seeing if i can get assistance with bed connectins
@frnknstn You might want to uncomment your tool config at the end of config.g and end with a T0
@gixxerfast ; General preferences
M83 ; ...but relative extruder moves; Network
M550 P"duet3" ; Set machine name
M552 S1 ; Enable network
;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet
M575 P1 S1 B57600 ; Panel Due; Printer geometry
M669 K1 ; Select CoreXY mode
M208 X0:330 Y0:285.75 Z0:350 ; Axis Limits
M564 H0 ; allow unhomed movement;------- drives from top---------------------------------------------------
; B -------+------ A
; | P.02 | P.03 |
; -------+------- Z-Drives
; | P0.1 | P0.4 |
; Front; Drive Mappings
M569 P0.0 S1 V0 ; Drive 0: E Axis
M569 P0.1 S1 V0 ; Drive 1: Z-LeftFront Axis
M569 P0.2 S0 V0 ; Drive 2: Z-LeftRear Axis
M569 P0.3 S1 V0 ; Drive 3: Z-RightRear Axis
M569 P0.4 S0 V0 ; Drive 4: Z-RightFront Axis
M569 P1.0 S1 V0 ; Drive 5: Expansion: B motor (X-axis)
M569 P1.1 S1 V0 ; Drive 6: Expansion: A motor (Y-axis); Motor remapping for dual Z and axis Limits
M584 X1.0 Y1.1 Z0.1:0.2:0.3:0.4 E0.0 ; Motor mapping
M671 X-76.2:-76.2:406.4:406.4 Y0:374.65:374.65:0 S20 ; Z leadscrews positions Left Front - Let Rear - Right Rear - Right Front; Microstepping and Speed
M350 X32 Y32 E16 Z16 I1 ; Configure microstepping with interpolation
M92 X200.00 Y200.00 Z200.00 E400.00 ; Set steps per mm 1.8 motors; Speeds, Acceleration and Jerk
M566 X400.00 Y400.00 Z25.00 E600.00 P1 ; Set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z1000.00 E3600.00 ; Set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E3600.00 ; Set accelerations (mm/s^2); Motor currents
M906 X1200.00 Y1200.00 Z1200.00 E700.00 I60 ; Set motor currents (mA) and motor idle factor in percent
M84 S600 ; Set idle timeout; Endstops for each Axis
M574 X2 S1 P"io0.in" ; Set X endstop controlled by switch
M574 Y2 S1 P"io1.in" ; Set Y endstop controlled by switch; Z-Probe
M558 P8 C"io3.in" H5 F120 T60000 ; set Z probe type to unmodulated and the dive height + speeds
M557 X15:215 Y15:195 S20 ; define mesh grid; Stallgaurd Sensitivy (maybe use to pause print after crash)
M915 X S2 F0 H200 R0 ; Set X axis Sensitivity 1.8 motors
M915 Y S2 F0 H200 R0 ; Set y axis Sensitivity 1.8 motors; Input Shaper and Accelerometer
;M955 P0 C"io4.out+io4.in"
;M593 F46.75 S0.2
;M593 F19 P4 S0.3 ; experimental; Z Probe Offset (Probe behind Afterburner)
G31 P500 X0 Y0 Z1.5; Heaters
M308 S0 P"temp_0" Y"thermistor" A"Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M950 H0 C"out_0" T0 ; create bed heater output on out0 and map it to sensor 0
M307 H0 A350 C139 D5.5 B0 ; set model parameters for heater 1 and use PID mode
M143 H0 S120 ; set temperature limit for heater 0 to 120CM308 S1 P"temp_1" Y"thermistor" A"Hotend" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out_1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M307 H1 B0 R1.680 C233.0:193.0 D6.75 S1.00 V23.7 ; disable bang-bang mode for heater and set PWM limit
M950 F0 C"out7" Q500 ; Parts cooling create fan 0 on pin out7 and set its frequency
M106 P0 T45 H0M950 F1 C"out8" Q500 ; Extruder create fan 1 on pin out8 and set its frequency
M106 P1 T25 H1; Fans Electronic compartment & Exhaust
;M950 F1 C"out3" Q100 ; Creates Case Fan 1
;M106 P1 T40 S150 H0 ; Case Fan 1 Settings (Turns on at 60°C tool temp) at low speed
;M950 F2 C"out4" Q100 ; Creates Case Fan 2
;M106 P2 T40 S150 H0 ; Case Fan 2 Settings (Turns on at 60°C tool temp) at low speed
;M950 F5 C"out7" Q100 ; Creates Case Fan 2
;M106 P5 T95 S50 H0 ; Exhaust fan; Filament Runout sensor
;M950 J4 C"io5.in" ; Input 4 filament sensor
;M581 P4 T2 S1 R1 ; Filament Sensor P4 triggers inactive-to-active edge (S1) tigger2.g (T2) only when printing (R1)
;M591 D0 P1 C"io5.in" S1 ; Filament Sensor; Tools
M563 P0 D0 H1 F0 S"Extruder" ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0CThis is where its at right now
@frnknstn said in seeing if i can get assistance with bed connectins:
M106 P0 T45 H0
This one: M106 P0 T45 H0 ---> M106 P0 S0 H-1 right? You don't want the part cooling fan with thermostatic control. You want the Slicer to handle that one
@alankilian ![alt text](
image url)
I dont see anything
This post is deleted! -
@alankilian right, that dont do anything if turned all the way up
@frnknstn Did you fix this?
"This one: M106 P0 T45 H0 ---> M106 P0 S0 H-1 right? You don't want the part cooling fan with thermostatic control. You want the Slicer to handle that one"
I changed the comment now i get fan 0 at the bottom. but i still have no action
@frnknstn OK, that's one. Now we must check your tool config ...
and later your wiring...
@gixxerfast glad you guys are helping. new to this and trying to learn. appreciate your patients
You're doing GREAT!
We've all been where you are right now.
@frnknstn
Now replaceM563 P0 D0 H1 F0 S"Extruder" ; Define tool 0
with
M563 P0 D0 H1
Just to test and reset the board
Add a T0 at the very end of config.g as well
Shouldn't make much difference but ...
@gixxerfast it is changed
it put Tool fan under fans. No movement yet though
@frnknstn Oh, yes. #2 done. Now try to max that one and see if any fan spins.
Drag it to max
@gixxerfast no movement.
; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Network M550 P"duet3" ; Set machine name M552 S1 ; Enable network ;*** Access point is configured manually via M587 M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet M575 P1 S1 B57600 ; Panel Due ; Printer geometry M669 K1 ; Select CoreXY mode M208 X0:330 Y0:285.75 Z0:350 ; Axis Limits M564 H0 ; allow unhomed movement ;------- drives from top--------------------------------------------------- ; B -------+------ A ; | P.02 | P.03 | ; -------+------- Z-Drives ; | P0.1 | P0.4 | ; -------+------- ; Front ; Drive Mappings M569 P0.0 S1 V0 ; Drive 0: E Axis M569 P0.1 S1 V0 ; Drive 1: Z-LeftFront Axis M569 P0.2 S0 V0 ; Drive 2: Z-LeftRear Axis M569 P0.3 S1 V0 ; Drive 3: Z-RightRear Axis M569 P0.4 S0 V0 ; Drive 4: Z-RightFront Axis M569 P1.0 S1 V0 ; Drive 5: Expansion: B motor (X-axis) M569 P1.1 S1 V0 ; Drive 6: Expansion: A motor (Y-axis) ; Motor remapping for dual Z and axis Limits M584 X1.0 Y1.1 Z0.1:0.2:0.3:0.4 E0.0 ; Motor mapping M671 X-76.2:-76.2:406.4:406.4 Y0:374.65:374.65:0 S20 ; Z leadscrews positions Left Front - Let Rear - Right Rear - Right Front ; Microstepping and Speed M350 X32 Y32 E16 Z16 I1 ; Configure microstepping with interpolation M92 X200.00 Y200.00 Z200.00 E400.00 ; Set steps per mm 1.8 motors ; Speeds, Acceleration and Jerk M566 X400.00 Y400.00 Z25.00 E600.00 P1 ; Set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z1000.00 E3600.00 ; Set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z100.00 E3600.00 ; Set accelerations (mm/s^2) ; Motor currents M906 X1200.00 Y1200.00 Z1200.00 E700.00 I60 ; Set motor currents (mA) and motor idle factor in percent M84 S600 ; Set idle timeout ; Endstops for each Axis M574 X2 S1 P"io0.in" ; Set X endstop controlled by switch M574 Y2 S1 P"io1.in" ; Set Y endstop controlled by switch ; Z-Probe M558 P8 C"io3.in" H5 F120 T60000 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:215 Y15:195 S20 ; define mesh grid ; Stallgaurd Sensitivy (maybe use to pause print after crash) M915 X S2 F0 H200 R0 ; Set X axis Sensitivity 1.8 motors M915 Y S2 F0 H200 R0 ; Set y axis Sensitivity 1.8 motors ; Input Shaper and Accelerometer ;M955 P0 C"io4.out+io4.in" ;M593 F46.75 S0.2 ;M593 F19 P4 S0.3 ; experimental ; Z Probe Offset (Probe behind Afterburner) G31 P500 X0 Y0 Z1.5 ; Heaters M308 S0 P"temp_0" Y"thermistor" A"Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out_0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 A350 C139 D5.5 B0 ; set model parameters for heater 1 and use PID mode M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp_1" Y"thermistor" A"Hotend" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out_1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 R1.680 C233.0:193.0 D6.75 S1.00 V23.7 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"out7" Q500 ; Parts cooling create fan 0 on pin out7 and set its frequency M106 P0 S0 H-1 M950 F1 C"out8" Q500 ; Extruder create fan 1 on pin out8 and set its frequency M106 P1 T25 H1 ; Fans Electronic compartment & Exhaust ;M950 F1 C"out3" Q100 ; Creates Case Fan 1 ;M106 P1 T40 S150 H0 ; Case Fan 1 Settings (Turns on at 60°C tool temp) at low speed ;M950 F2 C"out4" Q100 ; Creates Case Fan 2 ;M106 P2 T40 S150 H0 ; Case Fan 2 Settings (Turns on at 60°C tool temp) at low speed ;M950 F5 C"out7" Q100 ; Creates Case Fan 2 ;M106 P5 T95 S50 H0 ; Exhaust fan ; Filament Runout sensor ;M950 J4 C"io5.in" ; Input 4 filament sensor ;M581 P4 T2 S1 R1 ; Filament Sensor P4 triggers inactive-to-active edge (S1) tigger2.g (T2) only when printing (R1) ;M591 D0 P1 C"io5.in" S1 ; Filament Sensor ; Tools M563 P0 D0 H1 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C T0
@frnknstn OK, so you have dragged the little bubble icon to max and no fan movement?
Then we need to see the wiring please
Your fan config should be good now
Promise to say "It's alive, it's alive" when it starts working
@gixxerfast could i have the wires backwards wouldnt they spin backwards? Probably a dumb question but i thought id ask. Trying to get this pic off my phone to show ya
