    Resume fails sometimes
    934
      Would you be willing to try the 3.4 betas to see if there is a difference in behaviour?
      Can you upload your config.g and other macros homing, pause, etc as files so that we can see if there is something odd going on?
      Duncanundefined 1 Reply Last reply Reply Quote 0
      • Duncanundefined
        Duncan @Phaedrux
        @phaedrux
        I have to finish some work in the machine and don't think can try new firmware on beta until 9th of December at least...
        About my files, they are on my previous replys to @T3P3Tony all of them, config, pause and the new resume I updated after see the one that was wrong.
          Phaedrux Moderator @Duncan
          @duncan said in Resume fails sometimes:
          I mean can you upload them as actual files, that way all characters are preserved incase there is a bad hidden character or something.
          • Duncanundefined
            Duncan @Phaedrux
            @phaedrux sorry, didn't understand what you were asking. Here they are.resume.g pause.g config.g
              I don't see anything strange in there. Can you send M98 P"config.g" and see if any errors come up?
              I look forward to seeing if the 3.4 release makes a difference here.
              Duncanundefined 2 Replies Last reply Reply Quote 0
              • Duncanundefined
                Duncan @Phaedrux
                @phaedrux I get this error:
                Error: Setting not available for external drivers
                Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                • Duncanundefined
                  Duncan @Phaedrux
                  @phaedrux any ideas? reading other issues of this error I think it's for the M350 and M906 that define X and Y motors that are with the external boards and drivers, but that can cause the problem of the resume?
                  Is this a known error in 3.3 version? that's why you're suggesting trying 3.4 beta?
                    There are many fixes between 3.3 and 3.4 so it would be helpful to know if those fixes have already solved your problem, or if it remains and requires further digging. Using the most recent code base makes that a bit easier.
                    • Duncanundefined
                      Duncan @Phaedrux
                      @phaedrux I test this morning and it's very strange.
                      If I use M600 and send the GCODE, the machine pause, and then I can use the resume button and works fine.
                      But if I use the Pause button always fails...
                      any ideas?
                        Is that after updating to 3.4 beta 6?
                        • Duncanundefined
                          Duncan @Phaedrux
                          @phaedrux no, still on 3.3.
                          I don't know if I upgrade to beta if I can fix one thing and break a couple more...
