    Duet3D 1HCL - Closed Loop Controller Beta test
    Hardware dev
    20
    209
    19.1k
      A Former User @dc42
      Hey any good news?
      Cheers
      Richard
        T3P3Tony administrators @A Former User
        @gruna-studio yes! finally over the bottle neck. drop me a line tony@duet3d.com as you have been waiting a while so we may be able to supply directly from next week (before we can get any to our resellers). also @samlogan87
        Note support for these is still experimental in RRF 3.4
          A Former User @T3P3Tony
          @t3p3tony
          yeeeeah!
          thanks a lot.
          So there is the first question.
          Is there any experience with specific encoders I could use?
          Is this an actual information?
          If there is no picture yet, I can provide you some good ones and other documentations.
          Thanks a lot
          Richard
          T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • samlogan87undefined
            samlogan87
            @T3P3Tony awesome. Sent you an email regarding getting some boards
            Custom Core-XY
              @gruna-studio the SPI connected encoders are not yet fully supported. we have done some limited testing but for now I recommend using quadrature encoders.
                @gruna-studio the encoders we have had most success with are the 1000 PPR (4000 CPR) ones built-into some 1.8deg stepper motors. There are some examples at https://www.omc-stepperonline.com/closed-loop-stepper-motor/.
                  A Former User @dc42
                  OK... nice to know. Can´t wait to install it. 🙂
                  My X-axis works with an double shaft nema 17 who has belts on both ends. So I can´t ( at the moment) install the a new motor. How about the encoder of stepper online. I guess they´re quiet similar to the build in encoder.. or am I completly wrong?
                  May it´s a cheaper solution to upgrade specific axis.
                  https://www.omc-stepperonline.com/encoder/
                  This encoder would fit nicely in my system but I`m not sure if this is working in the same way as the built in encoder of stepper online nemas.
                  cheers Richard
                  https://www.omc-stepperonline.com/download/HKT30-32.pdf
                  • alankilianundefined
                    alankilian @A Former User
                    @gruna-studio Can you find some place that verifies you can get a 4,000 counts-per-revolution encoder? I looked at their web page and data sheet and I don't get a solid feeling that's true, but it might be true.
                    I see CPR and LinesPerRev/PulsesPerRev (LPR/PPR) used incorrectly all the time.
                    If you can only get a 1000 CPR encoder that's going to be too low a resolution to get you good performance. If the data sheet says CPR but they really mean LPR than it's OK, but without buying and testing one you won't know.
                    A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
                      A Former User @alankilian
                      @alankilian https://www.rls.si/eng/products/rotary-magnetic-encoders
                      But I´m no really sure with the configurations there.
                      Share it if you do one if you want.
                      I think they have all we need in future.
                      Concerning the stepper online encoder. I think I´ll ask them and let you know.
                      Cheers
                      Richard
                        dc42 administrators @alankilian
                        @alankilian a 1000 PPR (pulses-per-rev) quadrature encoder provides 4000 CPR (counts per rev, better called transitions per rev). The EXP1HCL board uses all 4000 transitions. The 4 transitions that occur in the time of 1 pulse probably won't be as evenly spaced as the pulses, but using them still provides a benefit over using just the pulse count.
                        @gruna-studio if the encoder spec is 1000 PPR (not 1000 CPR) then the resolution should be OK. We've only tried one system using a separate encoder (not from stepperonline) and we've had poor results; but that may be caused by something else on that machine. If you do use a separate encoder, you need to make sure there is no added backlash in the encoder caused by it being separate from the motor. So the mounting of the encoder on the shaft and the encoder body on the motor need to be rigid. As long as the EXP1HCL is in beta test and not a fully released product, we'd rather you use stepper motors with integrated encoders, so that we can be fairly sure that any issues you report are not caused by poor coupling of the motor to the encoder.
                        A Former User? 2 Replies Last reply Reply Quote 0
                          A Former User @dc42
                          This post is deleted!
                            A Former User @dc42
                            I just got my boards! thanks a lot to providing me in this early stage. 😄
                            I saw there are some changes to the version 0.3. Is there already a wiring diagramm?
                            cheers
                            Richard
                              @gruna-studio latest EXP1HCL documentation is at https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Expansion_1HCL.
                              Alex.crundefined 1 Reply Last reply Reply Quote 0
                              • Alex.crundefined
                                Alex.cr @dc42
                                @dc42 @T3P3Tony
                                Any idea when 1HCL will be available to US resellers?
                                Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                                  T3P3Tony administrators @Alex.cr
                                  @alex-cr we have orders in from at least Filastruder (need to check with the other ones). I hope we will start shipping reseller orders to them next week.
                                  Alex.crundefined cloudseedsundefined 2 Replies Last reply Reply Quote 2
                                  • Alex.crundefined
                                    Alex.cr @T3P3Tony
                                    @t3p3tony
                                    Much appreciated!
                                    • cloudseedsundefined
                                      cloudseeds @T3P3Tony
                                      @t3p3tony Anything for Germany/Europe? I am currently testing 1XD with SERVO42C but that makes little sense if 1HCL is available soon.
                                      • madmattcoundefined
                                        madmattco
                                        Apologies if this was addressed before but I was wondering why the choice of using the 5160 and it's built-in encoder input was not used?
                                          T3P3Tony administrators @cloudseeds
                                          @cloudseeds we have dispatched some to Compass-DHM and Dold Mechatronic , I hope both of them will list them soon.
                                          DHM-onlineundefined cloudseedsundefined 2 Replies Last reply Reply Quote 0
                                            dc42 administrators @madmattco
                                            @madmattco the EXP1HCL uses the TMC2160A because it supports the direct coil current control that we need for closed loop node. The TMC2160A does not support an encoder. In any case, reading the encoder using the built-in encoder support in the MCU is faster than reading from the stepper driver over SPI.
