Solved BLTouch Probe Won't Deploy
@fcwilt said in BLTouch Probe Won't Deploy:
I double checked my code to be sure and it is always put into G90 mode before do the G30.
Okay, thats the way that it used to work for me as well. Now the probe wont deploy unless I have a G91 before my M558 and G30 in my homez.g file.
@charlie said in BLTouch Probe Won't Deploy:
Did you remove the double G30s in the homing files?
@joergs5 said in BLTouch Probe Won't Deploy:
This was analysis of the firmware source code. It accepts 0 in the deploy/retract files and also K0. It was only a check, you don't need to do anything.
Okay, thank you for doing that analysis!
About your problem, I am currently thinking about whether moving -3 away from the endstop is maybe too low and not reset to no-contact or contact (I don't know your endstop), so the endstop may not trigger at the next slow move, which is G1 H1 and doesn't set the endstop triggered then.
Im assuming that youre referring to the
G1 H0 X-3 F6000
in my homex.g file andG1 H0 Y-3 F6000
in my homey.g file. My switches are Omron 653-D2F-5L. It has 0.5mm of movement differential, but it couldnt hurt to try 5mm. -
No, just put G91 before the M558 and G30s. Here is the new homez.g file that appears to work.
; Voron. ; 0:/sys/homez.g ; Called to home the Z axis via G28 Z. ; 2020/10/24/20:02 G91 ; Set axes (not extruders) to relative positioning mode. G1 H2 Z5 F6000 ; Lift Z relative to current position. G90 ; Set axes (not extruders) to absolute positioning mode. G1 X175 Y151.5 F6000 ; Move X and Y axes so the Z probe is at the center of the bed. G91 M558 F600 H2 A1 ; Set Z probe. Feed rate: 600 mm/min. Dive height: 2 mm. Times to probe: 1. G30 ; Z probe quickly (1 of 2 passes). M558 F120 H5 A1 ; Set Z probe. Feed rate: 120 mm/min. Dive height: 5 mm. Times to probe: 1. G30 ; Home Z by probing the bed slowly (2 of 2 passes). G90
G1 H0 X-3 F6000
in my homey.g file. My switches are Omron 653-D2F-5L. It has 0.5mm of movement differential, but it couldnt hurt to try 5mm.As long as the movement is adequate to insure the endstop sensor is no longer activated your good.
But it has nothing to do with your G30 issue. The first G1 H1 marks the axis as homed. The second one may (or may not) make the stopping position a bit more accurate but that is all it does.
With the modification to the homex.g file to include G91 before the M558, the probe is working intermittently. Any other considerations that Im not making? Could interference be a part of the problem?
I would try this.
- In the config.g file set your M558 to the values you want to use during probing.
- Remove/comment out both M558s and one G30 in your home Z file
- Reset
- Home X
- Home Y
- Home Z
Thank you for your response. Unfortunately I tried this already, and it failed to deploy. Also, when performing a G29, the probe extended on the first probe point, but failed to deploy on the second one.
@phaedrux said in BLTouch Probe Won't Deploy:
Are you using toolboards or expansion boards or just the 6HC?
@phaedrux
Yes, I am using a Duet 3 Expansion board 3HC -
@phaedrux
Yes, I am using a Duet 3 Expansion board 3HCMove your connection to the 6HC to rule out any problems with communications to the 3HC or the 3HC itself.
It is.
It is.
Did you try it with the 3HC disconnected?
@fcwilt
Issue persists with 3HC disconnected at the can port and with the fuse removed. -
@fcwilt
Issue persists with 3HC disconnected at the can port and with the fuse removed.This is just bizarre.
I did a number of tests on my printer, but it was with a Duet 2 WiFi board, and I could not create any conditions, short of incorrect code, to cause the probe to fail.
I do have a 6HC. It won't be hard to hook up one of my spare BLTouch.
But that is for tomorrow.
@fcwilt
I can't tell you how grateful I am for your assistance! Im going to re run the wire to rule out faulty wiring (not a small feat given the voron drag chains, lol). I will report back my findings. -
@fcwilt
I can't tell you how grateful I am for your assistance! Im going to re run the wire to rule out faulty wiring (not a small feat given the voron drag chains, lol). I will report back my findings.I'm just upset that we haven't found the problem yet.
My first check on wiring would be to run something directly as possible from the board to the probe without worrying about making it actually work for printing. Just enough wire for testing.
M558 K0 P9 F120 H3 R0 T6000 A1 B0 C"0.io4.in"
I've found a comment here https://forum.duet3d.com/topic/16791/3-1-1-bltouch-doesn-t-function-after-cancelling-a-job/7 which may help, setting the R parameter higher than 0 for recovery time. Maybe you want to try it. This thread has other interesting proposals like noise reduction also.
Here are the things I would suggest trying:
- Try a fresh basic config from the config tool to rule out something being weird in your current config.
- Try temporarily switching to standalone mode to remove the SBC from the setup.
- Try the 3.4 beta6 release.
Upon some preliminary testing, it appears as though the wiring may be to blame. In a few days Ill have the time to do some more digging. Ill keep you posted as to the results. Thank you all for your help so far!
