    Triperon Motion
    36
    2.3k
    • o_lampeundefined
      o_lampe
      If you need another excuse to build a monorail Tripteron, imagine you have four of them surrounding the printbed.
        dc42 administrators @Apsu
        @Apsu said in Triperon Motion:
        You are indeed correct that it is not delta movement. It is completely linear, and described by a linear matrix/system of linear equations. All Tripterons are...
        If that is the case, then standard RRF supports Tripterons, and there is no longer any need for custom kinematics. Use the M669 command to specify Cartesian and use the XYZ parameters to modify the matrix.
        • speedpeteundefined
          speedpete
          I'm just trying out the delteron from Apsu, does anyone have a working config.g for duet wifi board? ...could you please show this here?
          My hardware is printed, smart effector is here, so I can start building this into my Kossel XL. 🙂
          Best Regards
          Peter
          • oliofundefined
            oliof @speedpete
            @speedpete you'll need to build your own firmware from my fork https://github.com/oliof/RepRapFirmware/tree/colinear-tripteron
            speedpeteundefined 1 Reply Last reply Reply Quote 0
            • oliofundefined
              oliof
              @speedpete also you need to brace for disappointment, there is a lot of inherent backlash in the Delteron
              https://photos.app.goo.gl/Kk1dJpv59M4AB1mi8
                speedpete @oliof
                @oliof
                that looks more complicated that I can handle 😉 ...What is with "If that is the case, then standard RRF supports Tripterons, and there is no longer any need for custom kinematics. Use the M669 command to specify Cartesian and use the XYZ parameters to modify the matrix." from DC42?
                Doesn´t that work? I´ve found no one showing such a config.g 😞
                Best Regards
                Peter
                • oliofundefined
                  oliof
                  @speedpete there are two different kinds of Tripterons:
                  1. Orthogonal Tripterons in a box frame -- These use Cartesian kinematics and can be run without any changes to firmware. You could use the RepRapFirmware configurator to create a config.g for these.
                  2. Colinear Tripterons in a delta frame like @Apsu s delteron -- these use their own kinematics as implemented in my fork and need firmware changes. I'll need to check whether it can be done as @dc42 says, but back in the day I couldn't make it work (but that's probably my lack of understanding and not a limitation of the firmware).
                  • oliofundefined
                    oliof
                    @dc42 these are the inverse kinematics for colinear tripteron
                    Inverse Kinematics
                         * 3x3 reduction coefficient matrix * 1x3 coordinate matrix
                         * [a_x -a_y 1]   [x]
                         * [b_x -b_y 1] * [y]
                         * [g_x -g_y 1]   [z]
                    How'd that be expressed in M669?
                    But besides that I needed arm angle and the height at which the machine homed plus some correction factor (which thinking about it today might be dropped in favor of adjusting steps/mm...) for proper movement, as well as delta style homing at the top (because the motors move the arms colinearly and not in a Cartesian fashion). I may pull out my prototype and do some testing; I assume I can drop a lot of my code if M669 matrix definition works.
                    speedpeteundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      speedpete @oliof
                      @oliof
                      That would be very interesting 🙂 ...nice of you 🙂 Truly I really depend on you in this case ...so please give it a try 🙂
                      Best Regards
                      Peter
                        dc42 administrators @oliof
                        @oliof said in Triperon Motion:
                        Inverse Kinematics
                             * [a_x -a_y 1]   [x]
                             * [g_x -g_y 1]   [z]
                        If a_x, a_y etc. are constants, then this:
                        M669 K0 Xa_x:b_x:c_x Y-a_y:-b_y:-g_y Z1:1:1
                        with appropriate substitutions for a_x etc.
                        speedpeteundefined 1 Reply Last reply Reply Quote 1
                          speedpete @dc42
                          so a / b / g is a substitute for the lenght of the arms? ..and I have to find "a matching value" ?
                          Best Regards
                          Peter
                            dc42 administrators @speedpete
                            @speedpete I have a feeling that a_x etc. are not constants but are trigonometric functions. @oliof, can you point me to your reference for the inverse kinematics?
                            • oliofundefined
                              oliof @dc42
                              @dc42 they are constants, see https://github.com/oliof/RepRapFirmware/blob/colinear-tripteron/src/Movement/Kinematics/ColinearTripteronKinematics.cpp
                              (sorry I haven't looked at this code in a long time, I am a bit confused).
                              • oliofundefined
                                oliof
                                I've now refreshed my memory and with some helpful explanations from @Apsu yes those are all constants.
                                  speedpete @oliof
                                  @oliof and @dc42
                                  ...and what does an example "mechanics alike Apsu" in G-code look like for my starting point?
                                  Best Regards
                                  Peter
                                  • oliofundefined
                                    oliof @speedpete
                                    @speedpete Grab the formula from my code to compute the constants and then set up the kinematics as @dc42 described. I didn't get around to trying this weekend; I may be able to do this tonight.
                                      speedpete @oliof
                                      @oliof
                                      I don´t know how to do this, I´ll wait for your try 😉
                                      Best Regards
                                      Peter
