    So close...Extruder connected to Toolboard won't budge.
    1.0k
    • rjenkinsgbundefined
      rjenkinsgb @ArcadeKilla
      @arcadekilla
      Something I found when building my two machines, recently.
      There are two different wiring standards used by different motor makers. Out of eleven various types of motors, two had the inner pins swapped (so 1-4 then 3-6) & needed wiring as you have yours. The rest had the windings on 1-3 and 4-6.
      Try checking for continuity through the motor windings at the toolboard connector. As it is, you should see a few ohms between
      red & blue, and separately between green & black.
      If there is a circuit between red and black, it's the other motor type; swap the black & blue wires.
      Robert J.
      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
      ArcadeKillaundefined 1 Reply Last reply Reply Quote 0
      • ArcadeKillaundefined
        ArcadeKilla @Phaedrux
        @phaedrux said in So close...Extruder connected to Toolboard won't budge.:
        M98 P"config.g"
        M122
        M122 B121
        1/20/2022, 2:53:05 PM	M122 B121
        Diagnostics for board 121:
        Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)
        Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
        Never used RAM 2912, free system stack 2789 words
        Tasks: Move(notifyWait,0.1%,147) HEAT(delaying,2.1%,117) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.6%,76) CanClock(notifyWait,0.9%,65) ACCEL(notifyWait,0.0%,61) TLast software reset data not available
        Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 28120, writes 12, timeouts 0, DMA errors 0, steps req 0 done 0
        Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
        Peak sync jitter 0/0, peak Rx sync delay 199, resyncs 0/0, no step interrupt scheduled
        VIN: 24.5V
        MCU temperature: min 17.4C, cuLast sensors broadcast 0x00000000 found 0 12 ticks ago, loop time 0
        CAN messages queued 653435, send timeouts 0, received 1470240, lost 0, free buffers 37, min 37, error reg 110000
        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
        Accelerometer detected: yes, status: 00
        I2C bus errors 0, naks 0, other errors 0
        1/20/2022, 2:52:52 PM	M122
        RepRapFirmware for Duet 3 MB6HC version 3.01-RC9 running on Duet 3 MB6HC v1.01 or later
        Board ID: 08DJM-956BA-NA3TN-6J1F6-3S46K-TBAASUsed output buffers: 1 of 40 (13 max)
        Static ram: 154572
        Dynamic ram: 162220 of which 464 recycled
        Exception stack ram used: 332
        Never used ram: 75628
        Tasks: ETHERNET(blocked,804) NETWORK(ready,2076) HEAT(blocked,1084) CanReceiv(suspended,3412) CanSender(suspended,1432) CanClock(blocked,1432) TMC(blocked,216) MAIN(running,4404) IDLE(ready,80)
        Owned mutexes:
        Last reset 45:22:34 ago, cause: power up
        Last software reset at 2022-01-10 04:03, reason: User, spinning module LinuxInterface, available RAM 75656 bytes (slot 0)
        Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
        Error status: 0
        Free file entries: 10
        MCU temperature: min 38.2, current 38.4, max 38.5
        Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 11.8, current 12.3, max 12.9, under voltage events: 0
        Driver 0: standstill, reads 19216, writes 8 timeouts 0, SG min/max not available
        Driver 1: standstill, reads 19216, writes 8 timeouts 0, SG min/max not available
        Driver 2: standstill, reads 19216, writes 8 timeouts 0, SG min/max not available
        Driver 3: standstill, reads 19216, writes 8 timeouts 0, SG min/max not available
        Driver 4: standstill, reads 19216, writes 8 timeouts 0, SG min/max not available
        Driver 5: standstill, reads 19224, writes 0 timeouts 0, SG min/max not available
        Date/time: 2022-01-20 20:52:50
        Slowest loop: 4.55ms; fastest: 0.21ms
        === MainDDARing ===
        Scheduled moves: 3, completed moves: 3, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
        === AuxDDARing ===
        Heater 1 is on, I-accum = 0.0
        Heater 2 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        HTTP* is ready with "M122" in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon* is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 0.48ms; fastest: 0.03ms
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
        HTTP sessions: 0 of 8
        - Ethernet -
        State: establishingLink
        Error counts: 0 0 0 0 0
        === CAN ===
        Messages sent 200, longest wait 1ms for type 6017
        === Linux interface ===
        State: 0, failed transfers: 0
        Last transfer: 23ms ago
        RX/TX seq numbers: 52946/52947
        SPI underruns 0, overruns 0
        Number of disconnects: 0
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.1.1
        Code buffer space: 4096
        Full transfers per second: 31.46
        1/20/2022, 2:52:39 PM	M98 P"config.g"
        HTTP is enabled on port 80
        FTP is disabled
        TELNET is disabled
        Error: M350: Board 121 received unknown msg type 6021
        Error: M906: Board 121 received unknown msg type 6017
        Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
        Warning: M955: Command is not supported
        Error: M591: Remote ports not yet supported by this command
        1/20/2022, 2:52:16 PM	M98 P"config.g" M122 M122 B121
        Board ID: 08DJM-956BA-NA3TN-6J1F6-3S46K-TBAASUsed output buffers: 1 of 40 (10 max)
        Static ram: 154572
        Tasks: ETHERNET(blocked,804) NETWORK(ready,2076) HEAT(blocked,1084) CanReceiv(suspended,3412) CanSender(suspended,1432) CanClock(blocked,1432) TMC(blocked,216) MAIN(running,4764) IDLE(ready,80)
        Owned mutexes:
        Last reset 45:21:51 ago, cause: power up
        Error status: 0
        MCU temperature: min 15.2, current 38.3, max 40.7
        12V rail voltage: min 11.4, current 12.4, max 12.9, under voltage events: 0
        Driver 0: standstill, reads 36868, writes 15 timeouts 0, SG min/max 0/0
        Driver 1: standstill, reads 36869, writes 15 timeouts 0, SG min/max 0/0
        Driver 2: standstill, reads 36869, writes 15 timeouts 0, SG min/max 0/0
        Driver 3: standstill, reads 36870, writes 15 timeouts 0, SG min/max 0/0
        Driver 4: standstill, reads 36870, writes 15 timeouts 0, SG min/max 0/0
        Driver 5: standstill, reads 36875, writes 11 timeouts 0, SG min/max 0/0
        Date/time: 2022-01-20 20:52:06
        Slowest loop: 4.63ms; fastest: 0.14ms
        Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 3240065ms
        === MainDDARing ===
        === AuxDDARing ===
        Segments left: 0
        === Network ===
        Slowest loop: 1.68ms; fastest: 0.01ms
        - Ethernet -
        === CAN ===
        Messages sent 653144, longest wait 1ms for type 6018
        Last transfer: 18ms ago
        RX/TX seq numbers: 51574/51575
        Buffer RX/TX: 0/0-0
        Full transfers per second: 10.46
        Error: M122: Board 121 received unknown msg type 50
        FTP is disabled
        TELNET is disabled
        Error: M569: Board 121 received unknown msg type 50
        Error: M350: Board 121 received unknown msg type 50
        Error: M906: Discarded msg src=121 typ=4510 RID=11 exp 14
        Discarded msg src=121 typ=4510 RID=12 exp 14
        Discarded msg src=121 typ=4510 RID=15 exp 16
          ArcadeKilla @rjenkinsgb
          @rjenkinsgb Sadly, 'black and green' and 'red and green' are the correct connections. Just tested 😕
            definitely some errors.
            @arcadekilla said in So close...Extruder connected to Toolboard won't budge.:
            Your firmware versions are totally mismatched. How are you updating?
              @phaedrux I ended up redoing the firmware as I was having communication issues. This might be the source of my issues.
                Yes make sure the firmwares are all on 3.3 and that DCS matches as well.
                Using the pi you should be able to update using sudo apt update and sudo apt upgrade but the main firmware of 3.01 RC9 may be problematic to update. If that's the case, you can try manually flashing the firmware for 3.3 using USB to get it back in sync.
                  @phaedrux
                  Alright! Doing a lot better. I am getting communication and no errors now. Only issue now is I am only getting vibrations and no movement from any extruder commands.
                    Check the wiring for the extruder.
                    Check the steps per mm and motor current settings.
                    If you send M98 P"config.g" now do you still get errors?
                      @phaedrux
                      Wiring looks as pretty good.
                      M98 P"config.g"
                      Error: M552: Network-related commands are not supported when using an attached Single Board Computer
                      CORS disabled
                      CORS disabled
                      CORS disabled
                      Accelerometer 121:0 with orientation 12 samples at 1344Hz with 10-bit resolution
                        dc42 administrators @ArcadeKilla
                        That usually means one of three things:
                        1. The motor windings are not correctly phased. Check the phasing on the connector that plugs into the tool board, as described at https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases. The two wires at one end of the connector should belong to one phase, and the two wires at the other end to the other phase.
                        2. You have a bad crimp connection in the motor wiring. If you do the phase check described above, this may identify a bad crimp.
                        3. The stepper driver on the tool board has partially failed.
                          Phaedrux Moderator @ArcadeKilla
                          ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet
                          You'll need to remove these when using SBC move since networking is handled there.
                            ArcadeKilla @dc42
                            @dc42 Windings are correct. Plug seems good enough after re-crimping. Going to attempting to see if it will drivee a different stepper. How do I get the toolboard warrantied if it is dead? It's the only thing keeping this machine from running.
                              Let us know if the new motor works.
                              • ArcadeKillaundefined ArcadeKilla referenced this topic
