    Resume fails sometimes
    961
    • Duncanundefined
      Duncan @T3P3Tony
      @t3p3tony
      This one should work?
      ; resume.g
      ; called before a print from SD card is resumed
      ; generated by RepRapFirmware Configuration Tool v3.3.5 on Tue Nov 23 2021 11:54:18 GMT+0100 (hora estándar de Europa central)
      G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
      G1 R1 X0 Y0 Z0       ; go back to the last print move
      M83                  ; relative extruder moves
      G1 E10 F3600         ; extrude 10mm of filament
        T3P3Tony administrators @Duncan
        @duncan it looks better.
        Duncanundefined 1 Reply Last reply Reply Quote 0
        • Duncanundefined
          Duncan @T3P3Tony
          @t3p3tony I try and first was try and error, here the M122 results
          M122
          RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (standalone mode)
          Board ID: 08DJM-9P63L-DJ3S0-7JTD4-3S86P-9AJM9
          Used output buffers: 1 of 40 (22 max)
          Static ram: 150904
          Dynamic ram: 92144 of which 0 recycled
          Never used RAM 108288, free system stack 142 words
          Tasks: NETWORK(ready,47.1%,224) ETHERNET(notifyWait,7.2%,117) HEAT(delaying,1.4%,325) Move(notifyWait,12.5%,247) CanReceiv(notifyWait,1.6%,774) CanSender(notifyWait,1.0%,362) CanClock(delaying,0.7%,339) TMC(notifyWait,132.8%,59) MAIN(running,49.8%,1092) IDLE(ready,0.0%,29), total 254.3%
          Owned mutexes:
          Last reset 117:09:14 ago, cause: power up
          Last software reset details not available
          Error status: 0x10
          Aux0 errors 0,0,31
          Step timer max interval 159
          MCU temperature: min 35.3, current 45.4, max 48.9
          Supply voltage: min 23.3, current 23.7, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0
          Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/180/168, gc cycles 0
          Driver 0: position 57128, standstill, reads 34586, writes 11 timeouts 0, SG min/max 0/0
          Driver 1: position 19315, standstill, reads 34520, writes 77 timeouts 0, SG min/max 0/516
          Driver 2: position 4736, standstill, reads 34520, writes 77 timeouts 0, SG min/max 0/537
          Driver 3: position 0, standstill, reads 34587, writes 11 timeouts 0, SG min/max 0/0
          Driver 4: position 0, standstill, reads 34521, writes 77 timeouts 0, SG min/max 0/544
          Driver 5: position 0, standstill, reads 34521, writes 77 timeouts 0, SG min/max 0/528
          Date/time: 2021-11-24 17:02:06
          Slowest loop: 244.06ms; fastest: 0.03ms
          === Storage ===
          Free file entries: 9
          SD card longest read time 1.1ms, write time 799.9ms, max retries 0
          DMs created 125, maxWait 26493523ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 5107, completed moves 5103, hiccups 0, stepErrors 0, LaErrors 0, Underruns [143, 23, 33], CDDA state 3
          === AuxDDARing ===
          Heater 0 is on, I-accum = 0.0
          Heater 1 is on, I-accum = 0.0
          Segments left: 1
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is doing "G1 X506.026 Y244.066 E49.3093" in state(s) 0
          USB is idle in state(s) 0
          Aux is assembling a command in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === Filament sensors ===
          Extruder 0 sensor: no filament
          === CAN ===
          Messages queued 12407519, received 5272477, lost 0, longest wait 1ms for reply type 6042, peak Tx sync delay 699, free buffers 49 (min 17), ts 2108775/2108774/0
          Tx timeouts 0,0,0,0,0,0
          === Network ===
          Slowest loop: 800.86ms; fastest: 0.02ms
          HTTP sessions: 1 of 8
          - Ethernet -
          State: active
          Error counts: 0 0 1 0 0
          M122 40
          Used output buffers: 1 of 40 (25 max)
          Static ram: 150904
          Tasks: NETWORK(ready,28.5%,224) ETHERNET(notifyWait,0.1%,117) HEAT(delaying,0.0%,325) Move(notifyWait,0.1%,247) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,362) CanClock(delaying,0.0%,339) TMC(notifyWait,8.0%,59) MAIN(running,63.3%,1092) IDLE(ready,0.0%,29), total 100.0%
          Owned mutexes: HTTP(MAIN)
          Last reset 117:10:02 ago, cause: power up
          Error status: 0x10
          Aux0 errors 0,0,0
          Step timer max interval 129
          MCU temperature: min 45.0, current 45.2, max 45.5
          Supply voltage: min 23.5, current 23.7, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
          Driver 0: position 58154, standstill, reads 3028, writes 0 timeouts 0, SG min/max not available
          Driver 1: position 19467, standstill, reads 3028, writes 0 timeouts 0, SG min/max 0/501
          Driver 2: position 4736, standstill, reads 3027, writes 0 timeouts 0, SG min/max 0/512
          Driver 3: position 0, standstill, reads 3027, writes 0 timeouts 0, SG min/max not available
          Driver 4: position 0, standstill, reads 3027, writes 0 timeouts 0, SG min/max 0/526
          Driver 5: position 0, standstill, reads 3027, writes 0 timeouts 0, SG min/max 0/511
          Date/time: 2021-11-24 17:02:54
          Slowest loop: 3.09ms; fastest: 0.05ms
          === Storage ===
          SD card longest read time 1.0ms, write time 0.0ms, max retries 0
          DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 5355, completed moves 5341, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
          === AuxDDARing ===
          Segments left: 1
          HTTP is ready with "M122 40" in state(s) 0
          File is doing "G1 X415.098 Y205.787 E0.4560 F4800" in state(s) 0
          === CAN ===
          Messages queued 1118, received 603, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 127, free buffers 49 (min 40), ts 240/240/0
          === Network ===
          Slowest loop: 3.44ms; fastest: 0.02ms
          - Ethernet -
          State: active
          M122 41
          Static ram: 150904
          Tasks: NETWORK(ready,28.4%,224) ETHERNET(notifyWait,0.1%,117) HEAT(delaying,0.0%,325) Move(notifyWait,0.1%,247) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,362) CanClock(delaying,0.0%,339) TMC(notifyWait,8.1%,59) MAIN(running,63.2%,1092) IDLE(ready,0.0%,29), total 100.0%
          Last reset 117:10:07 ago, cause: power up
          Error status: 0x10
          Aux0 errors 0,0,0
          Step timer max interval 125
          MCU temperature: min 44.9, current 45.0, max 45.2
          Supply voltage: min 23.4, current 23.7, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 60177, standstill, reads 25223, writes 0 timeouts 0, SG min/max not available
          Driver 1: position 18579, standstill, reads 25223, writes 0 timeouts 0, SG min/max 0/496
          Driver 2: position 4736, standstill, reads 25223, writes 0 timeouts 0, SG min/max 0/506
          Driver 3: position 0, standstill, reads 25223, writes 0 timeouts 0, SG min/max not available
          Driver 4: position 0, standstill, reads 25223, writes 0 timeouts 0, SG min/max 0/513
          Driver 5: position 0, standstill, reads 25223, writes 0 timeouts 0, SG min/max 0/506
          Date/time: 2021-11-24 17:02:59
          Slowest loop: 0.48ms; fastest: 0.05ms
          === Storage ===
          SD card longest read time 0.4ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          Scheduled moves 5374, completed moves 5366, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
          === AuxDDARing ===
          Segments left: 1
          HTTP is ready with "M122 41" in state(s) 0
          File is doing "G1 X415.097 Y237.788 E2.3978" in state(s) 0
          === CAN ===
          Messages queued 99, received 56, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 5, free buffers 49 (min 44), ts 23/23/0
          === Network ===
          Slowest loop: 2.43ms; fastest: 0.02ms
          - Ethernet -
          State: active
            Phaedrux Moderator @Duncan
            @duncan said in Resume fails sometimes:
            USUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUSUS
            definitely something sus about this one.... 🤔
            • Duncanundefined
              Duncan
              Now it seems to be failing all times I try to resume, any ideas?
                Would you be willing to try the 3.4 betas to see if there is a difference in behaviour?
                Can you upload your config.g and other macros homing, pause, etc as files so that we can see if there is something odd going on?
                • Duncanundefined
                  Duncan @Phaedrux
                  @phaedrux
                  I have to finish some work in the machine and don't think can try new firmware on beta until 9th of December at least...
                  About my files, they are on my previous replys to @T3P3Tony all of them, config, pause and the new resume I updated after see the one that was wrong.
                    I mean can you upload them as actual files, that way all characters are preserved incase there is a bad hidden character or something.
                    • Duncanundefined
                      Duncan @Phaedrux
                      @phaedrux sorry, didn't understand what you were asking. Here they are.resume.g pause.g config.g
                        I don't see anything strange in there. Can you send M98 P"config.g" and see if any errors come up?
                        I look forward to seeing if the 3.4 release makes a difference here.
                        Duncanundefined 2 Replies Last reply Reply Quote 0
                        • Duncanundefined
                          Duncan @Phaedrux
                          @phaedrux I get this error:
                          Error: Setting not available for external drivers
                          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                          • Duncanundefined
                            Duncan @Phaedrux
                            @phaedrux any ideas? reading other issues of this error I think it's for the M350 and M906 that define X and Y motors that are with the external boards and drivers, but that can cause the problem of the resume?
                            Is this a known error in 3.3 version? that's why you're suggesting trying 3.4 beta?
                              There are many fixes between 3.3 and 3.4 so it would be helpful to know if those fixes have already solved your problem, or if it remains and requires further digging. Using the most recent code base makes that a bit easier.
                              • Duncanundefined
                                Duncan @Phaedrux
                                @phaedrux I test this morning and it's very strange.
                                If I use M600 and send the GCODE, the machine pause, and then I can use the resume button and works fine.
                                But if I use the Pause button always fails...
                                any ideas?
                                  Is that after updating to 3.4 beta 6?
                                  • Duncanundefined
                                    Duncan @Phaedrux
                                    @phaedrux no, still on 3.3.
                                    I don't know if I upgrade to beta if I can fix one thing and break a couple more...
