure
this is what i got as feedback:
M20 P"/www/" Begin file list dwc.json favicon.ico.gz html404.htm language.xml.gz reprap.htm.gz css fonts js img index.html.gz manifest.json.gz precache-manifest.a4ab8f573fcc203b798fa7d11eee39d5.js.gz service-worker.js.gz DuetAPI.xml Main_FW-V_2.05_DuetETH End file list ok
That doesn't look quite right to me. Did you delete the existing /www/ folder before replacing the contents with the zip file I linked previously?
@phaedrux
I thought I did - but it looks like i only overwrote the files with same name.....
However I now did deleated the old files first, copied in the new one and tested again. Still no connection.
Here is what I get now as feedback on M20 P"/www/" in YAT.
(BTW. I tested now multiple IP adresses, without any success )M552 Network is enabled, configured IP address: 192.168.0.200, actual IP address: 192.168.0.200 ok M20 P"/www/" Begin file list css fonts img js DuetAPI.xml favicon.ico.gz index.html.gz manifest.json.gz precache-manifest.a4ab8f573fcc203b798fa7d11eee39d5.js.gz service-worker.js.gz End file list ok
@humblejoe can you try reinstalling RRF 3.3. Redownload the Duet2Combinedfirmware.bin from the Releases on github and put it in the /firmware directory on the sd card (along with the IAP file if its not there already) and then use M997 from YAT.
I did as you said and it "kind of worked".
So i am now able to get connected to the board. However when ever I make a change in the config.g file (eather by putting SD in PC or by web edit) the system will not be able to get connected again. (f.ex. I changed the IP adress and after that I was not able to connect to the printer (on eather IP adress.
So far I havent tested that much but I will try to soon to maybe get an idea.
