    Connection between Duet 3 6HC and SBC (Pi4)
    828
    • Dr_Ju_Juundefined
      Dr_Ju_Ju @gloomyandy
      @gloomyandy yep, the link shown the circuit diagram of the Duet 3, but it does NOT detail the required connections between it, and a Pi4.
      Also, I may well replace the Pi with either an Odroid/Pine64 device, so want what is actually required.
      Julian,
      Old goat, learning new things….
      gloomyandyundefined 1 Reply Last reply Reply Quote 0
      • chrishammundefined
        chrishamm administrators @Dr_Ju_Ju
        @dr_ju_ju I've been using a GPIO shield for my Pi so I can use a Duet 3 with a Pi touchscreen:
        For SBC mode you need:
        • +3.3V
        • GND
        • SPI0 (with CE0)
        • GPIO25
        You could use SPI1 instead of SPI0 or another GPIO pin instead of GPIO25, but that would require extra configuration steps on the Pi and in /opt/dsf/conf/config.json.
        Duet software engineer
        Dr_Ju_Juundefined 1 Reply Last reply Reply Quote 0
        • gloomyandyundefined
          gloomyandy @Dr_Ju_Ju
          @dr_ju_ju Page three of the schematic shows the connections to the SBC connector (and which pins within that connector are in use). Since this then connects to a simple ribbon cable and then to the rPi header it is relatively easy to work out the rPi connections. What is it that you think is missing? Other than the 5V supply (which needs to be provided to the rPi in some way), I'd say that all of them are required. You may be able to reduce the number of ground connections (or possibly use alternate ground pins on the SBC connector) but I'd be cautious about doing this as you may find doing so introduces noise problems.
          • achrnundefined
            achrn
            The wiring diagram on teh dozuki lists the pins in the connector, which I find easier to lay my hands on than the schematic.
            https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram
            It lists the 3.3V connected.
            What I've done for using other connections for other things (including injecting 5V to teh Pi) is to use a stacking header and a little bit of tri-pad stripboardbetween teh ribbon and the pi.
            • Dr_Ju_Juundefined
              Dr_Ju_Ju @chrishamm
              @chrishamm Unfortunately the case I'm using works well, but severely limits access to the GPIO connector, i.e. it doesn't allow the use of a standard ribbon connector
              Julian,
              achrnundefined rjenkinsgbundefined 2 Replies Last reply Reply Quote 0
              • achrnundefined
                achrn @Dr_Ju_Ju
                @dr_ju_ju said in Connection between Duet 3 6HC and SBC (Pi4):
                Is it just the corners? It looks like a few minutes with a file would make it fit...
                • Dr_Ju_Juundefined
                  Dr_Ju_Ju @achrn
                  @achrn Nah, its not just the inner corners, but the depth, and amount of material that is used for the mounting screws etc....
                  Julian,
                  achrnundefined 1 Reply Last reply Reply Quote 0
                  • achrnundefined
                    achrn @Dr_Ju_Ju
                    @dr_ju_ju That's a shame (but I did kind of think if it was that simple you'd have done it already).
                    The Pi4 has better thermal and power management than previous Pis and consensus seems to be it actually tends to have fewer heat problems than less powerful models. Mine driving a MB6HC has been entirely happy with one of these: https://shop.pimoroni.com/products/raspberry-pi-4-heatsink but I understand you might want to stick with what is proven in your setup.
                    • rjenkinsgbundefined
                      rjenkinsgb @Dr_Ju_Ju
                      I use the same (or very similar) heatsink assemblies - they are fine with an extender added, eg. a header socket with wire-wrap style pins the IDC connector fits to.
                      The ones I found that have the proper square pins but still cheap were "Geekworm" 2*20 Pin female header kits
                      https://geekworm.com/products/geekworm-raspberry-pi-2x20-40-pin-gpio-stacking-header-extender-kit
                      They are available on Amazon etc.
                      Robert J.
                      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                      Dr_Ju_Juundefined 1 Reply Last reply Reply Quote 2
                      • Dr_Ju_Juundefined
                        Dr_Ju_Ju @rjenkinsgb
                        @rjenkinsgb I have some of those on order, but they appear to be lost in the xmas postal rush 😞
                        BTW, your picture still shows that you are using the ribbon cable, which I do not want to use, so I still need what actually needs to be connected ??
                        Julian,
                        rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
                          ????? I was responding to that post.
                          The required connections have already been linked in this thread, two or three times.
                          eg.
                          https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/33DEuEJZXP16vLbF.huge
                          Robert J.
