    Printer cant be connected anymore
    Duet Web Control
    700
    • humbleJoeundefined
      humbleJoe
      sure 🙂
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet Ethernet 1.02 or later
      Board ID: 08DGM-917NK-F2MSW-6JKF2-3SN6K-1G6NG
      Used output buffers: 1 of 24 (3 max)
      Static ram: 23876
      Dynamic ram: 74416 of which 0 recycled
      Never used RAM 16124, free system stack 193 words
      Tasks: NETWORK(ready,23.7%,464) HEAT(delaying,0.0%,278) Move(notifyWait,0.1%,340) MAIN(running,76.2%,467) IDLE(ready,0.0%,29), total 100.0%
      Owned mutexes: USB(MAIN)
      Last reset 01:04:35 ago, cause: power up
      Last software reset at 2021-11-15 22:30, reason: User, GCodes spinning, available RAM 16124, slot 1
      Error status: 0x00
      Step timer max interval 0
      MCU temperature: min 18.0, current 21.1, max 21.6
      Supply voltage: min 1.3, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: position 0, ok, SG min/max not available
      Driver 1: position 0, ok, SG min/max not available
      Driver 2: position 0, ok, SG min/max not available
      Driver 3: position 0, ok, SG min/max not available
      Driver 4: position 0, ok, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Slowest loop: 5.28ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.1ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.47ms; fastest: 0.01ms
      HTTP sessions: 0 of 8
      Interface state active, link 100Mbps full duplex
      ok
      M552
      Network is enabled, configured IP address: 192.168.0.254, actual IP address: 192.168.0.254
      ok
        I don't speak German, but it seems like it's pinging the address correctly?
        Let's try replacing the DWC files on the SD card. Or in fact, if you have another SD card to try, please try that as well. Copy over the contents of your existing card and then refresh the DWC files in the /www folder with the files from this zip file.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWebControl-SD.zip
        humbleJoeundefined 1 Reply Last reply Reply Quote 0
          humbleJoe @Phaedrux
          @phaedrux
          Well the ping was correct.
          I did changed the SD Card and also overwrote the www folder with a new build.
          I also changed the IP address in the config and testet that. But nothing changed.
          Still not able to reach the webclient, but ping and everything else looks fine.
            Can you try reaching it from a different computer/browser?
            When connected to USB terminal can you send M20 P"/www/" to see if it will read back the contents of the DWC files folder.
            • rjenkinsgbundefined
              rjenkinsgb
              Note that 192.168.0.254 (or 1.254) are default address for some internet / ethernet devices.
              Try a different ethernet address & see if that works differently, eg. 0.230
              Robert J.
              Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                humbleJoe @rjenkinsgb
                @rjenkinsgb
                well I already did tested that - and I am also my own network admin so I checked in my network settings the IPs, and I also tryed to give the MAC address a fixed IP from my network and writing "M552 S1 P0.0.0.0 " in the config.g file however it did not worked at all. I was not able to even find the printer in my own (ethernet) network.
                My guess now would be that I eather have a hardware Issue with the network controller section or I might have some issues with the soft/firmware sigth. However I doubt that it is software related - because of the fact that it randomly stopped working without any external influence.
                I am open for some other inputs.
                  When and where did you purchase your Duet Ethernet?
                    humbleJoe @Phaedrux
                    @phaedrux
                    I bought it in 05/2020 from the german duet seller Dold Mechatronik.
                      T3P3Tony administrators @Phaedrux
                      @phaedrux said in Printer cant be connected anymore:
                      @humbleJoe can you try this suggestion please ☝
                        humbleJoe @T3P3Tony
                        @t3p3tony
                        Sure 🙂
                        this is what i got as feedback:
                        M20 P"/www/"
                        Begin file list
                        dwc.json
                        favicon.ico.gz
                        html404.htm
                        language.xml.gz
                        reprap.htm.gz
                        css
                        fonts
                        js
                        index.html.gz
                        manifest.json.gz
                        precache-manifest.a4ab8f573fcc203b798fa7d11eee39d5.js.gz
                        service-worker.js.gz
                        DuetAPI.xml
                        Main_FW-V_2.05_DuetETH
                        End file list
                        ok
                          That doesn't look quite right to me. Did you delete the existing /www/ folder before replacing the contents with the zip file I linked previously?
                            humbleJoe @Phaedrux
                            @phaedrux
                            I thought I did - but it looks like i only overwrote the files with same name.....
                            However I now did deleated the old files first, copied in the new one and tested again. Still no connection.
                            Here is what I get now as feedback on M20 P"/www/" in YAT.
                            (BTW. I tested now multiple IP adresses, without any success 😕 )
                            M552
                            Network is enabled, configured IP address: 192.168.0.200, actual IP address: 192.168.0.200
                            ok
                            M20 P"/www/"
                            Begin file list
                            css
                            fonts
                            js
                            DuetAPI.xml
                            favicon.ico.gz
                            index.html.gz
                            manifest.json.gz
                            End file list
                            ok
                              T3P3Tony administrators @humbleJoe
                              @humblejoe can you try reinstalling RRF 3.3. Redownload the Duet2Combinedfirmware.bin from the Releases on github and put it in the /firmware directory on the sd card (along with the IAP file if its not there already) and then use M997 from YAT.
                                humbleJoe @T3P3Tony
                                @t3p3tony
                                I did as you said and it "kind of worked".
                                So i am now able to get connected to the board. However when ever I make a change in the config.g file (eather by putting SD in PC or by web edit) the system will not be able to get connected again. (f.ex. I changed the IP adress and after that I was not able to connect to the printer (on eather IP adress.
                                So far I havent tested that much but I will try to soon to maybe get an idea.
                                • humbleJoeundefined humbleJoe has marked this topic as solved
