    Duet3D 1HCL - Closed Loop Controller Beta test
    Hardware dev
    20
    209
    19.5k
      A Former User @dc42
      Sounds great!!!
      Thanks for updating us
      Cheers
      Richard
      • samlogan87undefined
        samlogan87
        I am keen to get two as well. I have the 48v power supply just need the boards now
        Custom Core-XY
          A Former User @samlogan87
          @samlogan87
          what is the benefit of 48 volt?
          cheers
          richard
          samlogan87undefined 1 Reply Last reply Reply Quote 0
            samlogan87 @A Former User
            @gruna-studio you are able to run it much faster
            Custom Core-XY
              @samlogan87
              really? the motors can drive faster?
              since two years I´m working with 3d printers and duet and I never heard about it. haha
              Is there a good summary from Duet?
              Today is "1HCL-Monday". !!!!
              cheers richard
                @gruna-studio driving stepper motors at the desired current depends on having enough driver supply voltage to overcome the back EMF of the motors, which increases with speed. It's especially important with high inductance and high current motors. You can estimate the voltage needed using the calculator at https://www.reprapfirmware.org/emf.html.
                A Former User? 3 Replies Last reply Reply Quote 0
                  A Former User @dc42
                  ok thanks a lot!
                    A Former User @dc42
                    any good news?
                      samlogan87
                      @gruna-studio i know. I am hanging out for them. I have money burning a hole in my pocket
                      Custom Core-XY
                        A Former User @dc42
                        Hey any good news?
                        Cheers
                        Richard
                          T3P3Tony administrators @A Former User
                          @gruna-studio yes! finally over the bottle neck. drop me a line tony@duet3d.com as you have been waiting a while so we may be able to supply directly from next week (before we can get any to our resellers). also @samlogan87
                          Note support for these is still experimental in RRF 3.4
                            A Former User @T3P3Tony
                            @t3p3tony
                            yeeeeah!
                            thanks a lot.
                            So there is the first question.
                            Is there any experience with specific encoders I could use?
                            Is this an actual information?
                            If there is no picture yet, I can provide you some good ones and other documentations.
                            Thanks a lot
                            Richard
                            T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                              samlogan87
                              @T3P3Tony awesome. Sent you an email regarding getting some boards
                              Custom Core-XY
                                @gruna-studio the SPI connected encoders are not yet fully supported. we have done some limited testing but for now I recommend using quadrature encoders.
                                  @gruna-studio the encoders we have had most success with are the 1000 PPR (4000 CPR) ones built-into some 1.8deg stepper motors. There are some examples at https://www.omc-stepperonline.com/closed-loop-stepper-motor/.
                                    A Former User @dc42
                                    OK... nice to know. Can´t wait to install it. 🙂
                                    My X-axis works with an double shaft nema 17 who has belts on both ends. So I can´t ( at the moment) install the a new motor. How about the encoder of stepper online. I guess they´re quiet similar to the build in encoder.. or am I completly wrong?
                                    May it´s a cheaper solution to upgrade specific axis.
                                    https://www.omc-stepperonline.com/encoder/
                                    This encoder would fit nicely in my system but I`m not sure if this is working in the same way as the built in encoder of stepper online nemas.
                                    cheers Richard
                                    https://www.omc-stepperonline.com/download/HKT30-32.pdf
                                    • alankilianundefined
                                      alankilian @A Former User
                                      @gruna-studio Can you find some place that verifies you can get a 4,000 counts-per-revolution encoder? I looked at their web page and data sheet and I don't get a solid feeling that's true, but it might be true.
                                      I see CPR and LinesPerRev/PulsesPerRev (LPR/PPR) used incorrectly all the time.
                                      If you can only get a 1000 CPR encoder that's going to be too low a resolution to get you good performance. If the data sheet says CPR but they really mean LPR than it's OK, but without buying and testing one you won't know.
                                      A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
                                        A Former User @alankilian
                                        @alankilian https://www.rls.si/eng/products/rotary-magnetic-encoders
                                        But I´m no really sure with the configurations there.
                                        Share it if you do one if you want.
                                        I think they have all we need in future.
                                        Concerning the stepper online encoder. I think I´ll ask them and let you know.
                                        Cheers
                                        Richard
                                          dc42 administrators @alankilian
                                          @alankilian a 1000 PPR (pulses-per-rev) quadrature encoder provides 4000 CPR (counts per rev, better called transitions per rev). The EXP1HCL board uses all 4000 transitions. The 4 transitions that occur in the time of 1 pulse probably won't be as evenly spaced as the pulses, but using them still provides a benefit over using just the pulse count.
                                          @gruna-studio if the encoder spec is 1000 PPR (not 1000 CPR) then the resolution should be OK. We've only tried one system using a separate encoder (not from stepperonline) and we've had poor results; but that may be caused by something else on that machine. If you do use a separate encoder, you need to make sure there is no added backlash in the encoder caused by it being separate from the motor. So the mounting of the encoder on the shaft and the encoder body on the motor need to be rigid. As long as the EXP1HCL is in beta test and not a fully released product, we'd rather you use stepper motors with integrated encoders, so that we can be fairly sure that any issues you report are not caused by poor coupling of the motor to the encoder.
                                          A Former User? 2 Replies Last reply Reply Quote 0
                                            A Former User @dc42
                                            This post is deleted!
