DWC displaying text only
Can you connect via USB terminal like YAT and send M122 and share the results here?
@phaedrux It doesnt seem to connect via yat. When checking Device Manager by pressing Windows Key + R and type devmgmt.msc, i dont see Duet listed, i've tried all usb port on the pc and none effect device manager. I have followed instructions in Getting Connected to your Duet but still no response when sending commands in yat.
@brian have now succeeded in connecting to yat. will advise progress.
@brian M112 results
Emergency Stop! Reset the controller to continue.ok
RepRapFirmware for Duet 2 WiFi/Ethernet Version 2.02(RTOS) dated 2018-12-24b1Executing config.g...Error: Bad command: ++
HTTP is enabled on port 80
FTP is disabled
TELNET is disabledDone!
RepRapFirmware for Duet 2 WiFi/Ethernet is up and running.
WiFi module started
WiFi module is connected to access point TELUS008 -
@brian M122 not M112
@brian Final result after completing the connecting instructions, and still cant get DWC on pc.
M112<CR>
M112
M112
FTP is disabled
WiFi module started
M115 S-1
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1
ok
M552 S-0
ok
WiFi module is idle
M552 S-0
ok
M552
WiFi module is idle
ok
M587 S"TELUSxx87" P"5n6w6xxxcc"
ok
M552 S1
ok
WiFi module is connected to access point TELUS0087, IP address 192.168.1.66 -
Send M122 please.
And can you share your config.g?
@phaedrux yes
++;MY update june 16 2018 for pellet extruder
; Configuration file for Duet WiFi (firmware version 2.0) Wifi not working, z endstop not working
; generated by RepRapFirmware Configuration Tool on Tue Jun 20 2017 17:30:36 GMT-0700 (Pacific Daylight Time); General preferences***********************
M111 S0 ; Debugging off
G21 ; Work in millimetres
M555 P2 ; Set firmware compatibility to look like Marlin
M208 X420 Y430 Z650 S0 ; Set axis maxima
M564 H0 ; must be here to allow movements before homing ...wtf; Endstops -my not working model******************
;M574 X1 Y1 S1 ; Define active high microswitches took out Z1 maybe cant have both-nope
;M558 P1 X0 Y0 Z1 H-3 F320 T5000 R0 ; smart IR Z probe, used for homing Z axis only, dive height 3mm, probe speed 200mm/min, travel speed ;5000mm/min, no recovery time
;M557 X25:175 Y25:175 S25 ; Define mesh grid
;G31 P500 X0 Y0 Z not here; Set Z probe trigger value, offset and trigger height HIGHER numbers moves bed CLOSER to nozzle-well it used to, nothing
;G30 ;does move bed up to trigger height* try z-2 or something-didnt home didnt go up; Endstops -T3P3Tony****************************
; Set Z height from build plate*********************M574 X1 Y1 S1 ; try remove Z0-didnt help, try Y2 flipped wires and work, now x not working trying X2
M558 P1 H3 F200 T1000 ;smart IR Z probe, (H)dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min travel speed was 5000 testing at 1000
G31 X0 Y0 Z0.4 P500 ; *****1.20 for 0.4 nozzle 2.0 for 0.9 HIGHER num puts bed CLOSER to nozzle! 1/1/21
;setting z height, command bed up to nozzle, run G92 Z0, set z to 0 in above line, repeat then run M114 to get offset; Drives*********************************************
M569 P3 S1 ; Drive 3 goes forwards; **below set microstepping to 64 from 128 now next line reduce steps by half x1272 y1284 z 6400-which worked!!!!
M350 X32 Y32 Z16 E32 I0 ; Configure microstepping without interpolation---below line was Z3200 Z3500=10% too muchby measuring 100mm with yardstick 3150 appears exactly correct!; STEPS **************************************
M92 X322.5 Y322.5 Z1307.8 E1300 ; ** (247 recreus E w/1.8 stepper, 500 for 0.9 stepper)(x636 642-1.8 steppers) 1360-dyze pro E-steps per mm trying y645 to correct printed(Z 3200 for 1,8 steppers try 5100 for 0.9 z,sy 2020 added 30 to 5100 to try reduce nozzle drag) 642 change for x y 5130 z (e1143 worked good for 1.0 LH), (e4000 good for 0.4LH) and (e1250 try 1750 too much for 0.6 LH) (try 700 for 0,9 Nozzle
M566 X100 Y100 Z100 E50 ; Set maximum instantaneous speed changes (mm/min); I changed from 900 x y (@12 prints very slowly)june 1 2018 120 z400 original ju27 2021 reduced E60 to E50
M203 X4800 Y4800 Z200 E1000 ; Set maximum speeds (mm/min)
M201 X600 Y600 Z100 E100 ; Set accelerations (mm/s^2) ; I changed from 1000 x y to 300 and now 200 and now lets try 300 june1 2018 Oct 600 xy 600;POWER ******************
M906 X855 Y855 Z1800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent *** tried 2000 works great but gets really hot 1800 hot, 1700 skips
M84 S30 ; Set idle timeout; Heaters
M143 S300 ; Set maximum heater temperature to 300C
M140 H-1 ; Disable heated bed
;M305 P1 X201 ; (board v0.4)
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
M305 P2 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 2
M307 H1 A350 C500 D50 B1; I added this line for pellet extruder C500 gives more timeout time; re-ativated as too many timeouts; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PBRIAN'S Build 2 ; Set machine name
M552 S1 ; Enable network
; Access point is configured manually via M587 by the user
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Fans changed p1 and p2 to S0 from S1 to see if they will work
M106 P1 S0 I0 F500 H1 T50 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S0 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S0 I0 F500 H1 T50 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Miscellaneous
T0 ; Select first tool -
@brian said in DWC displaying text only:
You've got a ++ before the ; for the comment which is causing that bad command error.
@brian Ok, i replaced all the www files on the sd card, but this has not made a difference. (that is on the new sd card)
What version of DWC files did you use? You'd need to match the files to your firmware version.
It looks like you're on 2.02 which is quite old now.
@phaedrux said in DWC displaying text only:
Have deleted the ++ in config.g
Version of DWC files; not sure version, but dated 2018, i think from when i installed the firmware, should be same install
Is 3.3 the latest and can i update just by copying files to sdcard?
For firmware 2.02 I think you'd want to use these DWC files.
https://github.com/Duet3D/RepRapFirmware/releases/download/2.02/DuetWebControl-1.22.6.zip
Updating to 3.3 would take a bit more doing. Let's see if we can resolve the DWC displaying correctly first.
Can you send M122 and post the results? Not M112.
@phaedrux agree, fix this first.
M122 Diagnostic RepRepFirmware for duet 2
WiFi/Ethernet version 2.20(RTOS)running on Duet
WiFi 1.02 or later Board ID: then the id number -
@brian updated www files from your link. no change
WiFi 1.02 or later Board ID: then the id numberThat's all that comes with it? There should be a longer diagnostic report.
@phaedrux i just got that from Panel Due, i will run Yat and see. BTW heres screenshot of my Home Router showing the ip address when i turn on printer.
FTP is disabled
WiFi module started
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
Board ID: 08DGM-956GU-DGMSN-6JKF2-3S86Q-TBRRH
Used output buffers: 1 of 20 (4 max)
Static ram: 25524
Dynamic ram: 98480 of which 0 recycled
Exception stack ram used: 288
Never used ram: 6780
Tasks: NETWORK(ready,1428) HEAT(blocked,1232) MAIN(running,3844) IDLE(ready,200)
Owned mutexes:
Last reset 00:00:36 ago, cause: power up
Last software reset time unknown, reason: Unknown, spinning module Platform, available RAM 6408 bytes (slot 1)
Software reset code 0x00b0 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0042380f BFAR 0xe000ed38 SP 0x20001ef4 Task 0x5754454e
Stack: 004450eb 00446c74 01000000 00000001 0040607f 200187cc a5a5a501 a5a5a5a5 20018a58 00000000 00000001 00000001 200099bc a5a5a5a5 a5a5a5a5 a5a5a5a5 00407a81 00000000 00000000 20001f48 00000014 3fff0300 00000000
Error status: 0
Free file entries: 10
SD card 0 detected, interface speed: 12.0MBytes/sec
MCU temperature: min 33.2, current 35.9, max 35.9
Supply voltage: min 0.2, current 0.4, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Cache data hit count 114777159
Slowest loop: 1.08ms; fastest: 0.06ms
I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
Bed compensation in use: none
Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.74ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address 84:0d:8e:b2:37:d2
WiFi Vcc 3.45, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24256
WiFi IP address 192.168.1.66
WiFi signal strength -32dBm, reconnections 0, sleep mode modem
ok
- WiFi -
Thanks. 12MB/s would indicate there is a problem with the SD card interface. It should be 20MB/s for the Duet 2.
When and where did you purchase the Duet? Firmware version 2.02 would indicate it's a bit old?
@phaedrux I purchased it a couple years ago, my second, as the first had many problems. I got it from Spool3D in canada, it is listed as a supplier on the duet3d site.
Unfortunately that is well out of warranty, but occasionally we have refurbished boards we can offer at reduced cost on exchange. Please contact roland@duet3d.com to enquire about availability and include a link to this thread.
@phaedrux ok, thanks for all your help
