    seeing if i can get assistance with bed connectins
    1.5k
    • frnknstnundefined
      frnknstn @alankilian
      @alankilian i still have to do z probe and fans. then bed leveling. paused on probe was getting frustrated. So i have been messing with heaters. Now im trying to figure out fans on extruder and parts cooler
      frnknstnundefined 1 Reply Last reply Reply Quote 0
      • frnknstnundefined
        frnknstn @frnknstn
        @frnknstn so on my extruder fan, should i just run that always on by the power strip, i am running 24v fans throughout
        Gixxerfastundefined 1 Reply Last reply Reply Quote 0
        • Gixxerfastundefined
          Gixxerfast @frnknstn
          @frnknstn Not all 24V fans can be PWM:ed Do you have more than two wire fans? Can you show how you connected them ?
          Have you set the jumper to V_fused for 24V ?
          Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
          Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
          Ender 3 Pro with BTT SKR-2 + RRF
          • frnknstnundefined
            frnknstn @Gixxerfast
            @gixxerfast these are all 2 wire, i switched the jumper from 12v to VIN, both fans are coming out of out7 and out8. if i need to get different fans i can
            frnknstnundefined Gixxerfastundefined 2 Replies Last reply Reply Quote 0
            • frnknstnundefined
              frnknstn @frnknstn
              @frnknstn said in seeing if i can get assistance with bed connectins:
              ill see if i can get a pic
                @frnknstn
                No, they should work fine. At out7 (hotend fan) should start when T1 reaches 45C. YOu should be able to manually control out8 (part cooling) in the DWC dashboard. Have you tried?
                They are both two pin connectors so as long as you haven't rotated the wires you can't go wrong there
                • frnknstnundefined
                  @gixxerfast i have no fans under fan selection. thats where i assumed they would show up
                  • frnknstnundefined
                    frnknstn @frnknstn
                    @frnknstn ill double check and make sure i have the wires correct
                      @frnknstn That is strange, not even the tool fan? ... Is your config still as listed above ?
                      Try a M98 P"0:/sys/config.g" and check the console
                        @frnknstn You might want to uncomment your tool config at the end of config.g and end with a T0
                        • frnknstnundefined
                          @gixxerfast ; General preferences
                          M550 P"duet3" ; Set machine name
                          M552 S1 ; Enable network
                          ;*** Access point is configured manually via M587
                          M586 P0 S1 ; Enable HTTP
                          M586 P1 S0 ; Disable FTP
                          M586 P2 S0 ; Disable Telnet
                          M575 P1 S1 B57600 ; Panel Due
                          ; Printer geometry
                          M669 K1 ; Select CoreXY mode
                          M208 X0:330 Y0:285.75 Z0:350 ; Axis Limits
                          M564 H0 ; allow unhomed movement
                          ;------- drives from top---------------------------------------------------
                          ; B -------+------ A
                          ; | P.02 | P.03 |
                          ; -------+------- Z-Drives
                          ; | P0.1 | P0.4 |
                          ; Front
                          ; Drive Mappings
                          M569 P0.0 S1 V0 ; Drive 0: E Axis
                          M569 P0.1 S1 V0 ; Drive 1: Z-LeftFront Axis
                          M569 P0.2 S0 V0 ; Drive 2: Z-LeftRear Axis
                          M569 P0.3 S1 V0 ; Drive 3: Z-RightRear Axis
                          M569 P0.4 S0 V0 ; Drive 4: Z-RightFront Axis
                          M569 P1.0 S1 V0 ; Drive 5: Expansion: B motor (X-axis)
                          M569 P1.1 S1 V0 ; Drive 6: Expansion: A motor (Y-axis)
                          ; Motor remapping for dual Z and axis Limits
                          M584 X1.0 Y1.1 Z0.1:0.2:0.3:0.4 E0.0 ; Motor mapping
                          M671 X-76.2:-76.2:406.4:406.4 Y0:374.65:374.65:0 S20 ; Z leadscrews positions Left Front - Let Rear - Right Rear - Right Front
                          ; Microstepping and Speed
                          M350 X32 Y32 E16 Z16 I1 ; Configure microstepping with interpolation
                          M92 X200.00 Y200.00 Z200.00 E400.00 ; Set steps per mm 1.8 motors
                          ; Speeds, Acceleration and Jerk
                          M566 X400.00 Y400.00 Z25.00 E600.00 P1 ; Set maximum instantaneous speed changes (mm/min)
                          M203 X12000.00 Y12000.00 Z1000.00 E3600.00 ; Set maximum speeds (mm/min)
                          M201 X3000.00 Y3000.00 Z100.00 E3600.00 ; Set accelerations (mm/s^2)
                          ; Motor currents
                          M906 X1200.00 Y1200.00 Z1200.00 E700.00 I60 ; Set motor currents (mA) and motor idle factor in percent
                          M84 S600 ; Set idle timeout
                          ; Endstops for each Axis
                          M574 X2 S1 P"io0.in" ; Set X endstop controlled by switch
                          M574 Y2 S1 P"io1.in" ; Set Y endstop controlled by switch
                          M558 P8 C"io3.in" H5 F120 T60000 ; set Z probe type to unmodulated and the dive height + speeds
                          ; Stallgaurd Sensitivy (maybe use to pause print after crash)
                          M915 X S2 F0 H200 R0 ; Set X axis Sensitivity 1.8 motors
                          M915 Y S2 F0 H200 R0 ; Set y axis Sensitivity 1.8 motors
                          ; Input Shaper and Accelerometer
                          ;M955 P0 C"io4.out+io4.in"
                          ;M593 F46.75 S0.2
                          ;M593 F19 P4 S0.3 ; experimental
                          ; Z Probe Offset (Probe behind Afterburner)
                          G31 P500 X0 Y0 Z1.5
                          M308 S0 P"temp_0" Y"thermistor" A"Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                          M950 H0 C"out_0" T0 ; create bed heater output on out0 and map it to sensor 0
                          M307 H0 A350 C139 D5.5 B0 ; set model parameters for heater 1 and use PID mode
                          M308 S1 P"temp_1" Y"thermistor" A"Hotend" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                          M950 H1 C"out_1" T1 ; create nozzle heater output on out1 and map it to sensor 1
                          M307 H1 B0 R1.680 C233.0:193.0 D6.75 S1.00 V23.7 ; disable bang-bang mode for heater and set PWM limit
                          M950 F0 C"out7" Q500 ; Parts cooling create fan 0 on pin out7 and set its frequency
                          M106 P0 T45 H0
                          M950 F1 C"out8" Q500 ; Extruder create fan 1 on pin out8 and set its frequency
                          M106 P1 T25 H1
                          ; Fans Electronic compartment & Exhaust
                          ;M950 F1 C"out3" Q100 ; Creates Case Fan 1
                          ;M106 P1 T40 S150 H0 ; Case Fan 1 Settings (Turns on at 60°C tool temp) at low speed
                          ;M950 F2 C"out4" Q100 ; Creates Case Fan 2
                          ;M106 P2 T40 S150 H0 ; Case Fan 2 Settings (Turns on at 60°C tool temp) at low speed
                          ;M950 F5 C"out7" Q100 ; Creates Case Fan 2
                          ;M106 P5 T95 S50 H0 ; Exhaust fan
                          ; Filament Runout sensor
                          ;M950 J4 C"io5.in" ; Input 4 filament sensor
                          ;M581 P4 T2 S1 R1 ; Filament Sensor P4 triggers inactive-to-active edge (S1) tigger2.g (T2) only when printing (R1)
                          ;M591 D0 P1 C"io5.in" S1 ; Filament Sensor
                          M563 P0 D0 H1 F0 S"Extruder" ; Define tool 0
                          This is where its at right now
                          alankilianundefined Gixxerfastundefined 2 Replies Last reply Reply Quote 0
                          • alankilianundefined
                            alankilian @frnknstn
                            @frnknstn
                            Do you have your fans hidden in the "Status" tab?
                              M106 P0 T45 H0
                              This one: M106 P0 T45 H0 ---> M106 P0 S0 H-1 right? You don't want the part cooling fan with thermostatic control. You want the Slicer to handle that one
                              • frnknstnundefined
                                @alankilian ![alt text](bff710fe-017d-46e8-9dca-b7f6ce8fd525-Screenshot (3).png image url)
                                I dont see anything
                                  This post is deleted!
                                  • frnknstnundefined
                                    @alankilian right, that dont do anything if turned all the way up
                                    Gixxerfastundefined frnknstnundefined 2 Replies Last reply Reply Quote 0
                                      @frnknstn Did you fix this?
                                      "This one: M106 P0 T45 H0 ---> M106 P0 S0 H-1 right? You don't want the part cooling fan with thermostatic control. You want the Slicer to handle that one"
                                      • frnknstnundefined
                                        frnknstn @frnknstn
                                        I changed the comment now i get fan 0 at the bottom. but i still have no action
                                          @frnknstn OK, that's one. Now we must check your tool config ...
                                          and later your wiring...
                                          • frnknstnundefined
                                            @gixxerfast glad you guys are helping. new to this and trying to learn. appreciate your patients
