    Music skipping beats after firmware update (3.4.0beta6)
    28
    2.1k
    • engikeneerundefined
      engikeneer @jens55
      @jens55 you just need a bigger speaker 😉
      i3 clone with a bunch of mods
      jens55undefined 1 Reply Last reply Reply Quote 2
      • jens55undefined
        jens55 @engikeneer
        @engikeneer .... I am not an engikeneer so I didn't think far enough. Wish I would have finished my degree ...
        I am sure the neighbours will also really appreciate the sound tracks !
        • gtamanundefined
          gtaman @jens55
          @jens55
          Conveyor bed that automatically ejects prints 😄 I've seen it somewhere just not in a public machine. I think the hardest part would be reliability, but it is possible. You could also set it to cancel and kick a job out if the time runs out before the print is done xD I haven't used bill receptors because they're expensive, but I did put a coin selector in a claw machine I built 😄 It was just some generic thing from ebay and it works quite well surprisingly.
            dc42 administrators @o_lampe
            @o_lampe said in Music skipping beats after firmware update (3.4.0beta6):
            @gtaman
            Downside is, that it totally blocks Daemon.g for other purposes.
            Would be cool to block it only while playing the sound.
            Any ideas? Renaming the original file and replace it with Davids two-liner and back again?
            @gtaman
            If you already have a daemon.g file that is coded as a while loop so that it never terminates under normal conditions, and it spends most of its time in G4 delay calls, then you may not have the original problem anyway. The reason that not having a daemon.g file causes interruptions to timed tasks such as playing tunes is that every 10 seconds RRF will try to open daemon.g if it is not already open; and trying to open a non-existent file on the SD card requires the whole directory to be searched, which may require several sector transfers.
            Of course you could also choose to have daemon.g play the tune, triggered when it sees a global variable change state.
            Baenwortundefined 1 Reply Last reply Reply Quote 0
            • Baenwortundefined
              Baenwort @dc42
              @dc42 said in Music skipping beats after firmware update (3.4.0beta6):
              @gtaman
              @gtaman
              Is it enough to have a blank daemon.g or does it need contents?
              o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
              • o_lampeundefined
                o_lampe @Baenwort
                @baenwort said in Music skipping beats after firmware update (3.4.0beta6):
                You could add something like the below lines in your Daemon.g (empty or not) to have a controlable looptime.
                Set a low value when you need faster processing or higher, when you don't.
                while  true
                        //do other things
                        G4 S{global.DaemonLoopSpeed}
                  dc42 administrators @Baenwort
                  It need to have a loop with a delay call in the body.
                  I have it in mind to add a new GCode command to start/stop daemon.g.
                  DonStaufferundefined 1 Reply Last reply Reply Quote 1
                  • nikschaundefined
                    nikscha @gtaman
                    @gtaman would you mind sharing your gcode music collection?
                    Stay in school
                    gtamanundefined 1 Reply Last reply Reply Quote 0
                    • gtamanundefined
                      gtaman @nikscha
                      @nikscha
                      Here is my favourite in the code text below. I just found it, and i've been imagining it for weeks I tell you, WEEKS! Its the commodore 64 tribute from GTA Vice city. I think I'm going to use this for my main sound. Also, this thread had a bunch I shared earlier:
                      https://forum.duet3d.com/topic/26269/sound-for-duet?_=1639741054776
                      Also Don't be scared to make your own:
                      https://alexyu132.github.io/midi-m300/ -tool
                      https://www.vgmusic.com -midi music
                      https://bitmidi.com/ -midi music
                      There are Mp3 to midi converters too, but i havent found a good one
                      code_text
                      M300 P161 S370
                      G4 P161
                      M300 P166 S0
                      G4 P166
                      M300 P161 S370
                      G4 P161
                      M300 P166 S0
                      G4 P166
                      M300 P161 S370
                      G4 P161
                      M300 P166 S0
                      G4 P166
                      M300 P163 S330
                      G4 P163
                      M300 P163 S370
                      G4 P163
                      M300 P163 S440
                      G4 P163
                      M300 P161 S370
                      G4 P161
                      M300 P166 S0
                      G4 P166
                      M300 P163 S330
                      G4 P163
                      M300 P487 S370
                      G4 P487
                      M300 P166 S0
                      G4 P166
                      M300 P161 S294
                      G4 P161
                      M300 P166 S0
                      G4 P166
                      M300 P161 S294
                      G4 P161
                      M300 P166 S0
                      G4 P166
                      M300 P163 S294
                      G4 P163
                      M300 P161 S277
                      G4 P161
                      M300 P166 S0
                      G4 P166
                      M300 P161 S277
                      G4 P161
                      M300 P166 S0
                      G4 P166
                      M300 P163 S277
                      G4 P163
                      M300 P327 S330
                      G4 P327
                      M300 P327 S349
                      G4 P327
                      M300 P1000 S370
                      G4 P654
                      • Baenwortundefined
                        Baenwort @o_lampe
                        while  true
                                //do other things
                        So I tried exactly that (but with {global.DaemonLoopSpeed} replaced by a 1 as I didn't want to add a variable in my configuration.g) and the DWC is not unresponsive.
                        I'm going to pull the printer apart to get the mSDCard out once I get the kids in bed tonight.
                        I presume that even though you put it in code blocks that I shouldn't have used it exactly as you wrote it?
                        • o_lampeundefined
                          o_lampe @Baenwort
                          I believe, you wanted to say "now unresponsive"?
                          IMHO, a one second loop time for daemon.g shouldn't be too short, but there's a reason why they set the default loop time to ten seconds...
                          With a global variable, you wouldn't have to pull the SD-card. Maybe you can overwrite daemon.g by replacing it through DWC download instead of editing the file?
                          I recommend trying it with variable loop time until you figured out the best setting.
                          • DonStaufferundefined
                            DonStauffer @dc42
                            @dc42 Unfortunately, adding a daemon.g file with a loop didn't fix it for me. I have a music macro called from my S3D ending script. If I run the macro while no job is running it works fine. But almost always, at the end of a print, the third note doesn't sound. Not a big deal, but I don't know why it does this.
