    Which frame design can scale best?
    3D Printing General Chat
    11
    49
    3.5k
    • o_lampeundefined
      o_lampe @fcwilt
      @fcwilt said in Which frame design can scale best?:
      @kuon
      Wow. You could do amazing things with that beast.
      Yes you want to come up with a good design for allowing changing tools - hopefully without a lot of work.
      Instead of linear rails for the extruder -mini Z axes, you could use dovetail profiles. They could easily slide out for maintenance or tool changing.
      For a light load, I made my own PTFE sliders.
      • mikeabuilderundefined
        mikeabuilder
        Late replay, but @fcwilt, I am presently planning to use a single Z stepper. Mostly a limitation I've imposed on myself trying to stick with only the Duet3 and having enough drivers for a multi-extruder head. I'm planning some custom code during bed.g to measure some bed heights and tell me how much to adjust each of the front Kinematic balls under the bed.
        And regarding belt length, I think any arrangement that keeps both X and Y motors stationary will necessarily require at least one belt that is essentially a square that encloses the print area. Both CoreXY and MarkForged have this characteristic.
        Also, regarding belt stretch when comparing the MarkForges and a CoreXY, if you look at the MF picture in this thread, the largest forces on the either belt will be on accelerations and decelerations in the Y direction (you are trying to speed up or slow down the gantry and also the extruder on Y moves). The belt stretch should be less because the belt is shorter (approx half as long) than a CoreXY. However, in a CoreXY, you have two belts managing the same force, so the force on each belt is half, resulting in approximately the same amount of stretch.
        Regarding this whole topic, the thing that I think would be interesting is not so much "which is best", but "what are the tradeoffs". Each designer needs to make tradeoffs between many things to make a design that is right for their application. @kuon can't easily source laser cut steel they are, so that affects their decisions. I hate going into the machine shop, so that affects mine. Someone designing for high volume production will make different decisions. And a lot of the effects of our design decisions show up much later, and in things we didn't really think about at design time. So understanding the tradeoffs is valuable.
        kuonundefined fcwiltundefined 2 Replies Last reply Reply Quote 1
        • kuonundefined
          kuon @mikeabuilder
          @mikeabuilder I agree with what you said about tradeof. About belt length, I considered cross gantry because it has short belt and no moving steppers. I think it is the only arrangement that has those two qualities. I will try a real design with a cross gantry and see how it goes.
            deckingman
            On the subject of belt stretch, as I am often at pains to point out, do the maths. People get exited when they read something on the internet and see that applying a force of (say) 40 lbs) using a tensile test machine, gives elongation of about 0.6%. (That's just an example I found on the internet - it's not to be taken as fact). Look at data sheets if you can find them.
            But if you take the mass that you are going to move and multiply it by the acceleration, you'll find that the force that you are going to apply is so low that belt stretch is likely to be insignificant.
            By way of an example, I have what is considered to be a very heavy hot end because it has 6 inputs. Because of that I use a pair of parallel X rails which adds even more weight. The total moving mass in the Y direction is about 2 Kgs. I accelerate this at around 1000 mm/sec^2 which means that I'm applying a force of around 2 Newtons or around 200 gms or about 0.4lb to the belts. If the internet example is anything to go by (which I doubt) then that would mean I'd be looking at belt stretch of around 0.006%. But because this is CoreXY machine with two belts, then we can halve that again giving around 0.003%. And of course, that stretch will only apply to the section of belt between the attachment point on the carriage and the drive motor pulley. In my case, that's around 1.2 metres maximum giving about 0.036mm worse case. That's why I'm perfectly happy with my long, 6mm wide belts, despite the relatively high mass that I'm throwing around.
            Of course (and before someone leaps in to point it out) using a higher acceleration and/or mass will lead to a higher force but my point is simply just do the maths for your own situation before getting to exited about belt stretch.
            A Former User? 1 Reply Last reply Reply Quote 2
              A Former User @deckingman
              This post is deleted!
              kuonundefined 1 Reply Last reply Reply Quote 1
              • kuonundefined
                kuon @A Former User
                I fully agree with the math thing. I constantly try to do them, for things like beam deflection too. For the belt, I am still considering the high temp option I have.
                • fcwiltundefined
                  fcwilt @mikeabuilder
                  @mikeabuilder said in Which frame design can scale best?:
                  What board are you thinking of using?
                  You don't need custom code - that feature, Manual Bed Leveling, is part of the firmware.
                    mikeabuilder
                    I'm also in agreement on the math. Engineering is about understanding and you can't really understand without math.
                    But I also approach a lot of the engineering problems by trying to design to minimize undesirable forces even if I don't calculate their magnitude. For example, on a coreXY, there is a lot of talk about how to set the two belt tensions to be equal. Lots of phone apps and acoustic measurements. My coreXY designs (1.5, so far) use mechanisms to allow the two belts to be connected during tensioning so that they are naturally equalized. Then I lock the belts in place. This way, I avoid having to worry about the effects of unequal belt tension. Here's the overly complicated mechanism we're using on the printer at my maker-space, using a guitar tuning machine to allow us to "crank up the tension"
                    fdd26e3c-126c-452b-946d-388fa03148cc-image.png .
                    I also over-design where the cost is not high to do so. I use 10mm belts because it's not that much more expensive. 2040 vs 2020 extrusion, NEMA23 vs 17. This works because my printer design is just for me and I'm OK with the added costs. Other designers will have their own priorities.
                      mikeabuilder
                      @fcwilt, I've got a Duet3 6HC on hand. I'm using the 6 drivers for X,Y, Z, E0, E1, and one unused.
                      For leveling, I'll check out the process for assisted manual leveling. But I'm also thinking of coding up something just for fun with some constraints I want to place on myself. I don't want to adjust the rear support because it's hard to reach, and I'll have big thumb wheels on the two front bed supports. I thinking of code that I can use to calibrate the thumb-wheels (I know, it can be calculated, but where's the fun in that?), then the leveling code will tell me to turn each one right or left by a specific amount of rotation.
                      This is what happens when engineers retire...
                      • kuonundefined
                        kuon
                        Just to summarize a bit what I learned or confirmed in this thread:
                        • Always do the math, for belt stretch, beam deflection...
                        • No design is perfect and it's always tradeoffs.
                        • MarkdForge kinematic is a nice alternative to CoreXY
                        • Cross gantry might work with proper design (I will try it for fun (at least a CAD drawing, maybe not the construction))
                        • Ballscrews are overkill for 3d printer
                        • Belts can work on Z with gear/brake (or maybe even just 4 big steppers)
                        • Belt stretch can be smaller than we think, do the math
                        • There are some 1.75mm bowden drive (nimble)
                        • This forum is great
                        • fcwiltundefined
                          If you design the bed support with just 3 points (left front, rear center, right front) then you could use the firmware feature because it uses the first point probed as the reference and only computes the needed adjustments for the other two points probed. So you would probe rear center, left front, right front.
                          And three points do determine a plane.
                          engikeneerundefined 1 Reply Last reply Reply Quote 0
                          • engikeneerundefined
                            engikeneer @fcwilt
                            @fcwilt to be correct, you can probe as many points in whichever order you want. You just need to define the back adjustment screw as number one 🙂
                            @kuon we are looking forward to some pictures! Sounds like a beast of a machine
                            i3 clone with a bunch of mods
                            • fcwiltundefined
                              fcwilt @engikeneer
                              @engikeneer said in Which frame design can scale best?:
                              True but having tried varying numbers of points 3 seemed to work fine BUT I am using bed plates known to be flat within a certain spec.
                              • kuonundefined
                                kuon
                                Side question, does anybody know were to source genuine epdm gates belts in europe?
                                  mikeabuilder
                                  @fcwilt, thanks for the description of how the manual bed level assist works. I also read the wiki page and it's clear there too - the first probe point is not moved in the adjustment. This brings me to an interesting topic (somewhat off topic for scaling), and that is the concept of "leveling". When discussed, people usually assume, without stating, that the surface described by the Z probe (or nozzle) is perfectly planar and this is rarely the case. There can be humps or bends in the rails, and on a gantry supported by rails on either end, those rails might be skewed (back end up on one and down on the other). The point is that there are a lot of places that tolerances and alignment errors can impact getting a "really level" bed and the mesh compensation is really the final feature that covers up most of these. Getting each of the other elements as close to right as practical is a good thing, but be practical and have faith in the mesh.
                                  • mrehorstdmdundefined
                                    mrehorstdmd
                                    A large printer doesn't necessarily need the same bed flatness that a smaller printer needs. If you're building a large printer, there's a good chance you're going to use it to print large objects with a large nozzle and thick layers. A thick first layer is much more tolerant of variation in bed surface flatness than the thin first layer typically used in smaller printers.
                                    o_lampeundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                                    • o_lampeundefined
                                      o_lampe @mrehorstdmd
                                      @mrehorstdmd
                                      sounds reasonable, but there's also more shrinkage on bigger parts and a first layer with uneven squish-factor is prone to lift off the bed.
                                        Phaedrux Moderator @mrehorstdmd
                                        @mrehorstdmd said in Which frame design can scale best?:
                                        There's also a good change you'd want to print a large batch of many small objects. Having worked on a 1 square meter printer recently I can say that leveling and mesh is critical for both though.
                                          mrehorstdmd @o_lampe
                                          @o_lampe In my experience with printing ABS in a heated chamber (even at only 50C), relatively large prints (280 mm) don't warp off the bed. What's more likely to be a problem is getting the print to let go of the bed when it's finished. You have much wider lines and so much larger surface area where the plastic contacts the bed surface, even if the surface isn't perfectly flat. I find that a little IPA at the base of the print, combined with prying with a sharp scraper, does the job reliably and with minimal damage to either the print or the bed surface.
