    Unofficial RRF 3.4.0beta7+4 files
    Beta Firmware
    10
    23
    1.9k
      dc42 administrators @PetrKroupa
      @petrkroupa said in Unofficial RRF 3.4.0beta7+4 files:
      @dc42 Looks like there's something wrong with calling filament_error.g. I'm for sure have both files (with _ and with -) but still pause.g is called when fillament error. (6HC + 1LC + SBC) In beta7 work OK. beta7+5 no.
      Thanks, I've put this on my list to try to reproduce.
      PetrKroupaundefined 1 Reply Last reply Reply Quote 0
      • oozeBotundefined
        oozeBot @dc42
        @dc42 The fault always seems to occur 15-20 minutes after heating. The temp begins rising almost immediately upon enabling the heater, but does take a long time to reach the target temperature.
        Please watch this 25s movie I've linked below where it was ramping to 60c. Note the temp jumps around by .1-.2c. That's pretty typical while heating and what I feel is the cause of the fault.
        https://vimeo.com/665779274
        What I can't wrap my head around is the error states Heater 0 faults, but Heater 2 is the chamber and is what really faults. Maybe that is an unrelated issue..
        • Phaedruxundefined Phaedrux referenced this topic
        • RomeoFoxundefined
          RomeoFox
          Have installed the firmware due to file upload issues. Now I get the following errors on every move which make it impossible to work:
          Error: Driver 0.2 error: ok
          Error: Driver 0.3 error: ok
          Error: Driver 0.0 error: ok
          Error: Driver 0.1 error: ok
          Error: Driver 0.5 error: ok
          Furthermore an event notification window appears.
          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0beta7+6 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2022-01-13 18:24:07
            dc42 administrators @RomeoFox
            @romeofox this is now fixed in the 3.4.0beta7+7files at https://www.dropbox.com/sh/i5vox3xmkd55gaz/AAC19mI0WEC5GmEjLOBRbKs-a?dl=0.
            • OwenDundefined
              OwenD
              In 3.4.0b7+7, filament_error.g is not being called.
              pause.g is run immediately.
              It was working correctly in earlier 3.4b versions
              gloomyandyundefined 1 Reply Last reply Reply Quote 0
              • gloomyandyundefined
                gloomyandy @OwenD
                @owend I think the file has gone back to filament-error.g with a "-" rather than "_" do you have one of those?
                OwenDundefined 1 Reply Last reply Reply Quote 0
                • OwenDundefined
                  OwenD @gloomyandy
                  @gloomyandy
                  You nailed it, but it's the other way around in the release notes.
                  I renamed to filament-error.g and it ran the macro when the sensor tripped.
                  RepRapFirmware 3.4.0beta7
                  Upgrade notes:
                  The handling of filament errors have changed. When a filament error occurs, an event is created. To handle the event, RRF runs macro file filament_error.g without appending the extruder number to the file name and without pausing the print first. The extruder number is passed as param.D along with some other parameters. If filament_error.g is not found then the print is paused (running pause.g) and the error is reported.
                    gloomyandy @OwenD
                    @owend It used "_" in the original beta7 but has changed back to "-" in the most recent builds (and will be this way in RC1)....
                    https://github.com/Duet3D/RepRapFirmware/commit/3ac3345333659785dcd21088ae0b9b93ec914a4d
                    RepRapFirmware 3.4.0RC1
                    This release is still in preparation. Further items may be added before the release.
                    The macro files run after events are now heater-fault.g, filament-error.g (as in RRF 3.3), driver-error.g, driver-warning.g and driver-stall.g instead of these names with the '-' character replaced by '_'
                    a little confusing!
                    0 dc42 committed to Duet3D/RepRapFirmware
                    Replace '_' by '-' when generating macro name from event type name
                    OwenDundefined 1 Reply Last reply Reply Quote 1
                    • OwenDundefined
                      OwenD @gloomyandy
                      @gloomyandy
                      Thanks for that.
                      I had both files until yesterday.
                      I couldn't remember which to use, so I looked at the release notes, but in honesty I do now recall reading the snippet you posted, so my fault.
                      • PetrKroupaundefined
                        PetrKroupa @dc42
                        @dc42 - UPDATE: in BETA7+7 is called filament-error.g . Not filament_error.g.
                        (6HC + 1LC + SBC + MFM)
                        BigOne:Duet3 6HC +1LC + Rpi5 +SSD, mosquito hotend, 400x400x420
                        SmallOne : Duet3 6HC +1LC + Rpi5 +SSD, mosquito hotend, 210x250x210
                        Petr
                        • gloomyandyundefined gloomyandy referenced this topic
                        • Fred-Yundefined Fred-Y referenced this topic
                        • jay_s_ukundefined jay_s_uk referenced this topic
                        • dc42undefined dc42 marked this topic as a question
                        • dc42undefined dc42 has marked this topic as solved
