    mesh results inconsistent with leveling
    2.2k
    • jltxundefined
      jltx @fcwilt
      @fcwilt said in mesh results inconsistent with leveling:
      @jltx said in mesh results inconsistent with leveling:
      @gloomyandy I got bootstrapped from someone else’s config and they did not have that. So no good reason. Are you saying doing a G30 S-2 at one of the leveling points?
      I tried to do 5 points and unfortunately my bed is so whacked it cannot find a solution within 0.02.
      There is a process called Setting the Z=0 Datum. This involves moving the probe to a fixed XY location, like the center of the bed, and then executing a single G30.
      This process needs to be done:
      • after leveling the bed with G32
      • before creating a height map with G29 S0
      • before locating that height map with G29 S1
      OK. I did not see that documented in https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
      I have been printing just fine without doing that. But I will update my macro. Thanks.
      Bed leveling can be done multiple times as needed. Using the condition code features of firmware 3.3 and later you can put code into bed.g that will run the leveling process until specified degree of levelness is obtained.
      right, I do exactly this. See my bed.g posted above.
      • jltxundefined
        jltx
        @gloomyandy @fcwilt I’m still not clear on the purpose of the Z=0. Maybe the confusion is I have a Voron with a mechanical Z end stop that is used to set the tool Z relative to bed. The inductive probe is only used to level the bed and probe a mesh for bed correction. All of that is relative. Do I need this extra step of Z=0? What exact command would that be? Since I’m not currently doing that, what bad things might happen? I appreciate the help.
        Phaedruxundefined zaptaundefined 2 Replies Last reply Reply Quote 0
        • zaptaundefined
          zapta @jltx
          This post is deleted!
            Phaedrux Moderator @jltx
            As long as that offset is correct such that when the nozzle is moved to Z0 the nozzle is just touching the bed you're ok. The problem is that correcting the gantry leveling will likely alter that offset. I don't really understand why the voron does it that way. Regardless, you can do both. The mechanical switch can be used like a fast homing switch for Z, then the probe can be used to locate the Z0 point of the bed and do the leveling.
            jltxundefined 1 Reply Last reply Reply Quote 1
            • zaptaundefined
              zapta @jltx
              One option you have is to use the Clicky mod instead of the probe and Z switch. IMO it makes things simple and straight forward.
              The issue with with magnetic probe is that it doesn't measure well absolute height, hence the extra Z switch that some Vorons use. The Clicky solves this problem.
              • jltxundefined
                jltx @Phaedrux
                @phaedrux i believe they use a hybrid setup because the inductive probes are very sensitive to temperature. If I were to ignore the endstop and try to just use the probe I would have no way to actually set Z=0, at least no confidence that I was anywhere close at a given temp. The endstop can move a little too with thermal expansion but it seems pretty small by comparison.
                • jltxundefined
                  jltx @zapta
                  @zapta I looked at klicky but I don’t think I have enough room. Unless the magnetic sled can discriminate only a few mm for pick up I will lose part of my rear bed trying to avoid accidental mounting.
                  • fcwiltundefined
                    fcwilt @jltx
                    Here is a quick-and-dirty video of how I fit a Euclid probe to my FT5. It's a bit hard to see but there was limited space to place the camera.
                    FT5 with Euclid Probe
                    I added one of these to allow moving the dock into position as needed:
                    jltxundefined 1 Reply Last reply Reply Quote 0
                      Does that mean the probing is done cold?
                      • jltxundefined
                        jltx @Phaedrux
                        @phaedrux said in mesh results inconsistent with leveling:
                        No, you can probe whenever you want. I really don't know why that designed it that way.
                        • jltxundefined
                          jltx @fcwilt
                          @fcwilt
                          That's clever. I'll have a think about that.
