    mesh results inconsistent with leveling
    2.2k
    • jltxundefined
      jltx @jltx
      @jltx crap. I forgot I had moved my leveling points outboard a bit to get closer to the pivot points and this moved them a few mm off from my mesh points. But I thought I can't be off >0.1mm Z in just a few mm, so I took a higher resolution mesh and see that I have a horribly distorted bed. So the actual level points are much closer together in Z but if you move in just a bit you will get a large Z variation. However, the (now) precise leveling points are still not within the tolerance that leveling established. I'm seeing 0.013 delta (much better than 0.1) which is higher than the 0.001 coming out of leveling. But it doesn't rally matter when the bed is so bad. I'm not sure what happened to the plate. It used to be very flat and I treated it very gently during the rebuild.
      • jltxundefined
        jltx @gloomyandy
        @gloomyandy Is it important to re-zero the Z to the level point? I assumed this would all be compensated correctly. My Z endstop is not a Z=0 so I adjust for that in my G31. If I run a G30 and this changes where Z=0 is on every run due to temp variation, etc. won't that screw up my offset? I need to mull on that.
        So over sampling the bed in leveling is ok? The algorithm with do a good job averaging? I can try that. I think I will avoid the far left edge since it is such an outlier.
        gloomyandyundefined 1 Reply Last reply Reply Quote 0
        • gloomyandyundefined
          gloomyandy @jltx
          @jltx Is there a reason why you don't use your probe to set z=0? Unless you have a very good reason not to (like maybe a tool changer or something) then I'd say that using the probe to set z=0 is a good idea especially so since you are using the probe to level the bed.
          I'd not go overboard on the number of points you use in your bed.g routine, I've certainly never tested more than 5 points (which is what I use, close to the bed corners plus centre).
          jltxundefined 1 Reply Last reply Reply Quote 0
          • jltxundefined
            jltx @gloomyandy
            @gloomyandy I got bootstrapped from someone else’s config and they did not have that. So no good reason. Are you saying doing a G30 S-2 at one of the leveling points?
            I tried to do 5 points and unfortunately my bed is so whacked it cannot find a solution within 0.02.
            • fcwiltundefined
              fcwilt @jltx
              @jltx said in mesh results inconsistent with leveling:
              There is a process called Setting the Z=0 Datum. This involves moving the probe to a fixed XY location, like the center of the bed, and then executing a single G30.
              This process needs to be done:
              • after leveling the bed with G32
              • before creating a height map with G29 S0
              • before loading that height map with G29 S1
              Bed leveling can be done multiple times as needed. Using the conditional code features of firmware 3.3 and later you can put code into bed.g that will run the leveling process until specified degree of levelness is obtained.
              jltxundefined 1 Reply Last reply Reply Quote 1
              • jltxundefined
                jltx @fcwilt
                @fcwilt said in mesh results inconsistent with leveling:
                • before locating that height map with G29 S1
                OK. I did not see that documented in https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                I have been printing just fine without doing that. But I will update my macro. Thanks.
                Bed leveling can be done multiple times as needed. Using the condition code features of firmware 3.3 and later you can put code into bed.g that will run the leveling process until specified degree of levelness is obtained.
                right, I do exactly this. See my bed.g posted above.
                • jltxundefined
                  jltx
                  @gloomyandy @fcwilt I’m still not clear on the purpose of the Z=0. Maybe the confusion is I have a Voron with a mechanical Z end stop that is used to set the tool Z relative to bed. The inductive probe is only used to level the bed and probe a mesh for bed correction. All of that is relative. Do I need this extra step of Z=0? What exact command would that be? Since I’m not currently doing that, what bad things might happen? I appreciate the help.
                  Phaedruxundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                  • zaptaundefined
                    zapta @jltx
                    This post is deleted!
                      Phaedrux Moderator @jltx
                      As long as that offset is correct such that when the nozzle is moved to Z0 the nozzle is just touching the bed you're ok. The problem is that correcting the gantry leveling will likely alter that offset. I don't really understand why the voron does it that way. Regardless, you can do both. The mechanical switch can be used like a fast homing switch for Z, then the probe can be used to locate the Z0 point of the bed and do the leveling.
                      • zaptaundefined
                        zapta @jltx
                        One option you have is to use the Clicky mod instead of the probe and Z switch. IMO it makes things simple and straight forward.
                        The issue with with magnetic probe is that it doesn't measure well absolute height, hence the extra Z switch that some Vorons use. The Clicky solves this problem.
                        • jltxundefined
                          jltx @Phaedrux
                          @phaedrux i believe they use a hybrid setup because the inductive probes are very sensitive to temperature. If I were to ignore the endstop and try to just use the probe I would have no way to actually set Z=0, at least no confidence that I was anywhere close at a given temp. The endstop can move a little too with thermal expansion but it seems pretty small by comparison.
                          • jltxundefined
                            jltx @zapta
                            @zapta I looked at klicky but I don’t think I have enough room. Unless the magnetic sled can discriminate only a few mm for pick up I will lose part of my rear bed trying to avoid accidental mounting.
                            • fcwiltundefined
                              fcwilt @jltx
                              Here is a quick-and-dirty video of how I fit a Euclid probe to my FT5. It's a bit hard to see but there was limited space to place the camera.
                              FT5 with Euclid Probe
                              I added one of these to allow moving the dock into position as needed:
                                Does that mean the probing is done cold?
                                • jltxundefined
                                  jltx @Phaedrux
                                  @phaedrux said in mesh results inconsistent with leveling:
                                  No, you can probe whenever you want. I really don't know why that designed it that way.
                                  • jltxundefined
                                    jltx @fcwilt
                                    @fcwilt
                                    That's clever. I'll have a think about that.
