    RRF Update to 3.3 just killed my FW
    2.0k
    • Andy Cohenundefined
      Andy Cohen
      Tried to update from 3.0 to 3.3. It just hung. After about 20 minutes I gave up and rebooted. Now I can no longer connect to the machine via wifi, the extruder fan stays on and I can't get it to respond on the panel due at all. The update killed it.
      OK... so I will need to do a new install. HOW? I do not see new install instructions anywheres only updates.
      droftartsundefined 1 Reply Last reply Reply Quote -1
        It's likely that that wifi server didn't get updated correctly.
        Try sending M997 S1 on the panel.
        Otherwise connect via USB terminal and see what you can see there with M122.
        Also, did you update your config.g to enable the paneldue itself? That must be done in RRF3.
        M575 P1 B57600 S1
          droftarts administrators @Andy Cohen
          @andy-cohen if the firmware did update to 3.3 (connect via USB, send M115) send
          M997 S1 P”0:/sys/DuetWiFiServer.bin”
          Otherwise it will look in the /firmware folder, which doesn’t exist, and you’ll get an error message. 3.3 and later keeps firmware updates out of the sys folder.
            Andy Cohen
            Unfortunately... nothing seems to work at all. It acts like it cannot see the SD card and the extruder fan goes on. The update looks like it killed my whole setup!
            Can't I simply take the SD card out and make changes?
              There are config changes required between 3.0 and above. Can you post your current config.g?
              You can remove the SD card from the Duet and check the config.g on your PC.
              A firmware update can't kill anything. We just need you to connect the board via USB terminal to see what is actually going on.
              Andy Cohenundefined 1 Reply Last reply Reply Quote 0
                Andy Cohen @Phaedrux
                @phaedrux I was able top get the wifiserver running thanks to your post.
                It looks like quite a bit of the config is no longer working. Great.
                  The changes between 3.0 and up are pretty minor.
                  The change between RRF2 and RRF3 are more substantial. What firmware were you running before?
                  You can get an example config updated for 3.3 from the config tool to compare against. https://configtool.reprapfirmware.org/Start
                    Andy Cohen
                    @phaedrux I started with a late v2 and I'm lost with the new approach with the M950. Is there a web app I can use to gen the gcode?
                      Phaedrux Moderator @Andy Cohen
                      @andy-cohen said in RRF Update to 3.3 just killed my FW:
                      Yes. I linked it in my last post.
                      Here's what I normally tell people when they want to update from RRF2
                      If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
                      That will get your firmware and DWC up to date.
                      You can see the change logs here:
                      https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
                      For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
                      Backup your existing config files in the sys folder in case you want to switch back to RRF2. It’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
                      These documents will come in handy during the conversion.
                      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                      https://duet3d.dozuki.com/Wiki/Gcode
                        Andy Cohen
                        Thanks for the help.
                        I was able to get it to kinda work. It still does not see my extruder heater, only the bed heater. This is the heater gcode in the config file I generated:
                        Andy Cohenundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                          Andy Cohen @Andy Cohen
                          @andy-cohen Here's the tool def:
                            What does not see it?
                            Can you send M122 and M98 P"config.g" in the gcode console or USB terminal and share the results?
                              @andy-cohen Yeah... I see it... The web app did not make the P1 tool.
                                @phaedrux OK... heaters and fans seem OK.
                                Now the motors. They won't home. Comparing with my original config, I see nothing that can be incorrect. Any ideas?
                                M92 X88.57 Y88.57 Z400.00 E125.459271 ; set steps per mm
                                M201 X1000.00 Y1000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
                                M906 X800 Y800 Z400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                M84 S30 ; Set idle timeout
                                M208 X300 Y195 Z210 S0 ; set axis maxima
                                M574 X2 S0 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
                                M574 Y2 S0 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
                                M574 Z1 S0 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                                  S0 is incorrect.
                                  If the signal needs to be inverted, use S1 and add a ! to the front of the pin name.
                                  M574 X2 S1 P"!xstop"
                                    @phaedrux It moves but the limit switches are ignored. When told to Home X it moves it on an angle. It's a coreXY machine so I got something wrong..
                                    Why oh WHY was soooo much changed?!?
                                      You'll have to share your config and homing files at this point for any meaningful feedback.
                                      Are you sure it's set to corexy kinematic?
                                        @phaedrux Heck... at this point I'm not sure of anything!
                                        I also suspect the wifiserver FW needs to be updated as well as the ManelDue.
                                        ; Configuration file for Duet WiFi (firmware version 3.3)
                                        ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jan 31 2022 16:37:49 GMT-0800 (PST)
                                        M550 P"My Printer" ; set printer name
                                        M550 P"CloneDuet" ; Set machine name
                                        M552 S1 ; Enable network
                                        M586 P0 S1 ; Enable HTTP
                                        M586 P1 S0 ; Disable FTP
                                        M586 P2 S0 ; Disable Telnet
                                        M552 S1 ; enable network
                                        M586 P0 S1 ; enable HTTP
                                        M586 P1 S0 ; disable FTP
                                        M586 P2 S0 ; disable Telnet
                                        M574 X2 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
                                        M574 Y2 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
                                        M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                                        M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                                        M557 X10:300 Y-16.0:195 S20 ; define mesh grid
                                        M563 P1 ; Define tool 1
                                        G10 P1 X35 Y0 Z0 ; Set tool 1 axis offsets
                                        G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                                          Andy Cohen
                                          Yeah... you were correct.
                                          There's no
                                          "M669 K1 ; switch to CoreXY mode"
                                          I added it and now it seems to work.
                                            Can you send m122 and share the results?
